Old 10-14-2010, 02:50 PM   #1
darkslide74
darkslide74's Avatar
darkslide74 is an unknown quantity at this point
SR Sr wont spark?!?!?!
i have had my sr20 blacktop for almost 6 months and haven't been able to start it up because it has no spark. I have replaced ECU and wire harness as well as the plugs and it still has no spark. any ideas what could cause this?
darkslide74 is offline   Reply With Quote
Old 10-15-2010, 10:55 AM   #2
Ceepo
Ceepo's Avatar
Ignitor chip? is the coilpack harness grounded right? there are many things it could be....
Old 10-15-2010, 06:20 PM   #3
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
i would check the ignitor chip also. check your ground.
Old 10-18-2010, 09:33 AM   #4
darkslide74
I know the ignitor is good but i havent checked my ground
Old 10-18-2010, 09:36 AM   #5
lok
lok's Avatar
lok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond repute
check the orange wire on the dash plug.
lok is offline   Reply With Quote
Old 10-18-2010, 10:31 AM   #6
BlacknboostedS13
BlacknboostedS13's Avatar
BlacknboostedS13 is an unknown quantity at this point
Are you running stock ignitor? or Q45? If your not getting ANY spark to any of the spark plugs chances are its not the coils. Check your grounds and CAS.
BlacknboostedS13 is offline   Reply With Quote
Old 10-18-2010, 11:55 AM   #7
eklips3
eklips3's Avatar
eklips3 is an unknown quantity at this point
i would say Cam angle sensor.
set the motor to 0 degrees ( top dead center, but not really ) align the pin thats above the crank pulley to the colored tick on your crank pulley.
take out the cam angle sensor and check to see if the dots align up.
there should be a better explanation of it if you use google.
1992 240sx (RB20. 362whp@16psi)
eklips3 is offline   Reply With Quote
Old 10-21-2010, 12:21 PM   #8
darkslide74
cam angle sensor has been replaced and still no spark, and its a sr ignitor
Old 10-21-2010, 12:25 PM   #9
Ceepo
Ceepo's Avatar
Check all grounds on the chassis, who did the wiring on the swap for you, are you sure its done correctly, check your cas, check the ignitor(make sure its getting signal in one side and out the other) check the grounds on the coilpack harness, check the grounds for the block/engine itself(EVERYTHING)
spark, sr20 blacktop, tech
