![]() Join Date: Aug 2008
There could be a leak some where in the lines, check all the hoses and connections. I had the same problem turned out to be the hose that hooks up to the hardline, where it enters the bay, was lose.
#3 | |
Does it smell like gas only when it runs or all the time? If it's only when it runs it might be as simple and cheap as a $20 o2 sensor. |
or a injector o-ring is bad, I had that problem on the gf's old coupe.
take a sniff around and find out where its coming from then look for fuel itself. easiest way to fix it. prolly noghting major to fix if your buying the car. just don;t smoke by it |
![]() Join Date: Dec 2009
![]() Feedback Score: 8 reviews
my sr is having the same problem. whenever I open my windows I smell major gas.
also on about 3.1 gal of gas I get about 100km (62miles). about 20mpg? and that's when I mildly use the turbo.
fuel pump o-ring, rubber lines from the fuel pump, injector o-rings, check the fuel lines from the FF too! remember that they're all atlest 15 year old rubber hoses
