Old 12-16-2010, 10:19 PM   #1
shinobis13hb
shinobis13hb's Avatar
shinobis13hb is an unknown quantity at this point
boost not going above 10 lbs. no line on stock accuator.
YES i was watching the boost gauge.
could someone explain why it wouldnt go above 10 lbs? it should have infinite boost correct?
s13sr blacktop.
shinobis13hb is offline   Reply With Quote
Old 12-16-2010, 10:23 PM   #2
240sxrb25
240sxrb25 is an unknown quantity at this point
a wastegate wit no line attatched operates off spring pressure....if no vacuum line is attatched technically the exhaust pressure against the WG piston will open it....
infinateboost pressure is a hoax
240sxrb25 is offline   Reply With Quote
Old 12-16-2010, 10:43 PM   #3
roel03
roel03 is making a name for him/her selfroel03 is making a name for him/her self
Stock wastegate will go to 20psi with no attached line.
roel03 is offline   Reply With Quote
Old 12-16-2010, 10:54 PM   #4
shinobis13hb
but why would i not be going over 10lb if the line is disconnected?
even if i connect my manual boost controller and close it completly i only get 10lbs.
i would eventually like to go up to 12lbs when i get a front mount.
im jsut stummped
Old 12-16-2010, 11:03 PM   #5
roel03
Faulty wastegate? Different spring? It is easily narrowed down to that part so replace it. Even get an adjustable one and get rid of your MBC.
Also, your boost gauge could be wrong or wired incorrectly.
Old 12-16-2010, 11:20 PM   #6
shinobis13hb
thanks roel03,
i am most likely going to be replacing it with a hks adjustable and getting rid of that horrid MBC i can drive the car fine for now. but i already replaced it once and got no changed it stayed the same... but if something isn't broken why replace it? as far as the boost gauge it is installed correctly. thank you for your advice.
Old 12-16-2010, 11:58 PM   #7
mikerbike
mikerbike is an unknown quantity at this point
False. A wastegate with no line attatched will not open, creating more boost, eventually maxxing out the turbocharger's boost capabilities. And, exhaust pressure won't open a wastegate if it's pushing against the actuator.
The wastegate reduces boost, not increases boost.
OP, more likely causes of your problem are boost leak and/or bad turbocharger.
mikerbike is offline   Reply With Quote
Old 12-17-2010, 12:04 AM   #8
shinobis13hb
mikerbike,
i inspected the turbo and its Fing clean no shaft play at all motor has 60k+3k i have put on it. what would you suggest to check? could the stock wastegate me out of play here? . im going to upgrade to t bolts when i get my FMIC after x-mas. even if i close my MBC i only get 10lbs.
thanks for your help.
Old 12-17-2010, 01:35 AM   #9
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
boost leak test / thread.
Review Thread
bardabe is offline   Reply With Quote
Old 12-17-2010, 01:48 AM   #10
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
Boost leak indeed
R@ddy is offline   Reply With Quote
Old 12-17-2010, 11:06 PM   #11
roel03
What I am saying is, if the wastegate is running no vacuum or is seeing a regular vacuum source and not a boost source, the car will maximize at 20PSI and no more.
Old 12-19-2010, 06:00 PM   #12
mikerbike
Any vacuum source is also a boost source. But a boost source before the throttle body is not a vacuum source. So, I don't really understand what you're getting at.
And My turbo maxed out at 17psi when the wastegate line broke. But 20 at lower altitude is probably possible.
Old 12-19-2010, 06:49 PM   #13
rb25_s13*CHUKI
rb25_s13*CHUKI's Avatar
yea wastegate with no line is sick! haha I forgot to connect It one time and my car was pulling like a mother fucker for being a stock t25. Then I pull out my plugs after I seen It was off and they were all melted
Obliterate
rb25_s13*CHUKI is offline   Reply With Quote
Old 12-22-2010, 04:46 PM   #14
roel03
No, not every vacuum source is a correct boost source.
