Old 12-17-2010, 08:54 AM   #1
dued
dued's Avatar
dued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymore
Smile Clunk in Rear - Have solid Subframe Bushings
Hi Guys, I'm trying to research a new clunking noise I have coming from the rear of my s14. I have stance solid subframe bushings, so no problems there. I recently swapped my diff for a j30 however. I've been reading alot and it seems like there is play in the driveshaft from other people's descriptions. My question is, considering that the j30 was most likely an abs car, and my s14 is non abs, could there be a length problem in the driveshaft causing enough room for play and causing the clunk? Is there any way I could make a spacer to fix the problem? I haven't found a solution for this & I'd like to get it solved for everyone else out there.
dued is offline   Reply With Quote
Old 12-17-2010, 09:04 AM   #2
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
im pretty sure j30 is a direct swap.. i have clunking in the rear, granted i dont have solid subframe bushing or subframe risier either lol
S-Nation S13 is offline   Reply With Quote
Old 12-17-2010, 09:32 AM   #3
Wabash9000
Wabash9000 has a little shameless behavior in the past
check the center support of the driveshaft. the rubber there wears out and causes it to clunk around.
Wabash9000 is offline   Reply With Quote
Old 12-17-2010, 04:20 PM   #4
Sileighty_85
Sileighty_85's Avatar
No sapcer is needed, If you were using an ABS DS with a Non ABS Diff, Then you might need a spacer.
Only thing I could think of is if its a tight fit for the DS due to using an ABS Diff and Non ABS DS and if the Diff bushings have enough play then the DS front yoke might be slappin the back of the tranny.
Just a thought IDK
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
