Old 12-23-2009, 02:05 AM   #1
JDMbyBlood
JDMbyBlood's Avatar
Trader Rating: (24)
JDMbyBlood is a jewel in the roughJDMbyBlood is a jewel in the roughJDMbyBlood is a jewel in the roughJDMbyBlood is a jewel in the roughJDMbyBlood is a jewel in the roughJDMbyBlood is a jewel in the roughJDMbyBlood is a jewel in the roughJDMbyBlood is a jewel in the rough
Feedback Score: 24 reviews
Anybody using MAX ruca with Tein Coilovers?
Looking to order the complete MAX multi link set up for my s13. A customer complained that there were issues with fitment with Tein Coil overs and the MAX ruca. I email MAX and received this reply:
basically we designed it to have loads of clearance for anything out there but someone complained that had teins
I have no idea what their ride height settings or alignment settings were - did not see a picture - but apparently there is a problem with tein although there is a possibility that the settings on that particular car were not helping the clearance
for example the ruca is designed to go on lowered cars with about -1* camber
but if you tried to do massive negative camber or ride high it would not promote good clearance.
I never really thought much about it because most customers that come here sell their teins for our coilovers anyhow.
Im sure this completely undefinitive answer does not help you make a decision but that's the truthful course of events.
Can anybody verify that there is issues with fitment? I'd really like to go with MAX if I can, but wanted to double check with anyone that may be using Tein Coil overs with the MAX ruca.
Thanks....
JDMbyBlood is offline   Reply With Quote
Old 12-23-2009, 08:33 PM   #2
mangoes
mangoes has a reputation beyond reputemangoes has a reputation beyond reputemangoes has a reputation beyond reputemangoes has a reputation beyond reputemangoes has a reputation beyond reputemangoes has a reputation beyond reputemangoes has a reputation beyond reputemangoes has a reputation beyond reputemangoes has a reputation beyond reputemangoes has a reputation beyond reputemangoes has a reputation beyond repute
im in the same predicament. have tein flex's want max RUCA.
Outside Family
mangoes is offline   Reply With Quote
Old 12-23-2009, 08:38 PM   #3
JDMbyBlood
JDMbyBlood's Avatar
Trader Rating: (24)
Im also using the Tein Flex coilovers.
Old 12-23-2009, 08:42 PM   #4
JDMbyBlood
JDMbyBlood's Avatar
Trader Rating: (24)
I've been talking with Dan over at Max and we are both pretty confident that the ruca should work. I sent him pictures of my set up to get an idea of spacing and such.
Old 12-23-2009, 08:50 PM   #5
udon!
udon! is an unknown quantity at this point
wait, what? does this just apply to cars with tein coilovers?
because i thought obm stuff was designed for cars that practically drag the frame rails
udon! is offline   Reply With Quote
Old 12-23-2009, 08:51 PM   #6
mangoes
I had a set of Battle Version RUCA for S14 from my old car and tried fitting it onto the S13 but it had major clearance issues.
If the PBM ones have more clearance than the Battle Version ones I think it should be ok.
Outside Family
Old 12-23-2009, 08:57 PM   #7
LayNLow
LayNLow is making a name for him/her selfLayNLow is making a name for him/her self
You probably had them on the wrong side. They are interchangable, it just makes it easier to change out the camber arm or the strut and spring assembly on a s14 because its only a half circle, not a full circle like a 13.
LayNLow is offline   Reply With Quote
Old 12-29-2009, 01:05 AM   #8
om3ga
om3ga's Avatar
om3ga is an unknown quantity at this point
I have Tein super drifts, I talked to dan and he said a customer had the same ones and had to remove the helper springs. I decided to go a different route however that is an option!
om3ga is offline   Reply With Quote
Old 12-29-2009, 12:09 PM   #9
lilrusty
lilrusty's Avatar
Trader Rating: (37)
lilrusty is an unknown quantity at this point
Feedback Score: 37 reviews
a buddy of mine using pbm ruca with tein basic dampers on his s13. everything cleared just fine. his car is pretty low too...
lilrusty is offline   Reply With Quote
