Old 11-06-2009, 08:38 AM   #1
TTrx7Pete
TTrx7Pete's Avatar
TTrx7Pete is making a name for him/her selfTTrx7Pete is making a name for him/her selfTTrx7Pete is making a name for him/her self
Injectors reachign 100% duty cycle on 10psi S14SR Blacktop
Brief rundown of the car:
97 S14 with SR20DET S14 Blacktop T28 with VTC
FMIC, Walbro 255lph pump, stock injectors, full 3" exhaust, intake, PowerFC D-Jetro.
The fuel system, sans pump, is stock. I'm running 10 psi of boost and I'm constantly hitting 100% duty cycle in the upper 5.5-7k rpm range. So I don't floor it, or get into it anymore. Wondering why I am hitting 100% duty cycle as I've read on the forum over and over that 10 psi is safe boost with stock injectors.
Anything you guys think that may be set improperly? I plan on double checking the injector settings on the PFC. Anything else?
1993 AW Mazda RX-7
1997 Nissan Silvia
TTrx7Pete is offline   Reply With Quote
Old 11-06-2009, 08:41 AM   #2
Def
Sounds about right for 370's and some bolt-ons with a GT2560R.
Some people's definition of "safe" is pretty sketchy on this forum...
DEFSPORT
Old 11-06-2009, 09:14 AM   #3
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
^ I thought the S14 SR20DET had 440's? Also, can't you just say S14 SR20DET? Are there multiple models of the s14 engine?
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 11-06-2009, 09:17 AM   #4
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Nopes...S14s got 370s just like S13s. S15s have 440s stock...
CLICK HERE!!!
Old 11-06-2009, 09:29 AM   #5
s14unimog
s14unimog's Avatar
Trader Rating: (22)
Good to know, thanks. So what about the whole "blacktop" S14 SR20DET?
Old 11-06-2009, 10:05 AM   #6
TTrx7Pete
TTrx7Pete's Avatar
In any event... my question was not answered lol... I'm still wondering why I am hitting 100% duty cycle on the stock T28 Turbo.
1993 AW Mazda RX-7
1997 Nissan Silvia
Old 11-06-2009, 10:10 AM   #7
MandTPhotography
MandTPhotography is an unknown quantity at this point
My injectors are static at like 14lbs on a T25, 370cc's.
MandTPhotography is offline   Reply With Quote
Old 11-06-2009, 10:30 AM   #8
jspaeth
jspaeth's Avatar
Someone already told you why. You have maxed them out. That turbo at the boost is good for probably 275 whp or so, I would guess.
And that is enough to max out those injectors at stock fuel pressure.
It's not really that mysterious to be honest.
Daily driven
Old 11-06-2009, 10:39 AM   #9
tunersedge
tunersedge is making a name for him/her selftunersedge is making a name for him/her self
problem : you are maxing the injectors out.
solution : go bigger.
tunersedge is offline   Reply With Quote
Old 11-06-2009, 01:35 PM   #10
s14unimog
s14unimog's Avatar
Trader Rating: (22)
^that's why I thread jacked.... SO is "blacktop" necessary to be said with S14 SR20DET...?
Old 11-06-2009, 04:33 PM   #11
S13 curtis
S13 curtis's Avatar
S13 curtis is an unknown quantity at this point
jus get a adjustable fuel pressure for now that will be a temporary fix for now.
S13 curtis is offline   Reply With Quote
Old 11-06-2009, 04:51 PM   #12
jspaeth
jspaeth's Avatar
Worst idea ever.
He will be running really rich everywhere else.
Fail
Daily driven
Old 11-06-2009, 06:41 PM   #13
Def
Damn... some people are just dense.
Why don't you bump the boost up to 18 psi, it'll fix all your problems. :ghey:
DEFSPORT
Old 11-06-2009, 07:55 PM   #14
TTrx7Pete
TTrx7Pete's Avatar
I guess I'm missing something here.... I have a stock turbo with stock injectors running only 10 psi of boost... and I'm maxxing out my injectors? I was under the impression that 10 psi of boost was the factory boost setting on the S14 SR...
So why am I having an issue at "stock" boost levels?! That is my issue.
1993 AW Mazda RX-7
1997 Nissan Silvia
Old 11-07-2009, 08:21 AM   #15
lok
lok's Avatar
lok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond repute
7 is stock
lok is offline   Reply With Quote
Old 11-07-2009, 08:46 AM   #16
S14DB
AFC #1
S14DB's Avatar
7 is stock wastegate. Stock EBC raises it to 10.
Check your injector settings. Do you have an wideband? know your AFR's?
10 is safe on a stock setup. You have aftermarket parts that can cause you to flow more air at the same boost. But I can only assume something is wrong with the tune and would recommend some pulls on dyno with wideband.
Old 11-07-2009, 08:51 AM   #17
910noskillz
910noskillz's Avatar
910noskillz is an unknown quantity at this point
yeah, 7psi is stock.....as the reference to running 14 and the injectors being static, that is on a t25,
the t28 is a little bigger than that turbo though, and flows more air, and makes more power at lower boost levels(as opposed to a t25).....I would say that the stock injectors are good to about 250, then an upgrade would be needed.....
the point is if there maxing out, then there maxing out. theres no way around it unless you get bigger injectors....
get some bigger injectors and crank it to about 13psi, it will be worth the $350 when all is said and done....or just remove your boost controller and run stock boost
910noskillz is offline   Reply With Quote
Old 11-07-2009, 11:14 AM   #18
jr_ss
Hmmm, I thought that the S15 injectors were 480's? In any event, You need bigger injectors...
Old 11-07-2009, 11:25 AM   #19
Cone
Cone has much to be proud ofCone has much to be proud ofCone has much to be proud ofCone has much to be proud ofCone has much to be proud ofCone has much to be proud ofCone has much to be proud ofCone has much to be proud ofCone has much to be proud ofCone has much to be proud ofCone has much to be proud of
I know with some cars, you will hit 100 dc and it is totally fine. But to determine if there really is a problem, you need a wideband.
Cone is offline   Reply With Quote
Old 11-08-2009, 02:32 PM   #20
jr_ss
100% DC is not fine ever... Your injectors are no longer pulsing, but are staying open and pissing fuel... Bad idea
You "can" bandaid it (I use that term loosely) with a meth injection kit. This is common in the Subaru world, but I don't like the idea of relying on a small tank and pump to keep my engine from blowing up, no thank you.
Old 11-08-2009, 10:04 PM   #21
johngriff
johngriff's Avatar
I don't like the injector duty cycle feed back on the PFC.
I have seen this too on the commander in different cars with similar setups, some will say 100% duty cycle, other will say 70%.
What is the PFC basing the duty cycle on? I know injector open times, you should probably stop around 30ms with a stock sidefeed. Maybe hook up a scope to an injector signal out on the ecu harness and log the wave at your 100% event. If you are running 26ms+ I could believe the injectors are maxed out.
[email protected]
Old 11-09-2009, 12:05 PM   #22
s14unimog
s14unimog's Avatar
Trader Rating: (22)
Its surprising that there are still people on here that believe stock boost is 7psi... At any case, I would verify that the injector duty reading is correct; you're right, that shouldn't happen at stock boost levels.
Old 11-09-2009, 05:43 PM   #23
TTrx7Pete
TTrx7Pete's Avatar
Well it starts to cut out and I'll get some knock, so I'm certain that it is maxxing out the injectors. My engine light will flash. I come from the world of rotaries, so I don't take detonation lightly. I'm just shocked that for some reason I'm hitting 100%. The car was tuned already, but I'm guess that my supporting mods might be increasing the cfm of air and I'll need an injector upgrade... I guess for now I'll just turn down the boost.
Thanks to everyone who knows what I was talking about. 10psi is the stock boost level on the SR20DET, 7 PSI is the wastegate actuator spring setting.
1993 AW Mazda RX-7
1997 Nissan Silvia
Old 11-10-2009, 02:18 AM   #24
S13 curtis
S13 curtis's Avatar
Originally Posted by jspaeth View Post
Worst idea ever.
Fail
not really, depends on which fpr you have and if you have it tuned with the fpr.
