Old 07-06-2010, 01:21 PM   #1
GripEnemy1992
GripEnemy1992 is an unknown quantity at this point
My SR20DET Problem
so cylinder two is misfiring and i dont know why, so far i have checked compressiion, 150, and i swapped coil packs and i swapped spark plugs and also fuel injectors but it still doesnt fire cylinder two, i need more suggestions on what to do
Thanks
Jordan
801-891-8188
GripEnemy1992 is offline   Reply With Quote
Old 07-06-2010, 01:30 PM   #2
xska
xska is an unknown quantity at this point
Start engine with coil pack off the head and used spark plug in boot, make sure plug is grounded to valve cover.
This way you can see if it's sparking or not.
If it sparks, then more like fuel problem....
Is it missing only at idle?
xska is offline   Reply With Quote
Old 07-06-2010, 02:47 PM   #3
GripEnemy1992
i will try that what do you mean make sure the plug is grounded like the threads? and it misses all the time
Old 07-06-2010, 03:14 PM   #4
jspaeth
jspaeth's Avatar
Could be a bad ignitor chip....try to swap that out for someone else's.
Daily driven
Old 07-06-2010, 03:32 PM   #5
GripEnemy1992
whats the ignitor chip?
Old 07-06-2010, 04:17 PM   #6
greenman100
Trader Rating: (18)
greenman100 is an unknown quantity at this point
Feedback Score: 18 reviews
GOOGLE IT
good gah
greenman100 is offline   Reply With Quote
Old 07-06-2010, 05:30 PM   #7
xska
Just let the tread section of spark plug sit on valve cover and position it so you can see the spark.
If it's missing all the time then, it's not vacuum leak.
You can also remove valve cover to check #2 locker arms to see it's there.
Old 07-06-2010, 05:55 PM   #8
GripEnemy1992
can it even be the ignitor chip from what ive heard if it was bad the car wouldnt run but it does, so can that even be the problem cause it runs.
Old 07-06-2010, 06:01 PM   #9
xska
Usually... when ignitor goes bad, no spark to all the cylinders, not just one.
Old 07-06-2010, 06:36 PM   #10
greenman100
Trader Rating: (18)
Wrong, one channel of the ignitor can fail.
Swap coilpacks between cylinders, if the misfire moves cylinders, there's your culprit.
Otherwise, its wiring or ignitor.
Old 07-06-2010, 07:01 PM   #11
GripEnemy1992
problem fixed after hours spent diagnosing all it was is the ecu was only half plugged in. hahhaha
Old 07-06-2010, 07:39 PM   #12
jspaeth
jspaeth's Avatar
Omg.........
Daily driven
Old 07-06-2010, 10:02 PM   #13
240sxspeed
240sxspeed's Avatar
240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold
smh u big dummy
HOME OF THE LOWBALLERS AND INTERNET THUGZ
240sxspeed is offline   Reply With Quote
Old 07-06-2010, 10:09 PM   #14
s14jesse
s14jesse's Avatar
s14jesse is making his/her stupidity well-knowns14jesse is making his/her stupidity well-knowns14jesse is making his/her stupidity well-known
Send a message via AIM to s14jesse
check ur coil pack harness
s14jesse is offline   Reply With Quote
Old 07-06-2010, 10:19 PM   #15
greenman100
Trader Rating: (18)
omg.........
misfire, sr20
