Old 09-09-2003, 06:22 PM   #1
DMC
DMC's Avatar
DMC is an unknown quantity at this point
Stupid People Cause Cancer
Hey guys awhile ago i posted about my 240sx fastback that i was trying to "restore" well heres the update.
I removed all of the interior panels hte dash the automatic seatbelts the carpet and the roofliner and this guy put white vinyl sound proofing EVERYWHERE under the carpet under th roof lining he even filled up behind the front FENDER! Im not sure why. He aslo had wood screws all over the trunk and sides of the interior. I am currently in the process of removing the fenders, bumpers, white vinyle, wood screw, the custom made sub box(he cut into the car and put it in the wall slopely),the spray in foam, and the support behind the dash.
MORE BAD NEWS
I was starting to remove the fender today when i noticed a gaping whole in the car form the bottom rite in front of the rigght rear tire. My assumption is he jacked it up on this point with a normal jack you have around your house(not the one with the car) and it eventually broke threw and rusted. Its horrible! I think i need to grind off the entire piece(it goes into the car) adn replace it. Any SUGGESTIONS would be helpful. Also there is some rust holes in the spare tire holder.
Good News
-Matt(boostin) gave me a free dash with hud, free froont seats and free non power seatbelts!
-Matt(mbmbmb) gave me free front and rear seats!
-I almost got the fenders and bumper off in which i just have to knock out a few dents and repair the bumper then primer them all!
-I am planning to put in doors with all power options
As for the SR
THe engine is wating for me to drop the crank then im going to have the block and head boiled(or whatever chemical they use) I am going to have the pistons polished, then i plan to port out the head as well as manifolds and replace all seals and rings, and repaint the valve cover.
After which i will buy an fmic, boost controller , ecu and wiring harness and drop it in the car!
DMC is offline   Reply With Quote
Old 09-09-2003, 11:05 PM   #2
spindrift187
spindrift187's Avatar
spindrift187 is an unknown quantity at this point
Lemme know when you can get the block to me so me and heath can take it to the shop
spindrift187 is offline   Reply With Quote
Old 09-09-2003, 11:58 PM   #3
JasonNagra
JasonNagra is an unknown quantity at this point
Send a message via AIM to JasonNagra
Well its a project and you WILL learn a whole lot. In the end, if you do it the way you want, you will be happy though. Trust me...
http://www.imagestation.com/picture/...f/f9dc7664.jpg
Edit: check your link.
JasonNagra is offline   Reply With Quote
Old 09-10-2003, 05:46 AM   #4
DMC
DMC's Avatar
Thanks jake i didnt know you guys were still gonna doit. I ned to read up alittle bit before i pull the crank and pistons out but i think it will be out sometime next week. Let me know when you wanna take out this clutch man your never online.
Yea thanks man i figure the more work i put into it then the better its gonna feel when i get it on the track(after i turn 18) I really hope I can fix the hole up perfect.
Old 09-10-2003, 09:44 AM   #5
Fastback180
Fastback180's Avatar
Fastback180 is an unknown quantity at this point
Send a message via AIM to Fastback180
Ohhh god, I know the horrors of people installing head units and sh*t w/that Great Stuff foam. Losers. I have yet to see Boostins Beemer.
Fastback180 is offline   Reply With Quote
Old 09-10-2003, 11:24 AM   #6
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
Re: Stupid People Cause Cancer
Originally posted by DMC
MORE BAD NEWS
As far as fixing that rust hole the ideal thing would be to cut out the hole and weld in a square patch. If you cannot do that, I think an alternative would be to cut out the hole, grind the edges to smooth bare metal, spray the bare metal with primer, and then place a slightly oversized peice of metal on both sides of the hole (sandwiching the hole) and then rivet the peices together. You could even put JB weld between the metal peices and around the edges of the metal plates. I'll attach a pic of what I mean.
-m
mbmbmb23 is offline   Reply With Quote
Old 09-10-2003, 07:32 PM   #7
formeRiceR
formeRiceR is an unknown quantity at this point
I'm kinda in the same situation as you are, bought a S14 but a lot of rust and some holes. I've used a product called por-15 to prevent anymore rust, it's a long process, you have to nuetralize the rust them coat it with a por-15. It seems to work fgood. My neighbor has it on his car, a 1960's firebird or some domestic like that, he's the one that recommended it to me in the first place. but be warned if you don't prep the metal right it won't work as good
"Street racers don't need girls." -Lonely Driver
Learning about cars one FLAME at a time ... (thanks to TNORD)
formeRiceR is offline   Reply With Quote
Old 09-10-2003, 07:49 PM   #8
ZOLTAN
ZOLTAN's Avatar
ZOLTAN is an unknown quantity at this point
POR-15 is great stuff.
Every muscle car guy I know uses it.
Hell, visit their website, www.por-15.com ,they make all kinds of super-tough paints and refinishing products.
My understanding, and correct me if I'm wrong, is that most of the por-15 products were originally meant for the marine industry; so, it's excessively tough ****.
ZOLTAN is offline   Reply With Quote
Old 09-10-2003, 07:53 PM   #9
DMC
DMC's Avatar
Dang matt thats a really good idea i may do that if i cant replace the whole piece. Zoltan i am user some generic brand rust like solidifier its supposed to turn it too metal but i just use it to spray the spots i havent got rid of the rust yet then i sand it wit sand paper when i get around to it and spray it again to completely eliminate all rust good idea goodluck with your car
Old 09-10-2003, 08:02 PM   #10
ZOLTAN
ZOLTAN's Avatar
Be careful with rust converters.
Sometimes they work, sometimes they don't.
I'd be especially wary of the cheap stuff.
Old 09-10-2003, 08:29 PM   #11
DMC
DMC's Avatar
thanks man ill look out for that. but like i said im removing it all with a grinder so it should be fine
