Old 09-20-2010, 02:02 PM   #1
kidbandikoot
kidbandikoot's Avatar
kidbandikoot is making a name for him/her selfkidbandikoot is making a name for him/her self
Angry s14 front camber issues
ok ive resorted to this... prolly shlda started here anyhow but w.e.
ive pushd my plates as far back as they can go for neg. camber.
but i still end up with positive so much so its going thru tires faster than i want to admit.... now i have godspeed type-rs fully adj. and blah blah blah ive heard and read all the bashing on these.. i just need to figure out y the hell this is happening ... now i know i can go buy the lower arms to correct..but my thing is y the hell is it doin this in the first place... anybody run into similar problems ... thanx
kid.b.
CUT AND DRY.
kidbandikoot is offline   Reply With Quote
Old 09-20-2010, 02:04 PM   #2
kidbandikoot
also ill throw up pics if i can figure out how to do it .. cuz honestly ive askd just bout evryone the all end up scratching their heads and say jus by lower arms .....
CUT AND DRY.
Old 09-20-2010, 02:47 PM   #3
Datenshi
Datenshi is an unknown quantity at this point
Are you sure your coilovers aren't installed backwards? I've seen it happen before.. and that might explain somethings. Other than that, I blame the fact they are Godspeed.
Datenshi is offline   Reply With Quote
Old 09-20-2010, 02:54 PM   #4
kidbandikoot
yes there installed correctly ......
CUT AND DRY.
Old 09-20-2010, 09:58 PM   #5
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
1. Adjusting them all the way IN (towards the engine) give you negative camber
2. Have you ever adjusted your front TOE? Toe kills tires super fast, not so much camber. Camber wears at an even rate, not prematurly. For every inch IMO, you gain roughly an 1/8th total toe. This is bad
Old 09-21-2010, 03:47 PM   #6
kidbandikoot
thanx codyace.... ima be changing tire set-up soon soo ill have to go check the alignment settings aswell..
CUT AND DRY.
Old 12-09-2010, 10:05 PM   #7
jinxtacy
jinxtacy is an unknown quantity at this point
Just curious, but I'm swapping out my DF210 springs for something smoother. I haven't been able to source a set of OEM S14 springs yet but came across a set of Tein H-Techs which lower the car .7/.4". Would that be a problem camber wise or can I go ahead and ditch the RUCA's?
jinxtacy is offline   Reply With Quote
Old 12-10-2010, 10:58 AM   #8
Touge Whore
Touge Whore is an unknown quantity at this point
Yes, as codyace stated...check your toe specs on the alignment. Also, how is the height? Are you maxed out on the drop? You may need to raise it slightly until you get the arms to correct your alignment.
Touge Whore is offline   Reply With Quote
