Old 11-28-2003, 02:06 PM   #1
Punkin
Punkin is an unknown quantity at this point
Carb problem? Newbie needs help
I have a 90 240sx. It is having a "jerking" problem, like it's missing. Seems to be worse when it's cold. When I'm stopped at a red light it sometimes acts like it is going to die, the rpm's drop and the car jerks. I smell gas strongly when I start it up. Many time when I accelerate, it does not respond, but sort of sputters instead. Any help is appreciated
Punkin is offline   Reply With Quote
Old 11-28-2003, 06:38 PM   #2
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
humm
240s dont have carbs, but anyway check your mass air flow meter, it is located on the intake pipe next to the air box, remove the plug and see if there is any rust on the connectors, if there is remove the rust, also remove the mass air flow meter and see if there is anything blocking it. If the mas is ok then check for any vacume leaks, (any little hoses hanging and if your motor is making a hissing sucking sound) then check your timing with a timing light, if its not any of those, get a sr20
Luke
blu808 is offline   Reply With Quote
Old 11-28-2003, 06:43 PM   #3
zero.counter
zero.counter's Avatar
zero.counter is making a name for him/her selfzero.counter is making a name for him/her self
Send a message via AIM to zero.counter
Re: humm
Actually, for the KA24E there was a carb swap available. Just an F.Y.I.
zero.counter is offline   Reply With Quote
Old 11-28-2003, 07:48 PM   #4
Var
Var's Avatar
Send a message via AIM to Var
could also be an ECT
Hi
Old 11-28-2003, 07:58 PM   #5
deviousKA
deviousKA's Avatar
deviousKA is making a name for him/her selfdeviousKA is making a name for him/her self
Send a message via AIM to deviousKA
haha, my 240 has carbs, 44mm mikunis, oh and its a de . Check to make sure your cold warm up injector is shutting off, most likely your problem
deviousKA is offline   Reply With Quote
Old 11-28-2003, 10:54 PM   #6
zero.counter
Cool, I did not know that.
