Old 11-12-2009, 09:01 PM   #1
idamaster
idamaster's Avatar
idamaster is an unknown quantity at this point
Sr20 cam sprocket removal.
Been following that manual on sr20's up to this point. It says to use a socket on the sprocket and an open end wrench on the hexagon shaped thing on the cam. I dont see where this thing is. How do I remove the sprockets ?
http://i288.photobucket.com/albums/l...x/100_1254.jpg
http://i288.photobucket.com/albums/l...x/100_1255.jpg
http://i288.photobucket.com/albums/l...x/100_1256.jpg
idamaster is offline   Reply With Quote
Old 11-12-2009, 09:10 PM   #2
Sileighty_85
Sileighty_85's Avatar
its DIRECTLY in front of the #1 cylinder cam lobe
you can do that or throw a breaker bar on the crank and hold it that way also.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 11-12-2009, 09:21 PM   #3
idamaster
idamaster's Avatar
Thanks, I thought that it was supposed to stick out like the lobe does. I cant fit my open end wrench in there because its too thick. About the whole breaker bar on the crank can I do that without the belt being tensioned?
Old 11-12-2009, 09:30 PM   #4
Sileighty_85
Originally Posted by idamaster View Post
Thanks, About the whole breaker bar on the crank can I do that without the belt being tensioned?
youp.......................
後輪駆動車1番
1986 SR86 - 200ish
Old 11-12-2009, 09:35 PM   #5
idamaster
idamaster's Avatar
Well that didnt work. The chain ended up jumping like 5 links.
Old 11-12-2009, 09:41 PM   #6
jspaeth
jspaeth's Avatar
Ew.......doesn't that put an awful lot of stress on the timing chain?
I wouldn't do that, but then again I am paranoid.
Daily driven
Old 11-12-2009, 09:52 PM   #7
garagelu
Trader Rating: (60)
garagelu is on a distinguished road
Feedback Score: 60 reviews
put a screwdriver through one of the holes of the sprocket to keep it from moving when you loosen the bolt.
Use your head people!!
garagelu is offline   Reply With Quote
Old 11-12-2009, 10:37 PM   #8
Sileighty_85
lol i guess put the tensioner back in.
works for me ive done it 4 times already
後輪駆動車1番
1986 SR86 - 200ish
Old 11-12-2009, 10:52 PM   #9
idamaster
idamaster's Avatar
Ill try to see if an adjustable wrench will fit onto the cam tomorrow
Old 11-12-2009, 11:07 PM   #10
fcdrifter20
fcdrifter20's Avatar
Trader Rating: (44)
fcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to behold
Feedback Score: 44 reviews
owww.
all u have to do is hold the hex realy realy good and dont let it move if ur using the breaker bar technique. so u gota put some real huevos into it,if u let it slip, it could mess things up. i have done this a couple times with out problems. but i usualy use an impact to pull it off wich is the easiest.
fcdrifter20 is offline   Reply With Quote
Old 11-12-2009, 11:10 PM   #11
Sileighty_85
a normal wrench wont fit it, You'll have to grind the wrench to fit unless you can find a Thin wrench to fit it
後輪駆動車1番
1986 SR86 - 200ish
Old 11-12-2009, 11:12 PM   #12
idamaster
idamaster's Avatar
Ill go buy an impact wrench. Ive always needed one anyways.
Old 11-13-2009, 08:43 AM   #13
jspaeth
jspaeth's Avatar
I took the sprockets off with the cams OUT of the car.
Wrap whole cam in towels, put it on workbench.
Adjustable box end wrench over hex portion (had one that BARELY squeezed in there)....make sure it is ON and fits snugly.
Breaker bar on the bolt.
You can do it with 1 person....rotate the cam so that the wrench wedges down against the workbench.
Helps to have a second person to hold the cam down and hold the wrench tho.
Daily driven
Old 11-13-2009, 12:10 PM   #14
slow92
slow92's Avatar
slow92 is an unknown quantity at this point
impact wrench all the way with the transmission in gear so the crank won't move
Sr22 in the works
slow92 is offline   Reply With Quote
Old 11-13-2009, 02:43 PM   #15
jspaeth
jspaeth's Avatar
You guys are crazy, or I am just a little bitch.
All of that torque is being put through the timing chain....and it is an impact tq, not a smooth tq.
I just don't like the idea of doing that, doesn't sit right with me.
Daily driven
Old 11-13-2009, 08:10 PM   #16
garagelu
Trader Rating: (60)
Yea I totally agree that you are being a bitch about it.
COME ON, you arn't going to be sitting there for an hour with the impact hammering away at it. It should take more than a second or two to break it loose with the impact.
I can't believe there is a thread about how to break a bolt loose.
Throw a screwdriver in the sprocket hole to keep it from moving and break it loose.
OR
if you have an impact, put it in 5th gear and break it loose.
I really hope you have the bolt out by now....if not, thats sad.
Old 11-14-2009, 01:27 AM   #17
Ceepo
Ceepo's Avatar
wow, this is retarded, take your wrench grind it down so its not as thick and break that bitch loose, not hard at all dude!!!
Old 11-15-2009, 07:08 PM   #18
aNskY
aNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfection
Send a message via AIM to aNskY
i have always used a impact... even with no trans/ nothing holding crank pulley.. a quick zip breaks 'em free...
Bye bye zilvia kiddies
aNskY is offline   Reply With Quote
Old 11-15-2009, 09:21 PM   #19
idamaster
idamaster's Avatar
Exactly what I did. I held the breaker bar on the crank tight but the impact wrench didnt move it.
Old 11-15-2009, 09:24 PM   #20
garagelu
Trader Rating: (60)
What kind of impact gun are you using? Turn up the air pressure or get a impact that can handle more torque.
There should be no reason why an impact can't get that off.
Old 11-15-2009, 09:45 PM   #21
idamaster
idamaster's Avatar
I meant the impact gun didnt make the crank move. The sprocket was taken off in a millisecond haha
Old 11-15-2009, 09:51 PM   #22
djcobra
djcobra's Avatar
djcobra is making a name for him/her selfdjcobra is making a name for him/her selfdjcobra is making a name for him/her self
WTF! take off the rocker arm stoppers and you should be able to place the hexagon wrench on the camshaft nicely (I think its either 25mm or 26mm I forget), and use a break-bar on the front of the sprocket (26mm or 27mm I believe, don't quote me on it). Never use the chain for tension, geez!
Steve.
S14 326 whp, 311 tq @ 15 psi HKS F-CON V-PRO
djcobra is offline   Reply With Quote
Old 11-15-2009, 10:09 PM   #23
Sileighty_85
Steve.
Normal wrenches are too fat
You need to either get find a thin made one or grind one to fit
後輪駆動車1番
1986 SR86 - 200ish
Old 11-16-2009, 08:06 AM   #24
jspaeth
jspaeth's Avatar
I had an adjustable wrench that I used and it BARELY fit on there.....
Then, I used on my HKS cams to put the sprockets back on, and it fit on those no problem.
Daily driven
