Old 02-23-2010, 04:13 PM   #1
csimp3
csimp3 is an unknown quantity at this point
sr20det, hasnt been started in over a year, help
ok, i picked up a 91 240 today that has a sr20det swap, he said the car ran fine and was his daily till he picked up his new car, but it has been sitting for nearly a year. i put fresh gas and a new battery in it, cleaned the plugs, and im about to change the oil, but other than that, what should be done? it turn over stuff, but just wont fire, any ideas? thanks
csimp3 is offline   Reply With Quote
Old 02-24-2010, 01:54 AM   #2
R_G
R_G's Avatar
R_G is an unknown quantity at this point
check for spark, fuel, timing and compression.
R_G is offline   Reply With Quote
Old 02-24-2010, 02:49 PM   #3
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
It should be fine as long as its been under 5 years. take the valve cover off, pour oil over it, turn it by hand to get all oil flowing, and do what he said ^
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 02-24-2010, 11:50 PM   #4
csimp3
well got everything else working that wasnt due to a bad main alt fuse, im getting fuel and air, but still no spark. gonna try to chase it down with a voltmeter tomorrow, and suggestions?
Old 02-25-2010, 12:34 AM   #5
Drft_lock
Drft_lock is an unknown quantity at this point
Check the coilpacks against the valvecover for spark to see if they are firing.
Drft_lock is offline   Reply With Quote
Old 02-25-2010, 12:29 PM   #6
csimp3
i did, they are not firing
Old 03-01-2010, 01:43 PM   #7
beatlust
beatlust is an unknown quantity at this point
did u get this figured out??
beatlust is offline   Reply With Quote
Old 03-02-2010, 10:30 PM   #8
csimp3
no, i have still not figured it out, i had some power coming through the ignitor, but not 12 volts, and only had power when cranking the engine over. and im unsure if there is supposed to be power through it when the key is on, but not turning the engine over, or if its just supposed to have power when turning the engine over
