Old 04-01-2010, 10:02 PM   #1
JacobT
JacobT's Avatar
JacobT will become famous soon enoughJacobT will become famous soon enoughJacobT will become famous soon enoughJacobT will become famous soon enough
Slight throttle running lean
Stock S14 SR running 10psi and full 3" exhaust, a walbro 190 fuel pump and brand new 300zx fuel filter.
Under slight throttle the car runs stupid lean. Like 15.5-16s AFR. The car will build a bit of boost but wont move until it starts to reach the higher RPMs. When I push in the clutch the car sometimes wants to die/does die and tends to idle on the lower side. Did a boost leak test, couldn't hear/see anything leaking. I don't know what is causing this lean condition. Spark plugs look normal.
Any ideas? o2 sensor?
1995 Nissan 240SX
JacobT is offline   Reply With Quote
Old 04-02-2010, 10:21 AM   #2
s13 drifta
s13 drifta's Avatar
Trader Rating: (105)
s13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enough
Feedback Score: 105 reviews
I am dealing with the same problem right now. Even on slight throttle my a/f ratios jump up to 16-17, when I give it WOT it will bog and hesitate.
I have tried cleaning my MAF, new coolant temp sensor, checked timing, new plugs (bkr7eix-11), new fuel filter, tried a stock wastgate, new intercooler, new coulpers and clamps, no boost leaks, and my fuel pressure is at 40psi and climbs with throttle. Im going to try a new maf and see if that changes anything. Its getting rediculous and Im running out of ideas.
PM me for s13 or s14 parts!
s13 drifta is offline   Reply With Quote
Old 04-02-2010, 07:02 PM   #3
steve shadows
steve shadows's Avatar
What is your Fuel Pressure like?
Check it at idle, I suggest running at least 38-42 psi with the vacuum hooked up
Like Me on FaceBook !
Old 04-03-2010, 01:57 PM   #4
Hashiriya415
Hashiriya415's Avatar
Trader Rating: (22)
Hashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enough
Feedback Score: 22 reviews
unplug the o2, it's gonna run rich by default.
Hashiriya415 is offline   Reply With Quote
Old 04-06-2010, 09:27 PM   #5
JacobT
JacobT's Avatar
I did this and the car ran leaner all the time?
1995 Nissan 240SX
Old 04-07-2010, 06:58 AM   #6
jspaeth
jspaeth's Avatar
IF you guys are on stock ECU, I am not sure what to tell you.
If you are on a standalone, you can alter injection values based upon rate at which the throttle is being depressed.
...I know this because conincidentally, I was just reading about this for like 4 hours on the RX-7 PowerFC forums....it is a common issue to lean out when you rapidly tap the gas pedal
Daily driven
Old 04-07-2010, 10:25 AM   #7
s13 drifta
s13 drifta's Avatar
Im running a stock ecu, I think my problem is in my wiring. I just bought a brand new harness, so I will let you know how it works and if it fixes my problem.
Old 04-07-2010, 01:44 PM   #8
fullthrottle
fullthrottle's Avatar
fullthrottle is an unknown quantity at this point
Flow test injectors? Swap MAF with a friends good running car? These are the things I would try.
fullthrottle is offline   Reply With Quote
Old 04-08-2010, 09:22 PM   #9
Hashiriya415
Trader Rating: (22)
When you unplug it, the ECM runs rich by default. Could it be that your o2 wire is spliced somewhere and now your ECM sees over the 500mv so it leans the mixture.
