Old 05-01-2010, 02:04 AM   #1
mazersx
Banned from the Marketplace
Trader Rating: (32)
mazersx is an unknown quantity at this point
Feedback Score: 32 reviews
Send a message via AIM to mazersx
Arrow 89-98 Nissan 240SX part out S13 and s14 SE AND BASE MODEL 5 lug, power, & much more++
***Complete part out of Nissan 240sx S13 and s14 s15 Silvia front ends***
Send me a PM OR leave a message Here.
I have many more parts that aren't listed..
S13 = 1989-1994
S14 = 1995-1998
S15 = 1999-2002
Exterior: (**Front ends, Bumper, Fenders, Hood, Doors, Rear quarter panel, Rear bumpers**) s13-s14-s15
S13 Front clip Aka Radaitor Support with Apron $120 obo 89-94 NO FRAME DAMAGED out of a 1991 se
S14 front clip aka radaitor support with apron $200 95-98 NO FRAME DAMAGED out of a 1996 se
Headlights
pop up S13 headlights $40
95-96 S14 zenki headlights no broken tabs $200
89-02 S15 Silvia Headlights $600 No broken tabs
Fenders (fender linner, metal fender, fiberglass, bracket, screws,)
89-94 Driver side Metal fenders $50 passenger $20 has dent
95-96 driverside fender $80 oem green passenger fender $20 has dents
95-98 s14.5 Fender fiber glass driverside only $20
95-98 s14.5 Converison Fender fiber glass Vent 20mm only $150 obo
S13 GOOD CLEAN fender linner - $20 each
s14 fender liners all around with bottom guard $50 no damaged
Exterior -
Rear metal quarter panel 89-94 rear hatchback $80 pick up only driverside
Rear metal quarter panel 95-98 rear $200 pick up only driverside and passenger
Rear quarter panel WIDE BODY B-Magic Aero 30mm 95-98 FRP FENDER $250 obo CLEAN
Hoods (Fiberglass, oem metal, carbon fiber)
89-94 s13 pop up headlight hood 240sx $40
95-96 green zenki hood $150 obo
Rear trunk (glass, hatchback, Trunk lid)
sunroof glass no RUST OEM NISSAN 95-98 $200
89-94 clean wingless coupe trunk $100 obo
95-98 wingless trunk s14 $100 obo
95-98 oem peral white 1996 se trunk with spoiler $150
95-98 oem Green/blue se trunk with spoiler $150
Bumpers (bumper cover, metal bumper support reinforcement, foam)
s15 89-02 Front bumper $40 fiberglass has minor cracks Spec r replica
91-94 240sx Pop up headlight, Chuki Front bumper with SE LIP $150
89-94 Rear Coupe/convertible bumper Clean $80
89-94 front $20 or rear bumper support $20 each
S13 240sx bumper support foam $20
Jdm zenki bumper $200 No broken tabs.. Direct bolt on to 95-96 usdm car
USDM ZEnki bumper $100
ZENKI BUMPER/HEADLIGHT RETAINER CLEAN $75
Tail Lights
d-max style LED 180sx tail light $200 obo left and right (hatchback)
89-94 tail light $100 a set! OEM obo coupe, convertible, hatchback
95-98 S14a Kouki Complete TAIL-LIGHT $350 obo
Doors (motor, window, switches)
89-94 clean pasenger door with manual tinted windows - $100 complete clean clean white paint
89-94 Power windows Doors Complete - $300 a set complete door and harness, motor/ regulater/ tinted glass included Mirror
89-94 driver/passenger side mirror - $40 each power or manual
95-98 driver/passenger side mirror - $40 each
Interior (*Seats, interior panels, arm rest, center piece, dashboard, etc**)
89-90 single cluster $60
95-98 white face cluster SE ~114k $200, ~162k $130
97-98 kouki base model cluster $80 ~175k
Clean black cluster trim $30
95-98 Arm rest $40 8 out of 10
Nissan 240sx 1989 - 1994 Hatchback, Convertible, Coupe
A/C CLIMATE CONTROL - 89-94 $30 95-98 $50
89-94 OEM coupe quarter window glass - $80 each obo
hatchback rear black quarter panels - $30 each or $50 for both
89-98 Glove box $20
Nissan 240sx 1995 - 1998 Zenki, Kouki S14a
Door Panels -$50 a set
rear black quarter panel - $40 for both (interior)
Airbag Driverside and passenger r - $200 or 150 each
passenger side no cracks 1/4 quarter panel glass- $30
automatic gear shifter - $20
Internals: ( **Engine, Transmission, Brakes, Suspension, Control arms, Axle**)
s13 abs brake module/system $40 no problem whatsoever..
Complete 5 Lug Conversion $500 fits all year 1989-1998
Brake System
- - - 89-98 S13 Stock Front brake caliper with brake pad $25 each or $40 for both
- - - 89-94 Rear caliper $40 each. GOOD SEAL NO LEAKS!l
- - - Front 180sx big piston caliper $100 pair WITH 4 lug ROTOR
- Engine and Transmission
1996 SE 114k Clean engine Low mileages complete swap with auto tranny $700
1995 SE 162k blown headgasket complete swap $550 complete swap with auto transmission
1990 Sohc complete engine swap with bad head $200 with auto transmission
1990 sohc ~129k running health engine no leaks $450 motor only.
NEW Delrin Stiff Motor Mounts KA/SR Direct bolt on - $100 A SET
91-94 Automatic Transmission with only ~73,xxx $200
89-90 KA24E Clutch + Flywheel kit $80
89-90; 91-94 single cam 240sx stock header - $30
89-98 starter $50 ( working condition can go with you to autozone to test it out.)
91-98 twin cam header shield - $20 off a s14 1995
91-94 S13 dohc down pipe weld to your exhaust- $20
MAF (mass air flow sensor) SOHC 89-90 $60 , S14 97-98 $200
[SIZE="4"- Engine and Transmission[/size]-Front + Rear Suspension
[SIZE="4"- Engine and Transmission[/size][/size]
89-94 Apexi Coilovers N1 Nearly NEW $1200 obo ~300 miles
89-94 Teins Drift Spec Coilovers $800 ~11,000 miles
S13 subframe clean $100 ; S14 $150
95-98 $130 each ,89 -94 open diff aka 3rd member, pumkin COMPLETE $80 each
89-98 s13, s14 6 bolt axle $35 each
s13 or s14 Stock shocks and spring $150 obo Complete front and rear.
89-94 s13 rear control arm $50 each s14 $100 Each
s13 or s14 traction arm, toe arm, camber arms - $20 each.
s13 hub+spindle - $40 each side.or $150 for complete
s13 front lower control arm -$35 each
s13 front/rear sway bar - $20 each
Exhaust System
OEM CAT $140
Aftermarket cat converters $20
89-94 Coupe, fastback, hatchback, convertible Rs-R GT-2 Full catback $350. DIRECT BOLT ON OEM SETTING
Donuts/ Spare $20 each.
Stock steelies - $20 each (tires will need replace)
rolling shell with paperwork $800. Tag expired may 2010.
mazersx is offline
Old 05-01-2010, 03:08 AM   #2
dOMEmE
dOMEmE's Avatar
dOMEmE is an unknown quantity at this point
is the s13 OEM sunroof?
Chupas!
dOMEmE is offline
Old 05-01-2010, 03:35 AM   #3
PIN GIO 2
PIN GIO 2's Avatar
PIN GIO 2 is an unknown quantity at this point
Send a message via AIM to PIN GIO 2
trade camera canon 40d?
PIN GIO 2 is offline
Old 05-01-2010, 03:41 AM   #4
YdaSoL
YdaSoL's Avatar
YdaSoL is an unknown quantity at this point
how bad is the dent on the s13 89-94 passenger fender? lmk pm me
YdaSoL is offline
Old 05-01-2010, 09:26 AM   #5
mazersx
Trader Rating: (32)
yes, are you looking for the glass or just the cover?
Originally Posted by PIN GIO View Post
2 trade camera canon 40d??
no, thank you!
it need some work... I can provide you with pictures if you like.
mazersx is offline
Old 05-01-2010, 12:02 PM   #6
s13xturbo
s13xturbo is an unknown quantity at this point
I saW this on craigslist, horrible prices haha
s13xturbo is offline
Old 05-01-2010, 12:59 PM   #7
dOMEmE
dOMEmE's Avatar
im looking for the locking latch...not the one on the window the one on the car.
Chupas!
dOMEmE is offline
Old 05-01-2010, 01:58 PM   #8
mazersx
Trader Rating: (32)
If the price is so good, I wouldn't have them for those who are in need
mazersx is offline
Old 05-01-2010, 03:00 PM   #9
keistyle
keistyle's Avatar
keistyle has a reputation beyond reputekeistyle has a reputation beyond reputekeistyle has a reputation beyond reputekeistyle has a reputation beyond reputekeistyle has a reputation beyond reputekeistyle has a reputation beyond reputekeistyle has a reputation beyond reputekeistyle has a reputation beyond reputekeistyle has a reputation beyond reputekeistyle has a reputation beyond reputekeistyle has a reputation beyond repute
Send a message via AIM to keistyle
I need a rear coupe bumper (white or red preferred).
And a drivers side coupe tail light.
Lmk, thanks!
Tacoheroi.com
keistyle is offline
Old 05-01-2010, 07:28 PM   #10
mazersx
Trader Rating: (32)
i have a white coupe rear bumper but its not really oem white.
coupe tail light driverside $40
mazersx is offline
Old 05-01-2010, 11:28 PM   #11
s142jzkillav10
s142jzkillav10's Avatar
s142jzkillav10 is an unknown quantity at this point
Send a message via MSN to s142jzkillav10
what shell for 800 ?? s13 s14
s142jzkillav10 is offline
Old 05-01-2010, 11:32 PM   #12
mazersx
Trader Rating: (32)
the white one is $1000. green one is $800 all clean title.
mazersx is offline
Old 05-01-2010, 11:40 PM   #13
NINJASPY
NINJASPY is on a distinguished road
what color is the s14 wingless trunk? I need black.
NINJASPY is offline
Old 05-02-2010, 12:47 AM   #14
Waruiko420
Waruiko420's Avatar
Waruiko420 is an unknown quantity at this point
yo mazerx,
do u have a S13 1992 driver and passenger side mirrors (manual)?
Waruiko420 is offline
Old 05-02-2010, 09:24 AM   #15
mazersx
Trader Rating: (32)
sorry no black wingless trunk at least not in good condition paint... Everyone else got PMed
mazersx is offline
Old 05-02-2010, 09:35 AM   #16
DFWZenki
DFWZenki's Avatar
DFWZenki is an unknown quantity at this point
Interested in Fender liners all around for a S14. Do you have any pics of these? THanks! PMed you.
DFWZenki is offline
Old 05-02-2010, 12:02 PM   #17
menace88
menace88's Avatar
menace88 is an unknown quantity at this point
So, the wingless trunk is black?
Also what color is the 95-96 driver side fender?
menace88 is offline
Old 05-02-2010, 02:47 PM   #18
iRockairjordan
iRockairjordan is an unknown quantity at this point
all for for 89-94 s13 hatch
s13 subframe pics? how much shipped? front bumper chuki with lip how much shipped? how much just for lip? front fenders? condition? pics of all please lmk if you can ship and how much to 84120
iRockairjordan is offline
Old 05-02-2010, 04:38 PM   #19
mazersx
Trader Rating: (32)
sorry IRockairjordan.. THOSE ITEM ARE TOO BIG FOR SHIPPING!!
Menace88 yes wingless is black but faded.
Driverside fender is green.
mazersx is offline
Old 05-03-2010, 03:57 AM   #20
Rust.E
Rust.E is an unknown quantity at this point
any pics of the 89 fenders?
Rust.E is offline
Old 05-03-2010, 07:24 AM   #21
mxexux
mxexux's Avatar
mxexux is an unknown quantity at this point
hey can I see a pic of the back end of the white shell? Also, how complete is it? It sounds like you are parting everything out that is in it...
mxexux is offline
Old 05-03-2010, 08:04 AM   #22
S14Driftr91
S14Driftr91's Avatar
Trader Rating: (26)
S14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to all
Feedback Score: 26 reviews
how much would you want for the zenki hood shipped to 12590. its a long shot but im almost desperate lol
www.allthingsproper.com
S14Driftr91 is offline
Old 05-03-2010, 12:27 PM   #23
mazersx
Trader Rating: (32)
sorry no shipping on big heavy items!!
The white shell is up for $1000 after 5 lug is taken out.
Pmed for more info? if you guys are serious.
mazersx is offline
Old 05-03-2010, 01:21 PM   #24
marshallpre1
marshallpre1 is an unknown quantity at this point
Any A/C related stuff? I have an S13 with RB25DET and I need to install A/C lol
Thanks
marshallpre1 is offline
Old 05-03-2010, 01:30 PM   #25
Snake123
Snake123 is an unknown quantity at this point
my name is Isaac and lm very interested in buying the s13 right rear control arm! HIT me up My cell# Is 310-849-8862
Snake123 is offline
Old 05-05-2010, 02:00 AM   #26
IIxOATxII
IIxOATxII is an unknown quantity at this point
Send a message via AIM to IIxOATxII
are the donuts or steelies 5 lug ? pm me
IIxOATxII is offline
Old 05-05-2010, 04:50 AM   #27
s14kozenki
Trader Rating: (26)
s14kozenki is an unknown quantity at this point
read replies more carefully... ty
s14kozenki is offline
Old 05-08-2010, 01:44 AM   #28
slamn240
slamn240 is a jewel in the roughslamn240 is a jewel in the roughslamn240 is a jewel in the roughslamn240 is a jewel in the roughslamn240 is a jewel in the roughslamn240 is a jewel in the roughslamn240 is a jewel in the roughslamn240 is a jewel in the rough
i like that white one. pm sent
slamn240 is offline
Old 05-08-2010, 02:32 AM   #29
mazersx
Trader Rating: (32)
$1000 for the white shell.. got the paperwork in hand.
mazersx is offline
Old 05-08-2010, 07:57 PM   #30
Waveous72
Waveous72's Avatar
Waveous72 is making his/her stupidity well-knownWaveous72 is making his/her stupidity well-knownWaveous72 is making his/her stupidity well-knownWaveous72 is making his/her stupidity well-knownWaveous72 is making his/her stupidity well-known
hey man interested in your driver side fender for the 89-94 and the hood. do you have any pics?
Waveous72 is offline
