Old 10-10-2003, 12:07 PM   #1
redrps13
redrps13 is an unknown quantity at this point
question about s15 turbos
how much psi on a s15 turbo should put me close to 300hp? i just got my turbo on and im going to the dyno but i need an idea of where to set my boost conroller so i dont have to waste a bunch of runs.
redrps13 is offline   Reply With Quote
Old 10-10-2003, 02:10 PM   #2
nokeone
on strike three.
nokeone's Avatar
nokeone is making a name for him/her selfnokeone is making a name for him/her self
Send a message via AIM to nokeone Send a message via MSN to nokeone Send a message via Yahoo to nokeone
also depends on your other mods...a stock sr will require higher boost to acheive the same hp output that a modified sr can attain at less boost..
so it's all relative..
set it at 12psi, to be safe, and go from there...if you're looking to be thrifty a Dyno session may not be for you...it takes time to dial in a car..all cars are different..all react differently...i promise you yours will be unique..so advice you receive may be worthless..
good luck
panda; rockin your socks from the Bay to LA to SD, yay!
Pink GodziRa
nokeone is offline   Reply With Quote
Old 10-11-2003, 12:17 AM   #3
s156spd
s156spd is an unknown quantity at this point
Send a message via AIM to s156spd
boost for s15 turbo
12 is week i ran 12 daily at 275 to the wheels. 274 in torque. but thgen agin this was on the full s15 6spd swap. but the turbo is good till max boost at abotu 17-18lbs. start @ 15
s156spd is offline   Reply With Quote
Old 10-11-2003, 02:01 AM   #4
S15 Powered
S15 Powered is an unknown quantity at this point
Send a message via AIM to S15 Powered
Re: boost for s15 turbo
At 15psi on a stock motor it's only a matter of time til something fries, and at 17-18 psi that turbo is blowing hot air.
S15 Powered is offline   Reply With Quote
Old 10-11-2003, 09:52 AM   #5
s156spd
s15 turbo power
if thats what suits u. but i can tell u evry time i went to the track i was boosting 17-18 lbs all day and on the way home as long as i had race gas i did this alot and ran my car hard. ran 12.7 @110 @ 18lbs i pulled a 314 and 299 tourque. as for hot air dunno were your getting that info from. this is not true. even hevythrottle on there site is says this turbo's efficiancy is good to 15-18lbs.
Old 10-11-2003, 10:09 AM   #6
HaLo
from Canada, eh!
HaLo's Avatar
Re: Re: boost for s15 turbo
Untrue... I have an S15 turbo... I boosted 15psi daily for all summer with 18psi for drag racing... No problems whatsoever.
-> HaLo
Race Car: '98 E36 BMW M3
SOLD: 01 GPW Honda S2000
Old 10-11-2003, 10:24 PM   #7
FRpilot
FRpilot's Avatar
someone on fa dynoed 299hp and somewhere about the same for torque with s15 turbo. his car was tuned by secret services. man.. theres a lot of hardcore cars in fl.
FRpilot is offline   Reply With Quote
Old 10-12-2003, 01:52 AM   #8
S15 Powered
Re: Re: Re: boost for s15 turbo
Just keep runnin that setup and let me know what happens in another year or two.
Old 10-12-2003, 08:01 AM   #9
HaLo
from Canada, eh!
HaLo's Avatar
I did 11k km this year, with regular auto-x and drag racing. I tested my compression yesterday: 140-140-135-135. I don't believe that there is a problem. I've known people running 20 psi of simple T28 (I know it's not efficient) for 2-3 years and they had no problems. Now you're allowed not to believe me but this is a tried method and I'm confident this car will be running for years to come in this setup.
-> HaLo
Old 10-12-2003, 01:36 PM   #10
S15 Powered
Well, I can only hope that you're right cuz I also have an S15 motor with that very same turbo so if you're right and I'm wrong, I'll be a happy driver. However, it doesn't seem like a safe setup to run if I want to keep my car as healthy as possible.
Old 10-13-2003, 08:33 PM   #11
HaLo
from Canada, eh!
HaLo's Avatar
Just install some gauges and be sure to watch them. That's what I did.
I may also be wrong, but for the moment, it's still pulling hard. I've been running 11 psi daily though in the last few weeks (I don't feel like I need more power than that)
-> HaLo
Old 10-14-2003, 02:33 AM   #12
S15 Powered
Yea, I think i'll just run it at about 12-13 on a daily basis as soon as i get a boost controller. I might do a dyno pull at 17 once to see what's up
Old 10-14-2003, 12:14 PM   #13
taka
taka is an unknown quantity at this point
Send a message via AIM to taka Send a message via Yahoo to taka
what is an s15
taka is offline   Reply With Quote
Old 10-14-2003, 01:49 PM   #14
Silvia Wannabe
Silvia Wannabe is an unknown quantity at this point
the model after the s14 duh
I would definately recommend using the search button before posting like that again
Silvia Wannabe is offline   Reply With Quote
