Sr20det: Cavitation or lifting head?
Im having an odd problem with my SR, and I was wondering if you guys could lead me in a direction to start figuring whats wrong with it. Its a black top s13 sr, with 550's and a 2860RS turbo. Its currently set to 17psi on stock internals and tuned for it. When ever though the car is over 6000rpm the temp gauge will jump up for a split second then settle right back down. It's like it jumps about half a temp mark then comes right back to where it was before, between the second and third temp. mark. Is this cavitation or is it lifting the head when its doing this?
#3 | |
![]() Join Date: Mar 2006
Daily driven |
![]() Join Date: Oct 2004
Cavitation only occurs over a period of time when the water circulates at a high rate over a period of time.... Signs of cavitation usually is water spitting out of the reservoir, then lack of water cause heat temp rising, but it doesn't make meters jump....
For me its constant 6-7k rpm drives on the track abouve 5 sessions into it at the end of the day.... never happens on the stret.
![]() Join Date: Apr 2004
Stock dummy gauge is worthless. I was hitting 230 deg F coolant in the upper hose after coming off track(it was 104 in the shade one day - it was cooler on track, but no matter how long of a cooldown it'd heat up once parked). The stock gauge never moved that I could tell.
Get a real gauge on there and check it out. Are you losing coolant or popping the rad cap?
S13 Hatch - Goes around tracks quickly DEFSPORT |
![]() Join Date: Aug 2006
def is right, usually on the stock gauge by the time it shows you temp rising your pretty much already overheated.
voltage problem or ground.
PARTING/SELLING MY COUPE. PM ME. |
#9 | |
I see. |
I shot these two videos earlier tonight, they were done in second gear, since that seems to be the only time it happens. I did notice the bellhousing was all wet on the passenger side and the top of the motor on that side had an unusal amount of shit build up compared to the rest of the engine.
YouTube - Sr20det |
