Old 08-22-2010, 04:40 AM   #1
om3ga
om3ga's Avatar
om3ga is an unknown quantity at this point
FPR on S13 SR, Need help.
I have a basically stock S13 SR that i am cleaning up and getting ready to run, i want to replace my stock FPR but do not know exactly what my options are.
My plan is to purchase a good quality FPR and set it to the stock Fuel pressure. The reason i want to replace it is because i have a Walbro fuel pump and i know that it over-powers the stock FPR a bit.
So my question is what is the technical info on the stock FPR? Is it a 1:1 ratio? Or is it a rising rate FPR? I believe it is a 1:1 but i just want to be sure.
I would really like to go with a SARD FPR, but i cannot find technical info on it which makes me nervous. I need to know for a fact that their FPR is a direct bolt on replacement for the SR.
What is your experience with whichever FPR you have?
Here is a picture of my build in progress. Just for fun.
om3ga is offline   Reply With Quote
Old 08-22-2010, 05:06 AM   #2
lexlaxlux
lexlaxlux's Avatar
Trader Rating: (32)
lexlaxlux is an unknown quantity at this point
Feedback Score: 32 reviews
i use a walbro 255 lp with the stock fpr. doesnt run rich or lean... if it aint broke dont fix it
lexlaxlux is offline   Reply With Quote
Old 08-22-2010, 08:57 AM   #3
sidedrifts13
sidedrifts13's Avatar
Trader Rating: (29)
Feedback Score: 29 reviews
^same here, but where did you get that intake from? if anything get a catch can and plug up that hose on the intake and get a aftermarket exhoust mani then get a power fc
sidedrifts13 is offline   Reply With Quote
Old 08-22-2010, 03:36 PM   #4
om3ga
om3ga's Avatar
The Intake is an Apexi suction kit. I also used the Apexi MAF adapter and i have a custom coupler that goes from the Suction pipe to the MAF. This engine is not running yet and i am going to be getting a catch can. That plug i have there is just so nothing gets in there while the engine is sitting.
I am getting an aftermarket fpr no matter what, i just need to know for sure that it will be a direct replacement.
Old 08-23-2010, 04:24 PM   #5
om3ga
om3ga's Avatar
Anyone have any input for a good fpr? Ive done endless research with not many good results.
Old 08-24-2010, 10:13 AM   #6
om3ga
om3ga's Avatar
I am also considering the new Tomei FPR. I can not find any info as to whether it is a 1:1 Ratio or if its Rising rate. Please take a look at this info.
ADJUSTABLE
Old 08-24-2010, 10:24 AM   #7
teamsprock
teamsprock's Avatar
teamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the rough
Can you answer one question so we can help... why are you dead set on getting a new fpr? The stock one works fine and lots of people use them at lots of different power levels. Clocking the OEM one to face downward is the best solution, and it looks like you have already done that. Lots of people use sard and tomei, they work just like your stock one. You need a fuel rail adapter and the FPR then decide on what type of hoses you want to use.
I will be honest it's overkill to change out your stock one, once you get to a high power car then it can be a nice upgrade, but still probably not needed.
teamsprock is offline   Reply With Quote
Old 08-24-2010, 10:26 AM   #8
garagelu
Trader Rating: (60)
garagelu is on a distinguished road
Feedback Score: 60 reviews
I have a tomei FPR. I have the type-s version. It looks pretty much the same thing as a sard. I have a feeling its the same thing but just rebranded.
And yes it is a rising rate and my tomei fpr works great with no problems.
Instagram: @garagelu
garagelu is offline   Reply With Quote
Old 08-24-2010, 10:31 AM   #9
vegasS12
vegasS12 is an unknown quantity at this point
msgllentghtdfgh
vegasS12 is offline   Reply With Quote
Old 08-24-2010, 03:20 PM   #10
om3ga
om3ga's Avatar
Are you sure its a rising rate? If it is what is the rate on it? 1:1 is what the stock one is so i would imagine you would be having problems with it if it was indeed a rising rate. Where did you get that info?
I want an aftermarket fpr because the stock one is old and worn out and cannot handle the pressure my fuel pump puts out causing the engine to run rich. A good aftermarket fpr will be able to take the added pressure.
Thanks
Old 08-24-2010, 03:23 PM   #11
Psychomoongoose
Psychomoongoose's Avatar
Psychomoongoose is an unknown quantity at this point
dont get a PowerFC theyre basically a joke. Get a real EMS like Haltech or Microtech.....or Motec if you, yeah......
Psychomoongoose is offline   Reply With Quote
Old 08-24-2010, 06:45 PM   #12
om3ga
om3ga's Avatar
Did you even read the original post?
Old 08-24-2010, 06:53 PM   #13
omgRWDgoodness!
omgRWDgoodness!'s Avatar
Trader Rating: (48)
omgRWDgoodness! is an unknown quantity at this point
Feedback Score: 48 reviews
Originally Posted by vegasS12 View Post
msgllentghtdfgh
Wtf is this? You fail.
omgRWDgoodness! is offline   Reply With Quote
Old 08-24-2010, 07:28 PM   #14
VQMaxFan
VQMaxFan's Avatar
VQMaxFan is on a distinguished road
Aeromotive & fuelab were my 2 choices, i went with the fuelab because of the available colors. They are pretty common and reccomended in the dsm community. I didnt like the tomei because of the 1/8 npt ports.
VQMaxFan is offline   Reply With Quote
Old 08-24-2010, 07:29 PM   #15
sil80 monster
sil80 monster is an unknown quantity at this point
No YOU fail. So does your stocky s14!
OP, are you 100% sure your engine is running lean?
I'm in the same boat as you. Seems as if my engine is just wasting gas since i have a high flow fuel pump and the stock s14 SR FPR.
sil80 monster is offline   Reply With Quote
Old 08-24-2010, 08:09 PM   #16
om3ga
om3ga's Avatar
Its not running lean im saying that i want to replace my stock fpr because its worn out and old plus the combo of it and a brand new walbro 255 makes it run rich. Since that pump is strong its overpowering the stock old fpr which is why i want to get a new good quality fpr to replace the stocker.
I just need good hard evidence that there is a SARD/Tomei FPR that is a direct replacement (not mounted to the fuel rail of course) for the stock unit. I want to buy the fuel rail adapter run fuel lines and set the FPR to the same pressure as stock and have it run no different than it would with the stock one at the correct fuel pressure.
Capisce?
Old 08-24-2010, 08:13 PM   #17
omgRWDgoodness!
Trader Rating: (48)
I fail, huh? Be that as it may, at least my dumb ass isn't using my friend's account because the three that I made ALL got banned.
Get fucked
Old 08-25-2010, 12:54 AM   #18
om3ga
om3ga's Avatar
ohhhhhhhhhh
Old 08-25-2010, 07:45 AM   #19
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
yes the Sard unit will work just fine. it is a direct replacement, providing u get the Fuel Rail adaptor.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 08-25-2010, 09:53 AM   #20
310R
310R is an unknown quantity at this point
If you decide to run an external reg the aeromotive I run is great.Couple fittings and hose and you are off.The aeromotive pump is nice and easy to use also.You can run a guage right on the reg.Plus you can mount it away from the engine,mine is on the passenger shock tower.Good luck with your project.
310R is offline   Reply With Quote
Old 08-25-2010, 10:49 AM   #21
om3ga
om3ga's Avatar
Hey Jap Slap, i am just wondering which part number on the SARD you think will work correctly.
Thanks!
Old 08-25-2010, 11:03 AM   #22
japslapsilvia
Thanks!
this is the one that i have, u can use the same one but w/o the "AN"
fittings. they have the ones that have the barb fitting that will be a direct replacement for the stock FPR.
Sard 69011 Fuel Pressure Regulator AN6 Fitting
Old 08-26-2010, 06:16 PM   #23
steve shadows
steve shadows's Avatar
Honestly unless you're going for somehting insane like over 500 whp, the OEM stock FPR is perfectly fine, in fact GREAT, takes away all the guesswork too.
Just make SURE your OEM one is actually working properly.
Also bud if you still need more help feel free to keep PM'in me, Ill be here for as much as possible
Like Me on FaceBook !
Old 08-26-2010, 08:08 PM   #24
om3ga
om3ga's Avatar
Thanks steve, in a perfect world i would be able to buy a Rising Rate 1:1 SARD FPR. However their dosn't seem to be good hard evidence on any of their part numbers being a Rising Rate 1:1.
Old 08-26-2010, 08:36 PM   #25
Om1kron
Om1kron's Avatar
What steve said is church in this situation... No point in changing it out if the shit isn't broken.
And the walbro pump only affects the FPR on a KA24de not an sr20 which actually can regulate the extra flow properly.
Wayne Edwards
https://om1kron.blogspot.com
Old 08-27-2010, 12:46 AM   #26
om3ga
om3ga's Avatar
Yeah but pretend as if i need to buy a brand new FPR (which is basically the case) I need to get a new one and either buy a good aftermarket one or buy a brand new oem one (If possible)
Old 08-27-2010, 12:51 AM   #27
Aki180sx
Aki180sx's Avatar
Aki180sx is an unknown quantity at this point
I have a project nissan fpr and have had for at least 3 years with no issues. and its fairly cheap.
Aki180sx is offline   Reply With Quote
Old 08-27-2010, 01:34 AM   #28
Om1kron
Om1kron's Avatar
Shouldn't have a problem at all buying a new oem one.
Wayne Edwards
Old 08-27-2010, 02:08 AM   #29
om3ga
om3ga's Avatar
I would buy the SARD no problem, except for i keep seeing this around.
SARD fuel pressure regulators are designed to provide the correct fuel pressure for any high performance fuel injected vehicle. The normal model is designed to be used on fuel injected, non-turbo-charged engines, and it is machined from billet aluminum.
Old 09-18-2010, 10:13 PM   #30
om3ga
om3ga's Avatar
anyone?
