Old 01-26-2010, 09:38 PM   #1
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
SR/KA Power Steering Pump Switcheroo
KA and SR power steering pumps are interchangeable
KA on left, SR on right
unbolt pulleys and tensioner brackets
again KA on left (14mm and 12mm bolts)
SR on right (17mm and 12mm bolts)
notice the different banjos bolts
use the one that matches your high pressure line
switch gear and presto
aren't you glad you didn't spend money on a new SR power steering pump?
(change the pump in the rain for an automatic +10 street cred points.)
Old 01-31-2010, 11:01 PM   #2
datboibrad
datboibrad can only hope to improve
lol great write up on old news. it is sweat to see pics documented tho.
datboibrad is offline   Reply With Quote
Old 01-31-2010, 11:04 PM   #3
Sileighty_85
Sileighty_85's Avatar
you can also use a Non HICAS PSP on a HICAS bracket.
It requires modification of the back section of the pump
Ive got a post around somewhere with pics
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 02-01-2010, 08:10 AM   #4
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
yeah, this is as old as dirt
I just didn't remember seeing a detailed picture how and figured 'why not?'.
Old 02-01-2010, 10:39 PM   #5
markapple0507
markapple0507's Avatar
markapple0507 is an unknown quantity at this point
No ya this is great news for newbies like me. My question would there be any benefit of using a hicas psp on a non hicas car if so can it be done. I'm assuming you would use the non hicas mounts
bob,syouruncle
markapple0507 is offline   Reply With Quote
Old 05-04-2010, 06:33 PM   #6
va240dude
va240dude's Avatar
Trader Rating: (161)
va240dude is an unknown quantity at this point
Feedback Score: 161 reviews
Anyone know about S13/S14/S15 SR power steering pumps? With the exception of HICAS pump, are they all interchangeable? I searched but found nothing...just KA to SR and vice versa. Any help would be appreciated.
180SXオタクだ!
va240dude is offline   Reply With Quote
Old 05-04-2010, 07:13 PM   #7
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
lol i found this out during my engine swap by eye balling. i torqued down the high pressure line too much ont he SR pump while i was doing a swap in my s13 and destroyed the pump housing.
figured shoot, they kinda look the same let me compare them. mine were identical, but the ones in the pics that the OP posted are not identical.
clark is offline   Reply With Quote
Old 06-16-2010, 06:04 PM   #8
TheRealSy90
TheRealSy90's Avatar
I just bought a bunch of shit so I can hook up powersteering on my 89 coupe SE, seems that I somehow ended up with a HICAS powersteering pump so of course it has two banjo bolts. Is there any way I can make this pump work? Maybe block off the second bolt?
Such a good signature.
Old 06-18-2010, 03:15 PM   #9
bb4_96
bb4_96 is an unknown quantity at this point
can you put the ls pump on the ka or sr? because its better...
bb4_96 is offline   Reply With Quote
Old 01-03-2012, 11:50 AM   #10
Nacho_240
Nacho_240's Avatar
Trader Rating: (36)
Nacho_240 is an unknown quantity at this point
Feedback Score: 36 reviews
Bumping an old thread here...
Can anyone elaborate on which specific ka pump can work with the s13 sr? A quick search told me s13 KADE but I'd like to know if a s14 KADE will work as well.
Nacho_240 is offline   Reply With Quote
Old 01-03-2012, 11:53 AM   #11
SLiDe_WaYz
SLiDe_WaYz's Avatar
SLiDe_WaYz is an unknown quantity at this point
Dual Cam ps pump
SLiDe_WaYz is offline   Reply With Quote
Old 01-03-2012, 12:00 PM   #12
Nacho_240
Nacho_240's Avatar
Trader Rating: (36)
But from s13 or s14?
Old 01-03-2012, 12:23 PM   #13
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Same same...
CLICK HERE!!!
Old 03-17-2017, 04:18 PM   #14
blazin_teg
blazin_teg is an unknown quantity at this point
I know this is an old thread but can't find any info anywhere. Will a ka hicas pump fit a sr with hicas? I have a sr swapped car that still has the hicas system, but my sr pump quit and I can't find a sr hicas pump anywhere.
blazin_teg is offline   Reply With Quote
