Old 03-13-2010, 05:43 PM   #1
mjr321
mjr321 is an unknown quantity at this point
Greddy turbo timer s13
i got an s14 sr in my s13 and im trying to wire up my turbo timer..anyone know which wire on the harness by color is the speed sensor and parking e brake sensor wires?
tryin to install this and i dont have the 240sx harness for the tt so any help would be appreciated like maybe a complete step by step?
mjr321 is offline   Reply With Quote
Old 03-13-2010, 08:15 PM   #2
Prez
Prez's Avatar
Prez is an unknown quantity at this point
your dash harness is still s13 correct?
Black - ground
green - 12 v ignition
blue - accessory
red - 12 v constant
search son...
"soft so you can't even enjoy it"
Prez is offline   Reply With Quote
Old 03-13-2010, 09:07 PM   #3
TheRealSy90
TheRealSy90's Avatar
Doesn't help that you didn't give him the colors for the ones he asked for...
Old 03-13-2010, 09:12 PM   #4
Prez
Prez's Avatar
completely my bad...first color is not a good way to solely tap into wiring... but
pin #52=Vehicle Speed Sensor(yellow/green) e brake is a ground just tap into brown wire off ebrake assembly.
Old 03-13-2010, 09:12 PM   #5
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
go buy this and be done with it simple plug and play.
ProjectSilvia Turbo Timer Harness 240SX '89-'94 - Turbo Timer Harness - ProjectNissan.com
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 03-13-2010, 09:17 PM   #6
Jhester
Jhester's Avatar
Jhester is an unknown quantity at this point
Send a message via AIM to Jhester Send a message via Yahoo to Jhester
If I am correct, that doesnt include the prewired vss and ebrake wiring. Given the ebrake is the easy one but wat color is the vss on the s13?
Jhester is offline   Reply With Quote
Old 03-13-2010, 09:19 PM   #7
Prez
Prez's Avatar
53 Y/G Vehicle Speed Sensor edited other post
no it doesnt... has its own harness
so hook up main harness and purple wire off of timer goes to vss yellow/green #52 wire
brown goes to ebrake assembly... you dont need it though for operation.... esp. if you dont always pull up your ebrake..
btw greddy has all this info on their site...
Old 03-14-2010, 07:49 PM   #8
Jhester
Jhester's Avatar
Excellent support triple.
Old 03-14-2010, 08:37 PM   #9
Prez
Prez's Avatar
i hate looking for stuff when i get a new part and all i wanna do is install and run with it already... haha so yea enjoy it. funny when old poeple flag you down..." sir your car is still on..."
Old 03-14-2010, 11:57 PM   #10
mjr321
So did you wire it up without the plug and play harness?
Old 03-14-2010, 11:59 PM   #11
mjr321
And that seems to ne the pinout for a stock ka24de s13 ecu my car is an s13 but has a Silvia s14 sr20det ecu labeled "wc".. I need the wires for that
Old 03-15-2010, 09:54 AM   #12
Prez
Prez's Avatar
this one is off innovate motorsports...
1993 - 1996 Nissan Silvia S14 SR20DET (Non European) ECU Diagram
Still #53 is VSS
what year is your motor... Vss is prob the same.... if not go down by manifold close to firewall there should a be a two wire connector. one of those wires in that connector is the signal for the VSS. i have a toggle in my center console so if i ever so happen to go past 100 mph and still wanna go i just flip the switch and kill the signal.(thats a S13 w/ S13 blacktop)
Thats a 1997-1998 S14 Sr20DET and vss is 101 my bad wrong diagram
Old 03-15-2010, 09:59 AM   #13
Prez
Prez's Avatar
1997 - 1998 Nissan Silvia S14 SR20DET ECU Diagram
Printable (PDF) version
Pin #
Name
Signal Type
2
Tachometer Signal
RPM
16
Mass Air Flow Sensor
Analog
17
Mass Air Flow Sensor Ground
Ground
18
Engine Coolant Temperature Sensor
Analog
19
O2 Sensor Signal
Analog
20
Throttle Position Sensor
Analog
21
Sensor Ground
Ground
29
Sensor Ground
Ground
32
Speed
101
Injector # 1
Speed
103
Injector # 3
Speed
110
Injector # 2
Speed
112
Injector # 4
Speed
116
Power Ground (Electronic Concentrated Control System)
Ground
Printable (_PDF) version
Pin #
Name
Signal Type
7
Tachometer Signal
RPM
26
Ground
27
Analog
28
Analog
29
O2 Sensor Signal
Analog
30
Sensor Ground
Ground
38
Analog
50
Power Ground (Engine Control Module)
Ground
53
Speed
101
Injector # 1
Speed
103
Injector # 3
Speed
110
Injector # 2
Speed
112
Injector # 4
Speed
116
Ground
Source:
http://www.innovatemotorsports.com/r...ecu_pinout.php
