Old 11-07-2003, 11:00 PM   #1
AN89HATCH
AN89HATCH is a well-known jackass
Is it illegal to swap a ka24de into an 89 240sx?
Im lookig into purchasing a ka24de for my 89 240 but sice its a dohc and my original engine is a sohc is this swap going to be legal?Ive heard you can not swap dohc engines into cars that where originally equipet with sohc, u i caed dmv andthey said aslong as the yea of the engine is newer than the year of the car its ok, so im sorta confused.
AN89HATCH is offline   Reply With Quote
Old 11-07-2003, 11:09 PM   #2
BadMoJo
BadMoJo's Avatar
BadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura about
Send a message via AIM to BadMoJo
Its legal. there are a few things you neeed to do if your in cAil but i forget what they are. I am pretty drunk right now so i candkt quitre remeber. BUT it is leagal to do none the less!
----Gone----
BadMoJo is offline   Reply With Quote
Old 11-07-2003, 11:35 PM   #3
AN89HATCH
hha thanks for the reply, i guss ill find out what i ave to do tommorow
slide your ride.com
Old 11-08-2003, 12:06 AM   #4
WongFeiHung
WongFeiHung is an unknown quantity at this point
What's illegal is putting a older motor into a newer chassis...
WongFeiHung is offline   Reply With Quote
Old 11-08-2003, 12:38 AM   #5
aeontony
aeontony is an unknown quantity at this point
Basically, all the smog equipment has to be hooked up-that's all.
S14.5 for sale. Must move on with life...=(
http://www.zilvia.net/f/showthread.php?t=56822
Au no wa wakare no hajime...
aeontony is offline   Reply With Quote
Old 11-08-2003, 05:34 PM   #6
thx247
thx247 is an unknown quantity at this point
No its legal. You need to use all the original smog equipment on the DE motor, if its an OBDII motor you need to use the ODBII ECU, check engine light needs to work, diagnostic plug needs to work. Needs to pass smog test (smog II test so its on a dyno now) and a visual inspection at a BAR station where the ref (if you pass) will give you a sticker for the door jamb which says the car has a motor change, motor number etc.
I hope I'm not forgetting anything. You can find all the info on the DMV's website
thx247 is offline   Reply With Quote
Old 11-09-2003, 05:36 PM   #7
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
its legal but putting OBDII in an S13 would be a pita.
I don't know anyone that has done it.
You could just toss the S13 intake manifold and such onto the 98 block and hope no one notices that the block's # doesn't match.
andrave is offline   Reply With Quote
Old 11-09-2003, 07:31 PM   #8
AN89HATCH
is the 91-93 240sx dohc engine an obd2 motor?
slide your ride.com
Old 11-09-2003, 10:17 PM   #9
andrave
andrave's Avatar
nope not till 96
Old 11-10-2003, 06:31 AM   #10
BoroFabulous
BoroFabulous is an unknown quantity at this point
Send a message via AIM to BoroFabulous
Diagnostic Plug
Is the Diagnostic plug required to be working if the engine isn't obdii equipped, such as a 92' DE? I would like to know since i swapped in a DE from a 92' into my 89' fastback. I spliced the engine harness into the enginebay harness, the result of this being that the the consult(diagnostic plug of the s13's) doesn't work anymore. The last thing i want to be doing is paying $200 to illegally smog a fcking KA swap.
'89 SE coupe - Black
Eibach Sportline springs
KA24de swapped in
ya, its a pos
BoroFabulous is offline   Reply With Quote
Old 11-10-2003, 10:37 AM   #11
andrave
andrave's Avatar
yeah everything has to work.
you must maintain ALL smog equipment from BOTH engines, and when it is redundant the standard defaults to the LATER engine.
