Old 11-11-2009, 09:46 PM   #1
asg240
asg240's Avatar
asg240 is an unknown quantity at this point
s13 Engine bogs and dies, low idle??
Alright, so im new to Zilvia. I have a 93 hatch, Dohc. My hatch started bogging when i would revv past 2.5K and then it just finally died last night, i tried replacing spark plugs, checking voltage, and a few other things, but nothing worked.
If i try to fire it up, it starts, then few seconds it starts to bogg and dies. I cant keep it running for more than a few seconds.
It leads me to believe the injectoers are messed up because afret i try cranking it, i get a smell of fuel coming from somewhere by the intake manifold.
asg240 is offline   Reply With Quote
Old 11-11-2009, 10:13 PM   #2
SleepR 240sx
SleepR 240sx's Avatar
SleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond repute
Send a message via AIM to SleepR 240sx Send a message via MSN to SleepR 240sx
Vacccuuuuummmm leak
This is zilvia. We aren't nice.
Quoted For Truth
Check out the coolest new thing: toddrickkkkk.blogspot.com
SleepR 240sx is offline   Reply With Quote
Old 11-11-2009, 10:25 PM   #3
nismoskyz
nismoskyz's Avatar
nismoskyz is an unknown quantity at this point
check spark plug wires
try cleaning MAF sensor
(function)(form)^(-1)
nismoskyz is offline   Reply With Quote
Old 11-11-2009, 10:29 PM   #4
asg240
asg240's Avatar
Cleaned MAF, I did take off the vacuume line going to the valve cover and put a small filter on it... would that be it?
Old 11-12-2009, 04:52 PM   #5
zenki.life
zenki.life's Avatar
zenki.life is an unknown quantity at this point
Send a message via AIM to zenki.life
I was going to say vacuum. 90% of the issues with any of our cars is that kids fuck with the vacuum. once its fixed most engines will run like champs
Originally Posted by super240s14 View Post
man you all are ass holes...... and that is rude to talk like that on zilvia im reporting all you...... ZILVIA ADMINISTRATION PLEASE BANNED ALL THREE OF THESE DUDES
^^another person learns the perils of "stupid posting" on zilvia, too bad none will care.
zenki.life is offline   Reply With Quote
Old 11-13-2009, 11:52 PM   #6
fcdrifter20
fcdrifter20's Avatar
Trader Rating: (44)
fcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to behold
Feedback Score: 44 reviews
spray the area where u hear the noise with carb clean and see if u get a change in the idle of the car. is so then u kno for sure u got a vaccume leak
fcdrifter20 is offline   Reply With Quote
Old 11-15-2009, 04:01 PM   #7
asg240
asg240's Avatar
Well now the engine wont start, so i cant check it if it doesnt idle. I replaced plugs, wires, cap and rotor. and added some coolant. the car gets spark, and gas, but it doesn't fire. i think that it began running rich until the car finally flooded and it doesnt turn over. Damnit, i need this as a daily.....
Old 11-15-2009, 04:32 PM   #8
cotbu
cotbu's Avatar
while it's not starting..., is a good time to check the ecu for codes
tip: whenever your vehicle starts acting odd, don't just replace parts! exceptions are fuses, bulb, and relays etc.
Not turbos, ecu's and harnesses...harness's... harness!
plugs, wires, cap and rotor can be inspected, most replace these items during maintenance while vehicle is running well.
You're problem sound like a vacuum leak\ mafs problem but timing could be off now.
check codes, get it start check timing.
Old 11-15-2009, 05:26 PM   #9
asg240
asg240's Avatar
Quik question. how can i check codes? im not too familiar with ecu diagnostics. are you talking abut getting an obd1 reader and see what code(s) it throws?
Old 11-17-2009, 07:07 PM   #10
asg240
asg240's Avatar
i checked to see if it was throwing codes, but it didnt. it said 55 = no malfunctions in above circuits. im at loss... im going to check vacuum lines, fuses and fuel again to see if i missed something....
Old 11-19-2009, 02:50 AM   #11
asg240
asg240's Avatar
So its fixed..... it was my fuel pump, replaced it with a New High Flow one, i got my Adjustable FPR being shipped, and now all i gotta do is change my oil.
chuki kade 240sx
