Old 06-21-2010, 01:07 AM   #1
helladrifters
helladrifters's Avatar
helladrifters is an unknown quantity at this point
Car won't start, fuel flooding Cylinders? - Help
So I'm having a really odd problem thats been really bugging me.
I bought a 92 240sx SE a month ago. Car was great for a short period of time. I drove it for about 5 days after buying it. On the last day I took it out drifting with a buddy. Car was great for about 10 minutes.
However, I spun the car out and the car stalled out even with the clutch depressed. It then proceeded to not start. Cranked over fine, but no start.
We finally got it running for about 20 seconds, but it did not sound healthy at all. trying to give it gas made it worse, and then it died.
Got the car home, figured out too much fuel was getting in because the spark plugs were soaked in gas.
Thought it might be the fuel pressure regulator or leaky injectors, so i replaced the injectors and the regulator, but still same situation.
If i try to crank the car over with the injectors plugged in, it won't work. If i remove the plugs to the injectors, the car will try and start but then stop once all the fuel in the cylinder is gone (pretty fast).
any ideas for what could be wrong? I've been in contact with the seller, but I really have no idea what could be wrong
thanks in advance guys
helladrifters is offline   Reply With Quote
Old 06-21-2010, 01:16 AM   #2
hassanbakar123
hassanbakar123 is an unknown quantity at this point
what engine stock?
hassanbakar123 is offline   Reply With Quote
Old 06-21-2010, 01:27 AM   #3
helladrifters
good call lol
ka24de. ~180k. still strong. Engine is stock besides catback and K&N oem style filter
Old 06-21-2010, 06:13 PM   #4
helladrifters
alright so I tried something a little different today, sort of have some progress, although i have no idea what it means
Its pretty clear to me that fuel is flooding the cylinders. Either not sparking fast enough or fuel is pumping too fast.
I tried cranking the car for a bit and nothing happened. So next I removed the fuse for the fuel pump and then sprayed some brake cleaner in the throttle body.
The car started up for about a second and then it died once the brake cleaner/fuel had been burned up
what does this mean?
Old 06-22-2010, 02:44 PM   #5
Garber
Garber is an unknown quantity at this point
injector o-rings
Garber is offline   Reply With Quote
Old 04-19-2014, 05:42 PM   #6
linda
linda is an unknown quantity at this point
i have a 1993 chevy caviler its getting too much gas in 1 an # 2 cylinder can u help me
linda is offline   Reply With Quote
Old 04-19-2014, 05:44 PM   #7
linda
already chage them an still doing it
Old 04-19-2014, 05:49 PM   #8
linda
my husband changed the enjecters an o rings an my car still putting too much gas in 1 & # 2 cylinder
fuel injectors, ka24de, plugs
