Old 05-18-2010, 08:57 PM   #1
CinSun
CinSun's Avatar
CinSun is an unknown quantity at this point
Random SR20, S14 parts you need!!!
Please READ!!!
  • All parts are located in ONTARIO, CALIFORNIA 91761
  • Everything listed is used but in perfect working condition unless otherwise noted
  • All prices are OBO, but please don't waste my time with lowball offers
  • I will ship at BUYER'S expense, feel free to pm me for a quote and I'll get back to you ASAP
  • Local meetup/pickup is totally acceptable and preferred
  • Thanks for looking!!!
S13 SR20 Intake Manifold - $45
-the manifold will come with everything shown, EXCEPT the iacv. I'll also be throwing in brand new intake manifold gaskets.
S13 SR Flywheel - $40
S13 SR Exhaust Manifold - $50
-will come w/ 7-layer exhaust manifold gasket
S13 SR Throttle Body - $30
-comes with throttle position sensor as well. Will come with brand new OEM throttle body gasket.
S13 SR IACV x2 - $20 each
-I don't know if either of these work and I'm unable to test them, therefore I'm selling these AS IS.
S13 SR20 Oil Pump/Engine Front Cover - $150
-brand new, still wrapped in plastic
Adjustable FPR (fuel pressure regulator) - $70
-I'm not sure on the brand, but I was told this is either a Nismo or Tomei type-b universal FPR
S13 SR Ignitor Chip - $55
S13 SR20 Alternator w/ bracket and hardware - $90
S13 SR20 CAS (cam angle sensor) - $70
S13 SR20DET/KA24DE ECU Water Temp Sensor - $20
-brand new, never used
S14 KA/SR Dash Water Temp Sensor - $20
S13 SR20 PCV Valve - $10
S13 SR20 5 spd tranny - $225
-pulled from working setup. NO GEARS GRIND. Sensors, shifter, mounting brace, and clutch slave cylinder will be included. Tranny mount not included. There's a small leak in the rear where the driveshaft and tranny meet; the rubber seal/gasket needs to be replaced. This is a small fix. Local pickup/meetup only.
S14 Rear Seats - $75
-pickup/meetup only
S14 rear speaker deck cover/grilles - $30
-pickup/meetup only
CinSun is offline
Old 05-21-2010, 01:26 PM   #2
CinSun
CinSun's Avatar
so apparently i can't edit my post....anyways here's some more stuff
S14 Nismo Power Brace - $100
-I want to note that the threads on one of the bolts is partially ground down (about 1/8 of the threads.) A new nut can still be threaded onto it without any problems and therefore this should have little to no effect on the bolt's holding capacity. This bolt is used to attach the power brace to the sway bar. If its that much of an issue for you, you could always just replace the bolt with a new one. Otherwise the brace is in great shape.
S14 front sway bar - $35
-local pickup/meet up only
S14 tension rods - $20 each
S14 Zenki complete tail light set - $50
-no cracks, great condition. center piece does not come with reverse light bulbs.
CinSun is offline
Old 05-23-2010, 06:04 PM   #3
CinSun
CinSun's Avatar
bump10char
CinSun is offline
Old 05-23-2010, 06:25 PM   #4
x240xdrifter
x240xdrifter's Avatar
x240xdrifter is just really nicex240xdrifter is just really nicex240xdrifter is just really nicex240xdrifter is just really nicex240xdrifter is just really nicex240xdrifter is just really nicex240xdrifter is just really nicex240xdrifter is just really nicex240xdrifter is just really nice
Send a message via AIM to x240xdrifter
how much for the alternator bracket?
SHIFT_passion
x240xdrifter is offline
Old 05-24-2010, 02:51 AM   #5
miravete
miravete's Avatar
Trader Rating: (44)
miravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant future
Feedback Score: 44 reviews
you have pm
taking corners just as good as a drunken rhino..
miravete is offline
Old 05-24-2010, 05:47 PM   #6
CinSun
CinSun's Avatar
Bump10char
CinSun is offline
Old 05-25-2010, 01:51 PM   #7
CinSun
CinSun's Avatar
bump10char
CinSun is offline
Old 05-25-2010, 04:45 PM   #8
racerx2k1
460
racerx2k1's Avatar
Originally Posted by CinSun View Post
bump10char
Bump10char
bump10char
racerx2k1 is offline
240sx, ka24, s13, s14, sr20det
