Old 03-29-2010, 08:51 AM   #1
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
SoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud of
Feedback Score: 36 reviews
S13 S14 240SX KA SR Single and Dual, Parts Galore, New and Used!
stuff for sale pictures by brsilvia - Photobucket
Check above link for pics....
95-98 Nissan 240SX S14
1- Driver Door, gutted,dented, repairable, custom gold($30)
1- Passenger door, Black, some dings, complete($50)
1- Rad Shroud/lower/sides($15)
1- OEM Electric Fan ($20)
2+- Clutch Fans($10 ea)
1- Full Fiberglass Interior, needs refinished($350)
1- Gas Tank($30)
2- Brake Master Cylinders complete with Boosters($50 ea)
1- Tanabe Rear Subframe Bushings, New($80)
1- R & L OEM Rear upper arms($20)
1- R & L OEM Rear Struts, good($30)
1- R & L E-Brake Cables OEM, good($20)
1- Front R & L OEM Calipers 55k, Rotors, pads hardware ($100 obo takes all)
1- Rear R & L OEM Calipers 55k,C/D Slotted Rotors, pads hardware (SOLD)
1- Misc Blue Interior Peices, ask and I may have, Panels, Trims, ect.....
1- Misc Window trims, door trims, ect
1- Cowl Panel($20)
1- Blower Motor assembly($30)
1- Bumper Light, Driver($10)
1- Complete rear seat, Black with colored patterns, SE model($50)
1- Some and I mean some Misc black interior peices, no dashes or big panels, maybe some trims...
1- Carbon Fiber Subwoofer Enclosure for S14 Trunk, fits in wheel well, fits a 12" Kicker L7, scratch and hole, uber light!($50)
2- Complete OEM Airbox assembly, all plastics, lot of doubles, and triples, so I will sell whatever peices you may need!
1- KA Alternator ($50 obo)
1- Starter ($50 obo)
1- P/S Pump and bracket($50 pump only-$60 with bracket)
2- P/S Resivoirs ($10)
3- KADE Front Covers top($20ea)
1- KA Oil Pump($20)
1- Timing chain set, low miles($30)
(Any KA Part you may need Im sure I have a few of them, I boxes of accesories and internals, bolts, the hard to find lil things!)
1-sandwich plate(beteween tranny and block($20)
1- Misc AC Parts, lines, brackets, compressors, ect...
4- Pilot Bushing's , Brand New($10 ea)
1- ka flywheel, resurfaced ready to go! (resurface alone was $40)!($75 obo)
89-94 Nissan 240SX S13
1- SOHC MAFS(will work for SR($40))
1- OEM Front Brakes, R&L, rotors, calipers, pads, great working condition, painted red, very low miles($100 obo complete)
1- Ton of KA24DE Parts! TONS! (please refer to above at bottom S14 list) Ask and Ill let ya know, I prob have it!
1- Also a handful of SOHC KA24E parts, Brackets, Alternator, Starter, all accesories,ect
1- OEM Airbox assembly, tubing, ect($25....)
1- 5 Speed Transmission(sold)
1- 5 Speed sandwich plate(beteween tranny and block($20)
1- Fuel top hat, tapped and wired to run dual walbro fuel pumps to get you over that 500 hp!!!($20)
2- Clutch Fans($10 ea)
1- Body Kit- Vader/Shogun Style Sides and Rears Only, 1 side skirt broke in half, NO FRONT BUMPER($30)
1- Misc Black interior pc's, door sills, kick panels, center console,ect .....ask, i may have
4- Set of 4 SE wheels OEM SIlver Finish, tires are rideable(think someone stole these)
2- Tear Drop style rims with tires(stolen too I beleive, aluminum scrappin rednecks)
1- PS resivoir($15)
1- P/S Pump($40)
1- AC Compressor(1 ka24e, and 1 ka24de w/brackets, ect....)
1- cold air intake(polish)(sold)
1- cold air intake filter(red/like new)(sold)
S13 SR20DET
(Have Pretty Much a Complete Build with lots of goodies to part out! Taking diff Route! Will update accordingly!)
Fully Built Head with HKS Step 2 264 in/ex cams, HKS adj cam gears, BC valves, JWT valve guides, all oem valve seals, ect, BC valve spring kit, new rocker arms oem, Phase 2 ras, all lifters great shape, head was deburred and ported/polished. Head and components only have roughly 2-3K. Head was a Brand new oem nissan(very rare) as well as all components were brand new inside! Everything is pretty much clean as day it went in. So for this complete head I would ask $1500 obo!!! I will part this head out, but would rather sell as a whole complete as I built this all to work with eachother! Ready to ship, will work with stock bottom end also! Ill even throw in a Brand new Cometic Head Gasket!!!
Ill be keeping one of the heads, So if anyones interested, LMK ASAP as I am unsure which route im keeping. Looks like Im going with the below build, just trying something different. Someone should really take advantage of the above head, cause thats about hallf of what I have in it after all machining, labor, and parts!
Fresh Port Polish Head with BC valve guides(brand new)($600 obo)
BC Valves(brand new)($280 obo)
Jim Wolfe C1 Cams(brand new)($550 obo)
Comp Valve Springs(brand new)($180 obo)
Crower Titanium Retainers (brand new)($200 obo)
(ALL BLUE ILL PROBABLY BE KEEPING NOW)
Greddy oil pan(3k, like new, baffles included!) ($275 OBO)
CP Pistons 86.5mm(Used 3k miles(1 is lil nicked,in a spot hat will not effect performance)($300 obo)
3 Eagle Rods($150 obo, $50 ea.)
(Rods still attached to pistons, take the whole set for $400 obo)(1 eagle rod and a set of rings would complete the set like new)
Cometic Head Gasket(brand new) ($80)
Engine Mount Brackets ($100 obo)
Engine Mounts(used, can be used with KA also) ($30)
Alternator (sold)
Alternator Bracket($50 obo)
P/S Bracket($50 obo)
Starter ($100 obo)
Coil Packs($100 obo)
Coil Pack Harness($25 or will include with coils as package deal)
AAC Idle Air Control($100 obo)
Cam Angle Sensor($150 obo)
Oil Pump 3k use($100 obo)
OEM Valves/Springs/Retainers($50 obo)
OEM Timing Chain Guides/Chain Very minimal wear if any...($75 obo)
OEM Cam Gears Great shape($50 obo)
OEM Water Pump($30)
OEM Valve Stem Seals New($50)
OEM Rocker Arms New x8($240 all 8($30ea)
Head Bolts($25 obo)
Main Bolts($25 obo)
Lower Harness($50)
Wiring Harness plug-n-play S13 to S14 chassis(brand new)($300 obo)
Valve Cover(powdercoated charcoal grey)($100 obo)
Transmission(5speed)($250 obo)
Circuit Sport Short Shifter (sold)
Greddy Oil Sandwich Adapter w/3 ports ($50)
Manifold Studs(new-$30, used $15)
OEM Multi Layer Exhaust Manifold gasket, pressed once, great shape($25)
Oil Strainer Good shape($20)
Tranny Bolts($25 obo)
So many extra nuts and bolts for the SR, anything you may need, I probably have, please check my photobucket album!
1- OEM MAFS pigtail($10)
1- Aluminum Cold Pipe for Greddy Intake and FMIC kit, New(sold)
2- AC Compressors, with Brackets, ect
1- Misc turbo items, oem actuators, lines, ect...
1- Wiring, 1 complete harness S13 redtop into S14 Chassis(wired with Z32 mafs plug, and different injectors, think 550's,not stock injector plugs.)($200 obo)
1- Misc wiring, plug ends, ect....
1- OEM Fuel rail, complete with injectors and fpr,used, good working order!(sold)
1- OEM Flywheel, complete with used bolts! Nice shape(always recomend resurface though)($50)
1- Misc items, rare bolts, sensors, lil things, I may have, just ask....
New Items Added, all S13 SR from same build teardown, just found in box I forgot about, PLease view above links for pics!!!
1- P/S Pump, and pulley, sandblasted , Mint ($75 obo)(have bracket listed above)
1- Intake Manifold OEM, Sandblasted, Mint, Port and Polished Runners($100obo)
1- OEM Fuel Rail, with Caps and fuel pressure regulator, no injectors($40obo)
1- Water Lines on side of block, complete with sensors, ect($75 obo)
1- Throttle Body with TPS, sandblasted, mint ($50 obo)
I have alot of 240 parts among other parts, So if you need something, just ask!
Call/TEXT 330-432-4871
PM me with all serious inquiries!
I can get pics of anything needed,but Im not gonna waste time taking pics for lowballers. And if the item says New, I promise you it is NEW! Most likely in original box whatever it came in!
Thanks,
Brian
Hatas Keep Hatin, I Keep Rollin!
Last edited by SoloSilvia; 04-08-2010 at 02:05 PM.. Reason: Added Items and pics also in photobucket link 100+!
SoloSilvia is offline
Old 03-31-2010, 08:00 AM   #2
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
Sold Items:
-SR Alternator (still have bracket)
-Walbro Pump w/kit (still have one left)
-Circuit Sports Short Shifter
-Greddy Sr Cold Pipe S13
-S13 MAFS
-S13 Dipstick & tube
-KADE CAI & Filter
Also up for sale now!!!
S13 SR Head fully built with HKS Step 2 264 in/ex cams, HKS adj cam gears, BC valves, JWT valve guides, all OEM valve seal, ect, BC valve spring kit, new rocker arms oem, phase 2 ras, all lifters great shape, head was deburred and ported. Head and components only have roughly 2-3K Miles. Head was a Brand new OEM Nissan(very rare) as well as all components were brand new inside! Everything is pretty much clean as day it went in. So for this complete head I would ask $1500 obo.
Old 04-04-2010, 09:15 AM   #3
My$800S14
My$800S14's Avatar
My$800S14 is an unknown quantity at this point
s14
do you have an s14 manual transmission crossmember and mount if so how much shipped to 32837?
My$800S14 is offline
Old 04-04-2010, 10:16 AM   #4
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
Yes I do PM sent!
Old 04-04-2010, 12:09 PM   #5
driftpolice
driftpolice is an unknown quantity at this point
id like that oil pan please
driftpolice is offline
Old 04-04-2010, 10:22 PM   #6
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
Ok, I sent you a PM, Let me know what ya want to do.
Old 04-05-2010, 04:25 PM   #7
AhmadG
AhmadG is an unknown quantity at this point
Hey, do you have a KA24DE fuel rail with working, non-leaking injectors? I'm trying to diagnose why my car is running weird, eliminating the injectors will be a good idea.
Also if you have a MAF that worked perfectly, also for an S13 KA24DE, let me know.
I am in Toronto, Canada, and willing to pay for shipping. Thanks.
AhmadG is offline
Old 04-05-2010, 08:40 PM   #8
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
Sorry I do not have any of those items.
Old 04-07-2010, 06:20 AM   #9
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
Something came up, I may have a 95 KADE to part out in the next week or so. If so, theres all the parts you need, I can PM you and let you know!
Thanks,
Brian
Old 04-08-2010, 01:40 PM   #10
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
s13
I found a box of SR parts I knew I had but overlooked it! I added the pics to the first photobucket sale link on top my first post. And the decriptions in the bottom of parts in first post. EVERYTHING IS OBO!
Old 04-08-2010, 03:58 PM   #11
stealthy_240
stealthy_240 is an unknown quantity at this point
check your pms
stealthy_240 is offline
Old 04-08-2010, 04:47 PM   #12
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
All PM's Replied!!!
Old 04-09-2010, 01:37 PM   #13
The Elite
The Elite is an unknown quantity at this point
what size is the Cometic Head Gasket??
The Elite is offline
Old 04-09-2010, 02:15 PM   #14
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
88mm bore x 0.040"(1.02mm) thickness
This is probably the most bought size from cometic for this engine.
Would be great for any stock setup(86mm) & up to 87mm Bore Block. With Minimal to no shaving of head or block.
Old 04-09-2010, 02:49 PM   #15
racerx2k1
460
racerx2k1's Avatar
Originally Posted by SoloSilvia View Post
Sold Items:
-S13 MAFS
-KADE CAI & Filter
Yes I do PM sent!
All PM's Replied!!!
racerx2k1 is offline
