Old 09-29-2010, 06:37 PM   #1
95zenkisr20
95zenkisr20 is an unknown quantity at this point
HID problem
i just installed ddm hid low beams and when i turn my high beams on the hids shut off and just the high beams stay on when i would obviously like to have both low and high beams on.. any help would be great
95zenkisr20 is offline   Reply With Quote
Old 09-29-2010, 11:32 PM   #2
cotbu
cotbu's Avatar
We have a positive switching system for the headlights, At-least in an s13. So you need to run a relay, or create a separate circuit.
I've used a wolstentech TDR with good results, for daily driving.
I'm sure there are others available.
Time Delay Relay
Old 09-30-2010, 12:13 AM   #3
Enna
Enna will become famous soon enoughEnna will become famous soon enoughEnna will become famous soon enough
Send a message via AIM to Enna Send a message via MSN to Enna
Its because you have a zenki, I'm actually surprised you never found this out before you bought the HID's. You have to do a relay setup like cotbu mentioned to get them both working at the same time. Afik only the S14 Kouki had both at the same time.
Originally Posted by soreballz View Post
I hoped the candy would make it delicious, but I was incorrect.
Enna is offline   Reply With Quote
Old 09-30-2010, 05:27 AM   #4
95zenkisr20
thanks guys
Old 09-30-2010, 05:37 PM   #5
axlegrease
axlegrease's Avatar
axlegrease is an unknown quantity at this point
I've heard of zenkis with different low beam bulbs from the factory. Most zenkis though, have a hi/lo h4 bulb for the low beam. When you turn the high beams on, a separate filament in the h4 bulb turns on alongside the 9005 or whatever the inside high beam bulb is, which is why the connector has 3 prongs. As for the ddm hids, they sell the h4 kit with a hi/lo option which retains this function perfectly.
axlegrease is offline   Reply With Quote
Old 10-06-2010, 07:37 PM   #6
benj1159
benj1159 is an unknown quantity at this point
Ddm sucks ass
benj1159 is offline   Reply With Quote
