Old 09-02-2010, 02:54 PM   #1
Imperial SilviaS13
Imperial SilviaS13 is an unknown quantity at this point
s13 Problem Starting
im having problem starting my car. it doesnt want to start up. ive checked the starter and fuel pump and it still doesnt want to start. what wouldbe wrong with it?
Imperial SilviaS13 is offline   Reply With Quote
Old 09-02-2010, 04:29 PM   #2
yellowxhoodie
yellowxhoodie's Avatar
yellowxhoodie is an unknown quantity at this point
check your plugs.
yellowxhoodie is offline   Reply With Quote
Old 09-02-2010, 04:36 PM   #3
zylvia213
zylvia213's Avatar
Trader Rating: (36)
zylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond repute
Feedback Score: 36 reviews
Send a message via AIM to zylvia213
I think you posted this in the wrong section.... should be in tech support. Also you need to give more detailed info on your problem.
zylvia213 is offline   Reply With Quote
Old 09-02-2010, 05:43 PM   #4
!Zar!
!Zar!'s Avatar
Check your starter relay.
Old 09-04-2010, 09:24 PM   #5
Mishkin_707
Mishkin_707's Avatar
Mishkin_707 is an unknown quantity at this point
may have blinker fluid in the rear left tire.
Mishkin_707 is offline   Reply With Quote
Old 09-04-2010, 10:21 PM   #6
!Zar!
!Zar!'s Avatar
You are useless.
Old 09-04-2010, 10:34 PM   #7
I LUV MY S13
I LUV MY S13's Avatar
HAHA
OP, you need to do a bit of searching here this has been covered literally 100s of times.
-Jorge
I LUV MY S13 is offline   Reply With Quote
Old 09-05-2010, 03:13 AM   #8
Mishkin_707
You are useless.
hey, stupid questions get stupid answers.
oh yeah your"check your starter relay" was totally useless after he said he checked the starter and fuel pump, you knew exactly what was wrong with all the specific info the op gave ya.
Old 09-05-2010, 03:17 AM   #9
projekt_s13
projekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfection
Send a message via AIM to projekt_s13
Check your ignition switch also, i had a bunch of problems with my car not starting on hot days or whenever it felt like starting. It turned out to be the ign switch
projekt_s13 is offline   Reply With Quote
Old 09-05-2010, 10:52 AM   #10
!Zar!
!Zar!'s Avatar
On most s chassis if it doesn't want to turn over, chances are high it is the starter relay or clutch interlock relay.
Old 11-20-2010, 12:20 PM   #11
Imperial SilviaS13
okay i found out i have a bent valve. i have another motor and im gonna switch the heads. do i need to machine the valves still?
Old 11-20-2010, 05:01 PM   #12
yellowxhoodie
If you already have another complete head and you know its in good condition why would you need to do anything? Just switch them.
