Old 11-02-2009, 01:45 AM   #1
chituntang
chituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nice
S14: Popping noise during slow turns
It starts to make this popping noise recently. This happens when I am driving really slow (almost rolling speed). It happens to both left and right side. I have done the following things to the front suspension:
New OE struts tops with KYB AGX and RSR springs
New Moog FLCA ball joints
I am planning to do the following:
Rebuild power steering rack
Tension rods
Thanks in advance
Jesse
BTW, does anybody knows if a fully loaded IS350 (I mean fully loaded like NAVI, heat/cold seats, like everything) has stock bigger wheels at the back? Looked at one today and:
Stretch tires running 225/40/18 front and back
Passenger front wheel has a dent
Any of the above would cause shaking? I am not talking about the steering wheel, but the ride is shaky. The steering seems fine.
chituntang is offline   Reply With Quote
Old 11-02-2009, 02:08 AM   #2
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
edited.........
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 11-02-2009, 08:03 AM   #3
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
yes on the IS350. stock wheels are 18x8 front and 18x8.5 rear...unless its AWD
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 11-02-2009, 10:21 AM   #4
S13Sauce
S13Sauce's Avatar
S13Sauce is an unknown quantity at this point
when u reinstalled the struts did you make sure the black cup on top was seated right on the springs? because i did mine on my old car and when i tirned the prings were poping around when i turned.
S13Sauce is offline   Reply With Quote
Old 11-02-2009, 10:41 AM   #5
Dazzla
Dazzla is an unknown quantity at this point
Yeah. It's either that or something is loose. I had the same problem with my coilovers when one of the perches wasn't fully tight.
Dazzla is offline   Reply With Quote
Old 11-02-2009, 11:27 AM   #6
!Zar!
!Zar!'s Avatar
Noise during turning would most likely come from:
Loose nut on the top of the coilover.
Loose camber bolts on the top of the coilover.
Loose tension rod bracket.
Bad lower control arm bushing.
If it's under braking then it's most likely a loose brake caliper.
Old 11-02-2009, 11:42 AM   #7
c72c
c72c's Avatar
Trader Rating: (25)
c72c is an unknown quantity at this point
Feedback Score: 25 reviews
also the tie rods
or mounting bolts from the strut to the spindle
make sure all the shyte is tight that you installed, friend of mine had the same problem you're havin, the top bolt to the spindle was loose and the pop was the wheel camber-ing.
c72c is offline   Reply With Quote
Old 11-02-2009, 12:34 PM   #8
chituntang
Thanks on the IS350 comment. That explains why the rear looks more stretch than the front.
As for my car, the strut tops were done at least a year ago. So I do not think it is the install.
Really need to study, but I guess I will do a little wrench before that...
I will check and see if all bolts are torque properly (brakes, tie rods, struts, and the control arms). And now come to think of it, it does make a funny sound when I brake...
Old 03-01-2010, 12:28 AM   #9
My 180 8 u
My 180 8 u's Avatar
My 180 8 u is an unknown quantity at this point
Might sound stupid but tighten your lug nuts. In my 240 I would here a thump at an even pace. It would sound as if the tire had a bad spot on it. So I tightened the lug nuts and it since then gone away. Hope this helps
My 180 8 u is offline   Reply With Quote
Old 03-01-2010, 12:32 AM   #10
GroundHog
GroundHog's Avatar
GroundHog is an unknown quantity at this point
sounds like your tie rod ends, or maybe something stupid lol
GroundHog is offline   Reply With Quote
Old 03-01-2010, 02:51 PM   #11
SoguRacing
SoguRacing's Avatar
check your alignment. could be the tread gripping the asphalt at low speeds.
Old 03-01-2010, 03:59 PM   #12
KA24sleeper
KA24sleeper's Avatar
KA24sleeper is an unknown quantity at this point
had the same problem on my hachi awhile back when i gave it new coils, i just had to tighten them down more and get new rod ends cuz they were cracking the old ones( yes they cracked, took out the end bold and there was a crack along the side of it)
KA24sleeper is offline   Reply With Quote
Old 12-16-2010, 01:39 PM   #13
mofeel
mofeel's Avatar
mofeel is an unknown quantity at this point
yea im having the same problem except mine will pull to that side. its mainly the left side popping n pulling. the steering wheel also turns with the pull.
mofeel is offline   Reply With Quote
