Old 03-21-2010, 05:50 PM   #1
ae86_4life
ae86_4life is an unknown quantity at this point
CA Bee-R Rev Limiter Help!!!!1
alright i just bought a bee r rev limiter from a member on here and i cannot get it to work properly. i have it hooked into power ground cas 180degree and cas 1 degree as well. it is all wired according to about 5 different forums. but it still will not work. i even tried switching the green and yellow wires around. oh and this is on a ca18det. i am really confused and would just like to get this thing working right. any help would be appreciated.
ae86_4life is offline   Reply With Quote
Old 03-21-2010, 10:09 PM   #2
repda916
repda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymore
well how does it not work?
repda916 is offline   Reply With Quote
Old 03-21-2010, 10:58 PM   #3
ae86_4life
i had it hooked up according to the bee r website and it apparently has the green wire and yellow wire backwards. when i first tried this the car would not even start. i researched this and found it have been a very common problem. so i hooked up the wires opposite the instructions and the car started but the light on the bee r came on. and stayed on but did not function. it just lit up. so then i went back to check the instructions again and realized that the two wires the green and yellow wires were to go to the rpm signal and ignition wire. so i hooked up the yellow wire to the tach signal and the green wire into the cas 180 wire. when i did this the light on the bee r turned on at the desired rpm and seemed to pop a litle bit but would not bounce at the designated rpm, hopefuly someone else has had this problem and can help me out. thank you
Old 03-21-2010, 11:57 PM   #4
HPballer76
HPballer76's Avatar
HPballer76 is an unknown quantity at this point
maybe im just really tired but didn't you just answer your own question?? you said that the green and yellow need to go to the rpm signal and ignition wire then you say you hooked them to the rpm signal and cas. wouldn't that be the problem??
HPballer76 is offline   Reply With Quote
Old 03-22-2010, 10:38 AM   #5
ae86_4life
the bee r website says to hook the wires into the cas 180 and cas 1 degree wires. i guess the cas 180 throws out an rpm code and the cas 1 degree wire acts as a ignition wire cause if the ecu doesnt read cas readings the ignition wont fire. i just was hoping i made some stupid mistake wiring i t up.
