Old 01-13-2004, 02:01 PM   #1
bomex'd out s14
bomex'd out s14 is an unknown quantity at this point
Send a message via AIM to bomex'd out s14
s14 17" Motegi MR7 Rims for an S14
my friend and i swapped tires, he has my blackies, and i got his motegi rims, well ever since i put them on, my steering wheel's shaking left and right when i accelerate, and while going straight, my friend told me i need an alignment, balance, and or rotation, anyone know what it could be?
bomex'd out s14 is offline   Reply With Quote
Old 01-13-2004, 02:10 PM   #2
DoriftoSlut
DoriftoSlut's Avatar
DoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to behold
Send a message via AIM to DoriftoSlut
Wheels arent balanced. While you are at it, get them rotated and get an alignment.
Death Before Dishonor.
www.pinkgodzira.com
www.driftalliance.com
DoriftoSlut is offline   Reply With Quote
Old 01-13-2004, 02:13 PM   #3
bomex'd out s14
hahahah alright thanks
Old 01-13-2004, 07:56 PM   #4
Vatche
Vatche's Avatar
Trader Rating: (289)
Vatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfection
Feedback Score: 289 reviews
exactly what he said, get alignment roatation and balancing....everytime u change tires wheels suspension anything that changes the wheels placement on the car
Originally Posted by Jung918
I dub thy the socal zilvia slut.
The Ultimate For Sale Thread <> Review Thread
Vatche is offline   Reply With Quote
Old 01-14-2004, 01:01 AM   #5
SpeedMonkeyInc
SpeedMonkeyInc's Avatar
SpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond repute
NOnonono....you just need a set of hubcentric rings. You can get them anyplace that sells tires. Call them up to make sure they are in stock.
If you did not have the problem before, then you swap on some aftermarket rims, and you get this problem, you need these rings. $5.00 for 4 plastic rings.
Every time you change wheels you need an alignment? You gotta be kidding me. I switch from my grip tires/rims to my rain tires/rims all the time. No alignments needed.
SpeedMonkeyInc is offline   Reply With Quote
Old 01-14-2004, 01:05 AM   #6
mike13
mike13's Avatar
mike13 is an unknown quantity at this point
Send a message via AIM to mike13
try getting some wheels that are available outide of Pep Boys ricer zone and you should be good. the 17x7 +45mm offset is probably banging against your suspension causing all the horrible vibrations
mike13 is offline   Reply With Quote
Old 01-14-2004, 07:17 AM   #7
Ghettokracker71
Ghettokracker71's Avatar
Ghettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enough
Send a message via AIM to Ghettokracker71 Send a message via Yahoo to Ghettokracker71
Hubcentric rings eh? Never heard of them...hopefully I won't need them once I slap my Quatem Teks on...
Ghettokracker71 is offline   Reply With Quote
Old 01-14-2004, 08:02 AM   #8
mellojoe
mellojoe is an unknown quantity at this point
seriously, just go to any decent wheel/tire shop and get them balanced. That should take care of you.
If I were doing it, I'd get the alignment, too, but if you just slapped different rims on (that weren't crazy 18's or some other "bling bling"), then you really don't NEEEEEED that alignment. Just highly recommended.
mellojoe is offline   Reply With Quote
Old 01-14-2004, 08:39 AM   #9
Ghettokracker71
How much should alignment,and mounting+balencing be ? (I'm putting on rims as soon as winter finally ends)
Old 01-14-2004, 10:52 AM   #10
SpeedMonkeyInc
What are Quatem Teks?
Anyway, the thing with aftermarket wheels is that the center bore is big enough to fit all types of cars. Even when you torque down your lugs they don't center the wheel perfectly. A set of $5 hubcentric rings will make a very snug fit between the wheel and the hub, in effect balancing the wheels. I know because I had the same problem with my wheels, the rings fixed the problem.
Maybe I am misunderstanding. Did you mount the tires on the rims yourself? If yes, go get a balance at a tire shop. What I am thinking you did was just swap wheels and doing nothing with the tires then you should not need a tire balance. Just trying to save you from spending a grip of $$ on an alignment. Maybe if you have the toe or caster knocked way out on one or two wheels, than sure, that could be causing all that wobbling. Otherwise, what are you going to adjust that will solve that problem?
Old 01-14-2004, 11:00 AM   #11
Ghettokracker71
hmm...thanks.........the wheels I am putting on have about 800mis. on them,with Toyo Proxes F4(don't care for the tires honestly)...they've been shipped from Texas,the guy said chances are when they were shipped they might have gotten knocked around,and could have easily lost balance?
Hey thats really cool about the hubcentric rings,thanks again...hope it fixes the prob with those Motegi's.......
Old 01-14-2004, 11:05 AM   #12
Dousan_PG
Dousan_PG's Avatar
sounds like a real line there ghetto
either A) a wheel weight or 2 fell off
b) he sold you warped wheels
the shop who balances the wheels can tell you what shape they are in.
and ghetto:
about the pricing on alignment/balance. CALL AROUND, stop looking for handouts and pick up the phone.
Aaron
Pink GodziRa
Old 01-14-2004, 11:40 AM   #13
Ghettokracker71
and ghetto:
Well he has 100% positive feedback on eBay.......and alot of it,and hes not one of those power seller asshole companys,...he just some guy,I've watched the stuff hes been selling for a while after they were purchased...my dad bought them as a gift,....the guy claimed to have put them on his new car,and wrecked it,as in totaled...(he even emailed pics of the totaled car with my wheels on it !) ...and he ended up getting a truck as replacement for the car,so what to do with the wheels? Sell them...the accident could have easily messed up there balance as well( I would think)....I am leary of them,but I know a tire shop I trust,the original owner of my S13 is the guy that owns the shop,and if they say their warped...then,its no money out of my account !
Yeah,sorry about the handout shit,I thought you or somebody might have an idea........thanks
