Old 12-16-2009, 05:02 PM   #1
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
S-13 parts clearence, nothing over $10! SOHC, chuki, and more!!!
SOHC AAC valve assembly
This is the valve that actually controls your idle. It came off a running engine with no idle issues. I cleaned it thoroughly with air intake cleaner as well.
$5
SOHC IACV valve
This valve can cause idle issues as well. This came off the same engine as the AAC valve. I also cleaned this valve thoroughly.
$5
SOHC distributor w/cap and rotor
Came off a perfectly running car. The cap and rotor are bosch and are useable.
$10
SOHC MAF sensor
Came off a running car, it's for sure good. I cleaned it with MAF cleaner so it's ready to go.
$10
SOHC ignition coil assembly
This also came off a running car, for sure good. You can use it on a KADE as well, you just have to lengthen the coil plug harness a little.
$10
Chuki bumper to fender brackets
These are the OE brackets that hold the fender to the bumper on the chuki front end. Good condition, not mangled or anything.
$10
Steering wheel hub for s-13
This is an no-name brand huf for the s-13 chasis. The boot is missing, but the hub functions fine. The little pins for the turn signal auto off are there. The wire that connects the hore button to the horn pad fell off, but another can be soldered on.
$5
S-13 non-HUD guage cluster harness
This will work on any s-13, zenki or chuki doesn't matter. It plugs into the back of the guage cluster and plugs into the chasis harness on the other side.
$5
S-13 OE front endlinks
I found some of these lying around in a box and figured someone might need them. All are in good, useable condition. The washers for the bushings can be provided upon request free of charge.
$5 each
racepar1 is offline
Old 12-18-2009, 12:16 PM   #2
racepar1
racepar1's Avatar
First bump........
racepar1 is offline
Old 12-19-2009, 03:04 PM   #3
racepar1
racepar1's Avatar
Last bump........
racepar1 is offline
