Old 10-12-2003, 08:37 AM   #1
Swoop411
Swoop411's Avatar
Swoop411 is an unknown quantity at this point
Send a message via Yahoo to Swoop411
SR Turbo Tuning
Sed ut perspiciatis unde omnis iste natus error sit voluptatem accusantium doloremque laudantium, totam rem aperiam, eaque ipsa quae ab illo inventore veritatis et quasi architecto beatae vitae dicta sunt explicabo. Nemo enim ipsam voluptatem quia voluptas sit aspernatur aut odit aut fugit, sed quia consequuntur magni dolores eos qui ratione voluptatem sequi nesciunt. Neque porro quisquam est, qui dolorem ipsum quia dolor sit amet, consectetur, adipisci velit, sed quia non numquam eius modi tempora incidunt ut labore et dolore magnam aliquam quaerat voluptatem. Ut enim ad minima veniam, quis nostrum exercitationem ullam corporis suscipit laboriosam, nisi ut aliquid ex ea commodi consequatur? Quis autem vel eum iure reprehenderit qui in ea voluptate velit esse quam nihil molestiae consequatur, vel illum qui dolorem eum fugiat quo voluptas nulla pariatur?
Swoop411 is offline   Reply With Quote
Old 10-12-2003, 09:22 AM   #2
240_keyy
240_keyy's Avatar
240_keyy is an unknown quantity at this point
Send a message via ICQ to 240_keyy Send a message via AIM to 240_keyy Send a message via Yahoo to 240_keyy
what kind of mods do you have on your 240? start with that and we will go from there. If you have a question just ask, the worst that can happen is that you get flamed, but who cares?
Ask away, we will help.
There *is* a spoon...
240_keyy is offline   Reply With Quote
Old 10-12-2003, 09:52 AM   #3
Swoop411
Swoop411's Avatar
Old 10-12-2003, 10:19 AM   #4
240_keyy
240_keyy's Avatar
Make it so your BOV doesn't open at idle and then tune the boost controller. Also, you should be pulling between 18 and 22 mm/hg vaccuum at idle, so your boost guage must not be hooked up right. Run 10psi on street and 14 at track, not 17, that's bad
Old 10-12-2003, 06:40 PM   #5
Swoop411
Swoop411's Avatar
Old 10-12-2003, 06:51 PM   #6
240_keyy
240_keyy's Avatar
you will be able to boost a pound or two just by revving the motor, but unless your motor is under load you will ALWAYS be pulling vacuum. You have your guage hooded up wrong yo. Tee it off of the FPR signal hose.
