Old 09-08-2003, 06:13 PM   #1
PSI240SX
PSI240SX is an unknown quantity at this point
Blitz SSBC boost controller Q's
anyone have one of these units? I need the wiring diagram. Its the one with the seperate stepper motor.
www.enjukuracing.com
PSI240SX is offline   Reply With Quote
Old 09-09-2003, 09:31 AM   #2
FoCaL
FoCaL is an unknown quantity at this point
Send a message via MSN to FoCaL
What do you need to know exactly? I think its kinda self explanitory, but thats me.
I have an SBC-DC, and I can help you out if you let me know what you need. It will have to wait till I get home and can find the instructions, but Ill see what I can do. Also, the SBC does not use a stepping motor, thats the AVC-R. Blitz uses a dual silenoid in most of their boost controllers, and a single silenoid in their lower end ones.
FoCaL is offline   Reply With Quote
Old 09-09-2003, 08:34 PM   #3
PSI240SX
it has a connector with like 4 wires coming out of it and then a seperate connector with 2 wires... I need to know where they go. I dont have it in front of me so I cant say the color of the wires until tomorrow but i will post then.
Old 09-09-2003, 10:40 PM   #4
HaLo
from Canada, eh!
HaLo's Avatar
REd goes on 12V, black on ground and 2 others go on the Solenoid.
-> HaLo
Race Car: '98 E36 BMW M3
SOLD: 01 GPW Honda S2000
Old 09-10-2003, 08:23 PM   #5
PSI240SX
ok guys... I finally have pics of the thing and can explain what I need to know by showing you these pictures.
There is a connector coming out of the box that goes under the hood pictured here: .
4 wires.... Red, Black (turns to white), blue, and white. The blue and white are about 4 feet long and have a connector on the end pictured here:
That is the connector that the guy at Blitz said was supposed to be plugged into the brain box. I can assure you that there is no where on either thing to plug this connector in. Everything I got is pictured here:
Now the phone line thing plugs into both units, and the vaccuum line with the T on it plugs into the box under the hood, the red goes to positive and the black goes to ground... I get all of that.... where does the blue and white wires attached to the plug go? Blitz told me it goes into the piece that I am missing.
Old 09-10-2003, 08:58 PM   #6
HaLo
from Canada, eh!
HaLo's Avatar
Exactly... It's missing the small valve for boost control...
It's the part on the right. You actually see where the connector plugs in. I have the exact same boost controller.
-> HaLo
Old 09-11-2003, 10:32 AM   #7
FoCaL
I just got your PM, yes HaLo is right, your missing the solenoid. thats what goes under the hood. The Black box you have is the brain, and the gray box is just the display controller unit. Mine is a little different because I have a different boost controller but its the same concept.
