Old 10-07-2010, 11:30 AM   #1
drift240_2009
drift240_2009's Avatar
drift240_2009 is an unknown quantity at this point
New issue, PS looks like it boils after car has started
Everytime I start the car, the ps starts to slosh around and form bubbles likes its boiling. It does this even after ive driven a few times. The fluid isnt hot after i dip a clean swab in there to test it.
drift240_2009 is offline   Reply With Quote
Old 10-07-2010, 11:38 AM   #2
cardoza
cardoza is an unknown quantity at this point
I'm pretty sure that that's just the PS fluid circulating. My buddy's S14 also does the same thing.
cardoza is offline   Reply With Quote
Old 10-07-2010, 11:47 AM   #3
drift240_2009
All right, im just making sure. It seems strange to me because my s13 doesnt do it at all.
Old 10-07-2010, 10:30 PM   #4
Pacman
Pacman's Avatar
Pacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura about
Are there any leaks or is there air in the system?
Pacman is offline   Reply With Quote
Old 10-07-2010, 10:46 PM   #5
Shitty_S14
Shitty_S14's Avatar
Shitty_S14 is an unknown quantity at this point
mine looks like its boiling, but mine is also leaking a lil...
Is accepting BGR donations----paypal [email protected].
Shitty_S14 is offline   Reply With Quote
Old 10-07-2010, 11:14 PM   #6
Sleepy_Steve
Sleepy_Steve is an unknown quantity at this point
Same lol... I figure the spots under the car are either from PS fluid or a leaky oil pan gasket... But probably both.
'95 240 | @SleepySteve72
Sleepy_Steve is offline   Reply With Quote
Old 10-08-2010, 12:06 PM   #7
modulation
modulation is an unknown quantity at this point
I agree with this guy. Sounds like air is getting in the system some how.
modulation is offline   Reply With Quote
Old 10-08-2010, 03:13 PM   #8
drift240_2009
What should i do to get the air out? Can i just take out the ps pump or fill it up with new fluid?The steering is alittle hard to turn though sometimes if that helps anyone.
Old 10-08-2010, 03:21 PM   #9
modulation
Well I'd worry about how the air is getting in first. (Its not cause the cap is off, it's cause there is a leak somewhere in the hydraulic system.)
You aren't leaking power steering fluid from anything when the car is off?
Old 10-08-2010, 03:22 PM   #10
slider2828
slider2828's Avatar
Lift the front of the car, fill it, turn the wheel lock to lock a couple of times.... Then start the motor, repeat until air is all bled and then drop the front end back down....
Turn and Burn!
Old 10-08-2010, 06:57 PM   #11
drift240_2009
Um i dont get that. Where would i be leaking if theres no spots under my car?Ive done that slider and it still does the same thing.
Old 10-08-2010, 07:54 PM   #12
slider2828
slider2828's Avatar
Then it could be an issue with the pump... But what fluid are you using? Try atf?
Turn and Burn!
Old 10-08-2010, 09:32 PM   #13
drift240_2009
I use ps fluid. I dont remember the brand? ATF?Is that automatic transmission fluid? Why would i screw up my car, last person to tell me that my ps pump siezed up and the car didnt work.
Old 10-08-2010, 09:53 PM   #14
Team DET
Team DET's Avatar
Team DET is on a distinguished road
your suppose to use ATF Dexron 2 not ps fluid
(OΞO/- -\OΞO)
Team DET is offline   Reply With Quote
Old 10-09-2010, 01:58 AM   #15
Pacman
Pacman's Avatar
Remove the hoses at the steering rack and turn wheels getting the P/S fluid out of the rack and drain the rest of the fluid from the sytem. Fill with ATF (been using it in my pump for the last two years with no issues) and turn from lock-to-lock with the engine off. Start vehicle and add necessary fluid to keep level at minimum or more line. Once bled, there should be no noise and steering effort should be relatively normal. If the steering is hard at times, then there could be a issue with the pump or rack, or a restiction in the system.
Old 10-09-2010, 03:01 AM   #16
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
+1...Nissan uses ATF for the PS. Regular PS fluid is too thin.
CLICK HERE!!!
Old 10-09-2010, 05:51 AM   #17
nismoracingsx
nismoracingsx's Avatar
Trader Rating: (32)
nismoracingsx is an unknown quantity at this point
Feedback Score: 32 reviews
ack, I still need to flush the ps fluid out of my system >.<
nismoracingsx is offline   Reply With Quote
Old 10-09-2010, 03:21 PM   #18
drift240_2009
maybe it is a thinner fluid thats in there. guys this is making more sense than shops explain.
Ok I think this is the same issue but i want to toss this out so i know 100% it is the ps pump. My steering will go from stiff to loose at random times.
