Old 05-11-2010, 03:17 PM   #1
roboticnissan
roboticnissan's Avatar
roboticnissan is making a name for him/her selfroboticnissan is making a name for him/her selfroboticnissan is making a name for him/her self
rb20 operating temp?
I installed a water temp guage and put the sensor in thr lower hose. How cold should it be? I know its colder on the bottom than the top
roboticnissan is offline   Reply With Quote
Old 05-11-2010, 03:20 PM   #2
kushlivin
kushlivin's Avatar
kushlivin is an unknown quantity at this point
RB20's normal operating temp is between 170-180 -f
170*f / 77*c Thrilled
180* / 83* Happy
190* / 88* Content
200* / 93* Eek
+* +* Sad
HP is for gays.
Girls think stock KA's are fast.
kushlivin is offline   Reply With Quote
Old 05-11-2010, 03:31 PM   #3
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
What Kush Said.
Review Thread
bardabe is offline   Reply With Quote
Old 05-11-2010, 04:31 PM   #4
Sileighty_85
Sileighty_85's Avatar
Why do you want to know the temp of the radiator
You need to know what the engine temp is.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-11-2010, 05:25 PM   #5
roboticnissan
Double ppost my bad.
Old 05-11-2010, 05:55 PM   #6
roboticnissan
There is no engine temp sensor so my best bet is to get my coolant as cold as possible which will bring down engine temps.
All the temps above would be rellevant for the upper hose. I knew those all ready. How cold should my coolant be coming out of the radiator is my question.
Old 05-11-2010, 06:57 PM   #7
Sileighty_85
I know i cant be the only one that doesn't understand this logic.
Say that if you get the inlet coolant really cold will not guarantee that it will keep your engine colder. Not to mention the Engine need to be at a certain temp to it will pull fuel or it will run really rich.
If you get an air bubble in the system or the water pump dies then the engine will over heat and you wouldn't know cuz you'll be reading the rad temps.
後輪駆動車1番
1986 SR86 - 200ish
Old 05-11-2010, 07:18 PM   #8
roboticnissan
If air gets in the system or the water pump fails water no longer travels thru the radiator. Therefore not getting colder and just absorbing more heat and rising my temp guage. That's all besides the point. I want to know how cool my coolant should be getting when it comes out of the radiator. It goes in at 170 safely so what should it be colling down to?
Old 06-14-2012, 11:17 PM   #9
trickey1991
trickey1991 is an unknown quantity at this point
Sorry to bump and old thread
My Car runs about 180-185 on the highway doing around 120km/hr when its like 30 degrees or (86 Fahrenheit) outside.
when its like 25 or 77 Fahrenheit outside my car runs like 170-180 on highway
is this normal?
sometimes when sitting in town at lights etc it will get up to 190 when its 30+ degrees outside and 180ish when its like 20-25 degrees outside.
We are also very humid here.
this normal or?
92' R32 GTS-T 355whp
trickey1991 is offline   Reply With Quote
Old 06-15-2012, 06:08 PM   #10
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
I wouldnt really go crazy about it...get a colder thermostat if you want it to run a bit cooler.
CLICK HERE!!!
