Old 03-23-2010, 12:42 AM   #1
K20a2ivtec
K20a2ivtec is a well-known jackass
Rb25det part out 240z swap
PARTS HAVE BEEN PRICE WITH NO SHIPPING PRICE INCLUDED
I will sell the compete package for 2900 firm
Selling because I got a 2jz
RB25DET NEO 6 bottom end (oil pan not included, has RB26DETT stock rods) $500
RB25DET NEO 6 head (has RB20DET intake cam, cam gears not included) $250
My turbo set up (stock turbo manifold moded for external wastegate with a synapse 50mm wastegate on a ebay t3/t4 70 trim turbo .63 stage three rear, had full boost of 20lbs by 2700 rpm and pulled hard all the way, no shaft play) $450
RB25DET ARP head studs, and a tomei 1.2mm head gasket (head studs not sure if they will work with both neo and non neo heads, but they where in my neo, head gasket was used once, could still use it...) $100
HKS cam gears and timing belt (had an oil leak so the belt is now black.. and the cam gears are a lil faided, have 2000 miles on them) $175
Jun style intake manifold (will come with jyc top feed rail with 440cc injectors and a q45 throttle body and A.N. fittings for the vacum lines) $600
GTS R33 transmission (grinds 4th but didnt have a prob gettin into gear and never poped out of gears) $500
GTS R33 flywheel and spec stage 3.5+ clutch (has 2000 miles on it) $350
Starter (I have 2 of them) $50 each
RB26DETT eagle rods and je pistons (dont know the miles on them, but they look in good condition, pistons are .20 over) $500
Mchinney motor mount kit for RB into 240z (comes with oil pan moded to fit 240z, motor mounts, trans mount, and drive shaft) $400
R34 NEO 6 ecm stuff, no wiring harness $150
i have pics, lemme know what you wanna see
K20a2ivtec is offline
Old 03-23-2010, 07:59 AM   #2
numbnuts240
numbnuts240 is an unknown quantity at this point
pm'd about the mount set-up.
numbnuts240 is offline
Old 03-23-2010, 10:34 AM   #3
DeLorean
DeLorean is an unknown quantity at this point
Mount kit
VERY interested in the mount kit, I have PMd you, let me know if you received it.
DeLorean is offline
Old 03-23-2010, 10:53 AM   #4
ninety1two40
ninety1two40's Avatar
ninety1two40 is an unknown quantity at this point
Send a message via AIM to ninety1two40
Willing to sell just the stock manifold with wastegate?
SlideNY.com
ninety1two40 is offline
Old 03-23-2010, 11:02 AM   #5
sicner
sicner is an unknown quantity at this point
PM'ed about turbo lines
sicner is offline
Old 03-24-2010, 08:45 PM   #6
K20a2ivtec
bump numbers 1
Old 03-24-2010, 10:30 PM   #7
silverarrow27
silverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud of
Sucks, my brother was up that way this past weekend. Could have had him pick up the rb mount kit for me. Would you pm me a shipping quote to 92220 anyway if you're willing to ship? Curious is the oil pan for a 200zr or stock oil pan modded to fit? Custom drive shaft or is it McKinney?
1989 240sx XE|2002 Frontier SC CC LB 4wd|2011 Pathfinder LE V8 4wd
silverarrow27 is offline
Old 03-25-2010, 08:15 AM   #8
racerx2k1
460
racerx2k1's Avatar
http://zilvia.net/f/wheels-tires/109...-ask-pics.html
racerx2k1 is offline
