Old 09-13-2003, 11:33 PM   #1
jorge
jorge is an unknown quantity at this point
s13 stock hub studs to short for 5mm spacers?
hi, I want to know if the stock s13 hub studs are to short to be used with 5mm spacers? Is using the stock studs safe, or should I go for some longer nismo hub studs?
jorge is offline   Reply With Quote
Old 09-14-2003, 12:05 AM   #2
Kid Zelda
Kid Zelda is an unknown quantity at this point
Send a message via AIM to Kid Zelda
5mm is fine
I ran 5mm spacers on stock studs w/ no problems .. btw, hard driving
Kid Zelda is offline   Reply With Quote
Old 09-14-2003, 01:01 AM   #3
jorge
yeah daily driven and track, I was recommened by a freind freind who did the z brakes also and was in the same dillema he said he got longer nismo ones, and I think it would be safer also. because theres not enouph thread, that makes me feel uneven Im going to get some longer nismo studs
Old 09-14-2003, 01:02 AM   #4
jorge
but the question is now what size studs should I get?
NISMO Long Hub Bolt
Length 50mm
1 Bolt - Price $8.00
NISMO Long Hub Bolt
Length 60mm
which one would be the right size, should I just get the 60mm?
Old 09-14-2003, 01:46 AM   #5
mrmephistopheles
mrmephistopheles's Avatar
if nismo, get 60mm.
For some reason, 50mm are weaker. (in the experience of a few friends of mine)
Old 09-14-2003, 01:48 AM   #6
jorge
thanks man really apretiate your help
Old 09-14-2003, 01:55 AM   #7
jorge
should I get some for the rear while Im at it?
Old 09-14-2003, 10:07 AM   #8
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
if you get the longer ones you may not be able to run the center caps on certain wheels. I would think that 10mm difference would be enough to keep some center caps from popping/screwing on correctly.
I had some 8mm spacers and there is no way there would have worked with the stock studs.
andrave is offline   Reply With Quote
