Old 08-04-2003, 04:17 PM   #1
four
four's Avatar
four is an unknown quantity at this point
Send a message via AIM to four
SR advice please! SR20DE w/ turbo
Sup
Just got a sr20de turbo'd
i beleive its the one that comes on the silvia j's and silvia q's
anyway...just wanted to know..this unit has the distributor ign. system. Should I swap out the igntion system and get the coil on plug system? there's a lot of deals right now on ebay that has the full harness w/ ignitor and coil system. all i need to do is get that, and the Crank angle sensor.
or, i can just use the distributor system, and use my stock ecu and harness (KA24DE) i've read that I can use the ka harness and ecu with the distributor system. What do you guys think?
I'll post pics of the motor/trans set in a few days. jsut wanted to know if there really was a big improvement on the coil on plug system vs. the distributor system.
thanks guys
four is offline   Reply With Quote
Old 08-04-2003, 04:28 PM   #2
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
stock KA ECU with SR distributor ignition??
ummm...no. you can get a TUNED ECU to work with an SR and distributor ign. The SR has a completely different computer.
But seeing as how I've never actually *done* this and people are flamehappy on this board these days...I might as well shutup
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 08-04-2003, 04:34 PM   #3
four
four's Avatar
Eric
Reason is, i have both ka and sr ecus. i;ve read on sport compact that the stock ka ecu can be used on the sr20de
that's what im asking. also, if you guys think i should change the igntion system from distributor to coil on plug system. sr20des come with distributor ign. system unlike the sr20det/
Old 10-12-2003, 02:20 PM   #4
eoscrx
eoscrx's Avatar
eoscrx is an unknown quantity at this point
take it to carluch
eoscrx is offline   Reply With Quote
