Old 11-12-2003, 10:04 AM   #1
S14Speed997
S14Speed997's Avatar
S14Speed997 is an unknown quantity at this point
Replace whole T/C rod, or just bushing??
My stock T/C rod looks good, just my stock bushings are leaking.
Do the aftermarket (whiteline) bushings just pop right into stock rod?
I saw a couple options on www.pdm-racing.com
I would prefer to just get the bushings, any comments? thanks in advance
Eric
I love signatures that aren't over 400x200!
S14Speed997 is offline   Reply With Quote
Old 11-12-2003, 10:32 AM   #2
stp9154
stp9154's Avatar
stp9154 is an unknown quantity at this point
Not that easy to get new bushings in. My friend and i had a hard time doing that, but we eventually got them in. For me, i would rather get a new set of rods after spending some times with my friend on his car (bushings.)
stp9154 is offline   Reply With Quote
Old 11-12-2003, 11:35 AM   #3
Wei240
Wei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really nice
i got the bushings from pdm, took it to my mechanic, it's a bitch to get the old bushings out, make sure a shop has a vice or have really good tools.
search either here or f/a, there's a couple really detailed thread on this.
personally, i wished i bought the kazaama, tien, or any aftermarket t/c (the one's without bushings), check the group buys section, i think there's some on sale now (or was on sale). it's such a easy install without dealing with the bushings.
in either case, get an alignment afterwards...
Wei240 is offline   Reply With Quote
Old 11-12-2003, 06:16 PM   #4
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
http://www.240sx.org/atlanta/TC_bushing_install.htm
400x200
mbmbmb23 is offline   Reply With Quote
Old 11-12-2003, 11:04 PM   #5
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
my machine shop pressed mine in for like 20 bucks, it was a lot cheaper than replacing the TC rods and mine were in terrific shape.
they make a big diff by the way.
andrave is offline   Reply With Quote
Old 11-13-2003, 01:32 AM   #6
holisticbeatz
holisticbeatz's Avatar
holisticbeatz is a well-known jackass
The Whiteline tension rod bushings from PDM-Racing seem a bit expensive compared to the ones made by Energy Suspension. Check 'em out here: http://www.courtesyparts.com/Merchan...e=99995-77105G
I was planning to swap out the bushings prior to getting an alignment for my S14. However, due to an untimely accident, I decided to go with a set of Tanabe adjustable tension rods. They're a lot more beefy and durable. They also offer a wide range of adjustabliity I have yet to explore.
My $0.02
Trust and I don't mean GReddy.
holisticbeatz is offline   Reply With Quote
Old 11-13-2003, 01:58 AM   #7
andrave
andrave's Avatar
do a search, the whiteline are tapered, the energy ones aren't, supposedly they crack the TC rod after time.
I am glad I didn't go with spherical bushings since my car rides hard over expansion joints just with the poly bushings all around. spherical must be a real nut slapper.
I just checked those energy ones out, they are only like what, 8 bucks cheaper? not big enough to make a difference.
Old 11-13-2003, 06:53 AM   #8
S14Speed997
Thanks alot guys, I appreciate your info!
I had a feeling it would be a pain to get the bushings out and in..
I think I am going to buy OEM rods/bushings from PDM.
Thanks again
Eric
Old 11-13-2003, 09:51 AM   #9
andrave
andrave's Avatar
but oem bushings suck. You can get whiteline bushings pressed in for around the same price...
you have to take the opportunity to upgrade your car when you get it. The poly bushings make a big difference.
Old 11-13-2003, 10:18 AM   #10
S14Speed997
So its worth the hassel then? I have a shop that will put in the new rods/bushings for a "friend discount price". I just dont want to be an a$$ and bring him something that takes 2 hours instead of a half hour.
Eric
Old 11-13-2003, 10:25 AM   #11
Dousan_PG
Dousan_PG's Avatar
why OEM
go aftermarket
you get some adjustment if you like, no bushing, streetability discomfort..next to nothing over stock (feels nearly same)
anyways..
let's see
pdm-racing.com
oem tc rod and bushing: $71.50 for 1
whiteline bushing in tc rod: $103.5 for 1
aftermarket:
splparts.com: $161 for 2
now if your ONLY buying the bushing, then go for it, but if your buying the whole TC rod..
Aaron
Pink GodziRa
Old 11-13-2003, 10:39 AM   #12
S14Speed997
Holy crap, I have never seen these before (SPL tension rods S14/S15 $161)
So no rubber bushing...anybody using these now?
Old 11-13-2003, 10:40 AM   #13
Dousan_PG
Dousan_PG's Avatar
yea
LOTS AND LOTS AND LOTS of folks
very very common upgrade to go w/ aftermarket TC rods
very common
kazama, tein, spl, project silvia (check that out too, might be cheaper)
Aaron
Pink GodziRa
Old 11-13-2003, 10:56 AM   #14
JasonNagra
JasonNagra is an unknown quantity at this point
Send a message via AIM to JasonNagra
Most all of my adjustable parts are from SPL(including T/C Rods), very high quality and great service. O ya good price too. Don't get ass raped for a big name when SPL is JUST as good.
http://www.imagestation.com/picture/...f/f9dc7664.jpg
Edit: check your link.
JasonNagra is offline   Reply With Quote
Old 11-13-2003, 11:07 AM   #15
S14Speed997
Looks like you guys sold me on those SPL rods!! Thanks alot for all the tips on these,
one las thing, I see that they look adjustable..Should I just make them the same length as my current rods, or is there somewhere I can read up on this to understand adjusting?..thanks a bunch
Eric
Old 11-13-2003, 11:16 AM   #16
Dousan_PG
Dousan_PG's Avatar
i would add caster
when you get aligment just add like 1 or 2 degrees
stock i think is 5 degrees..
mine right now are 7.25 i think...but still rub when at the track drifting so going back to 8 degrees
id say a bit more caster would be nice. its your call. dont have to but if you might as well. if you dont like it, go back to stock. doesnt hurt to try! good luck!
Aaron
Pink GodziRa
Old 11-13-2003, 12:12 PM   #17
WongFeiHung
WongFeiHung is an unknown quantity at this point
You can pick up the projectsilvia ones on ebay for like $150 I think and they have the oil/lube nipple thing...Had them installed for a couple weeks now, very happy, easy install...
WongFeiHung is offline   Reply With Quote
Old 11-13-2003, 12:45 PM   #18
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
HA I've got one stock TC rod and one URAS adjustable. and even shortened all the way the URAS is longer than the stock one. so I got like .5 to 1 degree more caster on the drivers side than the passenger. feels kinda funny. I gotta order new tc rods. I'm tempted to get kazamas since all my oters are kazama and the red will match soo nicely... either that or get SPLs and powdercoat um
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline   Reply With Quote
Old 11-13-2003, 01:58 PM   #19
sykikchimp
WOW addicted
sykikchimp's Avatar
I agree with dousan, little to no difference in ride quality with spherical bearings.
I run 8 degree's of caster. Takes a bit more steering effort, but makes the car corner better, and more stable.
Steeles - positive caster will move the wheel forward in the wheel well. A shorter T/C rod should increase caster...
note on poly bushes.. they don't like twisting. The whiteline units being tapered helps, but MAKE SURE, TRIPLE SURE, that you put LOTS of the grease b/w the insert sleeve (that the mounting bolt goes through), and the bushing itself. Once tightened down, the sleeve will not twist, and the poly bushing will need to twist AROUND the sleeve. if it can't, it will eventually tear the T/C rod out of your control arm, and you will have to buy new control arms, and possibly new t/c rods as well. Rubber bushings, and Spherical bearings do not have this problem
Also - I own the dspeed t/c rods from PS and they suck. The bearings are rusting, and don't move real well any more. I'm going to be replacing mine soon. I would recommend something with a rubber boot on the bearing, or make sure the spherical bearings are Teflon impregnated.
Old 11-13-2003, 04:43 PM   #20
holisticbeatz
Originally posted by dousan36
i would add caster
How did you measure +2.25 degrees over stock?
Also, to add a higher degree of caster, I decrease the length of the tension rod, correct?
Old 11-13-2003, 04:45 PM   #21
Dousan_PG
Dousan_PG's Avatar
its called:
alignment shop
Aaron
Pink GodziRa
Old 11-13-2003, 05:08 PM   #22
holisticbeatz
its called:
alignment shop
So how much caster would be desirable? +3 degrees over stock?
Old 11-13-2003, 05:33 PM   #23
Dousan_PG
Dousan_PG's Avatar
you should try READING the thread.
Aaron
Pink GodziRa
Old 11-14-2003, 12:36 AM   #24
Steeles
Steeles's Avatar
true.. so wait.. umm now Im wondering WTF the alignment guy told Jason.... ahh well crap.. I aint worried about it. I'll order new adjustables here soon anyway. and have it realigned back to at least my 6.5 my go higher after listening to you and Dousan. 7.5 or so. we'll see.
Old 11-14-2003, 08:53 AM   #25
sykikchimp
WOW addicted
sykikchimp's Avatar
according to the back of my FSM, stock caster is 6* - 7.5*
http://charles.sykikchimp.org/quickref.html
Old 11-14-2003, 08:55 AM   #26
Dousan_PG
Dousan_PG's Avatar
ooh i c
thanks! then i need more haha
it still rubs at full counter..annoying
Aaron
Pink GodziRa
