Old 12-14-2003, 03:56 PM   #1
project_240
project_240 is an unknown quantity at this point
zenki headlight problem
help...i have a 95 and one of my headlights is out. now, the weird part is that when the low beam is on, it is out, but when the high beam is on, the low beam turns on along with the high beam, so the bulb itself still works. what do you think it could be? the low beam of my headlight works only when the high beam is turned on. it is just the passenger side...drivers side is fine.
-jake
project_240 is offline   Reply With Quote
Old 12-14-2003, 07:24 PM   #2
Phlip
Yes, I look like that
Phlip's Avatar
Replace the bulb anyway...
Weirdo
And I write too!
Old 12-14-2003, 07:39 PM   #3
yudalicious
yudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond repute
the low beam bulb actually has 2 filaments... 1 high beam 1 low beam - the low beam burned out - replace the bulb, this is normal.
BTW are you using aftermarket "xenon" bulbs? they wear out very fast.
yudalicious is offline   Reply With Quote
Old 12-14-2003, 07:56 PM   #4
project_240
okay i will replace the bulbs...and no i dont use those hyperwhite bulbs. i use normal h4 ones at auto zone or whatever...its been about 2 years since i replaced them. thanks...
-jake
