Old 08-14-2010, 10:41 AM   #1
808drft
808drft is an unknown quantity at this point
z32 head bolts work on ka24??
According to Matt Powers article in superstreet. They stated that he is using z32 head bolts. Ive search about this but didnt come up with anything. Does this work or needs to be custom fitted??
808drft is offline   Reply With Quote
Old 08-15-2010, 07:20 PM   #2
SxMachine
SxMachine's Avatar
SxMachine is making a name for him/her selfSxMachine is making a name for him/her selfSxMachine is making a name for him/her self
Well it is superstreet...then again it might work OR you might just want to use what was intended to be used, unless your certain.
91 Bmw 318is
90 S13 (sr20det)
SxMachine is offline   Reply With Quote
Old 08-15-2010, 08:28 PM   #3
blackoutt
blackoutt's Avatar
blackoutt is an unknown quantity at this point
put one in your left hand, and one in your right hand, then move your eyes from side to side. Let me know I'm interested in why that is so special. Aren't they studs anyway?
blackoutt is offline   Reply With Quote
Old 08-15-2010, 10:56 PM   #4
kalypso123
(ノಠ益ಠ)ノ彡
if they're the same diameter then it will work... the only benefit is if the 32's are made stronger; forged or what have you
Old 08-15-2010, 11:40 PM   #5
808drft
i donno i just thought it was interesting since he didnt just use head studs from arp. i could get the bolts pretty cheap since i work at nissan.
Old 08-18-2010, 10:53 PM   #6
Sad s13
Sad s13 is on the path to ruinSad s13 is on the path to ruinSad s13 is on the path to ruin
i heard under x amount of hp an tq the studs can strip out so maybe thats the case and he went with a bigger diameter and strong set up.... idk i havent compared the 2 side to side.
Sad s13 is offline   Reply With Quote
Old 08-19-2010, 01:26 PM   #7
808drft
true thats why they arp has the 11 or 12mm studs for crazy hp
Old 08-23-2010, 06:36 PM   #8
hitman
hitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfection
Send a message via AIM to hitman
head needs to be drilled out. the z32 bolts are 12mm where as ka is 10mm. they also torque higher.
driftparty.com
hitman is offline   Reply With Quote
