Old 11-05-2009, 10:44 PM   #1
2chuki4u
2chuki4u is an unknown quantity at this point
KA-t SAFC2 Settings wanted! (t25)
What are your settings?
-Post setup,settings, and degree of timing.
My setup is:
T25
n60 mafs
370cc inj's
i need a base setting tune please! ive looked all over so help if you can!
2chuki4u is offline   Reply With Quote
Old 11-05-2009, 10:56 PM   #2
Prok0
Prok0 will become famous soon enoughProk0 will become famous soon enoughProk0 will become famous soon enough
Send a message via AIM to Prok0
Simple math.
370 x .73 = 270
So your new injectors are 27% (1-.73=.27 or 27%) larger then your stockers, take out 27% fuel on low throttle map to get it to idle.
-27 across the board on low throttle pretty much
Then just get a wideband or get on a dyno and tune the high throttle map, set decel air function, etc. etc.
Everybodies settings are going to be different.
I also forget the MAF correction but you can probably find that in a second.
Prok0 is offline   Reply With Quote
Old 11-05-2009, 11:07 PM   #3
om3ga
om3ga's Avatar
om3ga is an unknown quantity at this point
im trying to sell my plug and play safc neo harness if anyone wants it. Props to prok0 for being cool and actually posting something helpful.
om3ga is offline   Reply With Quote
Old 11-06-2009, 09:43 AM   #4
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
Originally Posted by Prok0 View Post
Simple math.
370 x .73 = 270
This is great advice, and coming from a previous T25 KA-T owner I would follow what he's said here. The Stock S14 MAFS can handle 7psi btw... Once you hit 10, you'll max it out and go to full rich.
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 11-06-2009, 05:56 PM   #5
2chuki4u
i can see what hes saying by subtracting 27% out of my low throttle IF i had a stock mafs. but im running a n60 so shouldnt i set it at 0?... see thats whats got me right now. but otherwise, yea i do appreciate the help. +1.
byt the way im s13 not s14
Old 11-07-2009, 12:18 AM   #6
Prok0
I think the whole deal with the n60 maf and 370s was if you were running a stock ecu without the AFC.
I remember reading some shit about different maf housing sizes, etc. to get it to run properly.
But you have the ability to change your MAF input type in the afc to in essence 'trick' your ecu into reading the n60 properly...
Also, maxing out the stock maf really isnt that big of an issue, mine was maxed out pretty much once I got into boost on my KA-T, but it made it kind of nice since maf voltage stayed constant it made tuning with my wideband really simple.
So yeah, -27 and then just do the MAF correction deal, under the MAF table it should say like __ In __ Out, and you just have to put like 2 in 5 out or w/e corresponds to the MAF you have, I cant recall off the top of my head what the settings are for n60...
Old 11-07-2009, 12:42 AM   #7
yoni_nismo
yoni_nismo's Avatar
Trader Rating: (29)
yoni_nismo has a reputation beyond reputeyoni_nismo has a reputation beyond reputeyoni_nismo has a reputation beyond reputeyoni_nismo has a reputation beyond reputeyoni_nismo has a reputation beyond reputeyoni_nismo has a reputation beyond reputeyoni_nismo has a reputation beyond reputeyoni_nismo has a reputation beyond reputeyoni_nismo has a reputation beyond reputeyoni_nismo has a reputation beyond reputeyoni_nismo has a reputation beyond repute
Feedback Score: 29 reviews
you could run a n60 with 370cc without a safc just retard your base timing to 15deg a friend ran this for a while before getting a tuned ecu.... try to get a dyno run with afr readings before you start pushing your car because every motor runs diffrent so dont copy someones safc settings.
yoni_nismo is offline   Reply With Quote
Old 11-16-2009, 12:56 PM   #8
rsibley22
rsibley22 is an unknown quantity at this point
for changing the maf sensors you would need to know the correlation between the both voltage quantifier maps
rsibley22 is offline   Reply With Quote
