Old 12-17-2010, 02:19 PM   #1
pink godzila
pink godzila's Avatar
Trader Rating: (226)
pink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond repute
Feedback Score: 226 reviews
Smell oil/bad smog? What could it be? Help!
After start, car smell bad.... help
NO smoke
Could be?
1) Car has leak from crank shaft shell front. Havent fix yet.
2) Apexi N1 Dual
Whatelse could it be? so I could fix it and get it smog
pink godzila is offline   Reply With Quote
Old 12-17-2010, 02:23 PM   #2
KaminaSan
KaminaSan's Avatar
KaminaSan is an unknown quantity at this point
NO smoke
Could be?
2) Apexi N1 Dual
Ummm.... sounds like burning oil?
Maybe you should get that leak fixed, you know so you don't blow your engine, then you can worry about smog.
someone in the car is screaming when that deadly t25 spools up!
KaminaSan is offline   Reply With Quote
Old 12-17-2010, 02:35 PM   #3
modulation
modulation is an unknown quantity at this point
Could be?
2) Apexi N1 Dual
Where is the smell coming from? Does it smell like burning oil or ammonia?
If it smell like ammonia you have a leak somewhere in your exhaust.
Otherwise your car is going to smell cause the crank shaft seal leaks oil all down the oil pan and then onto the exhaust and transmission and it'll start to burn off when the exhaust gets hot.
modulation is offline   Reply With Quote
Old 12-17-2010, 03:20 PM   #4
pink godzila
Thanks guys...
I notice...the smell is more like burning oil. Drove the car today and cause is raning is Socal, so as far I havent smell anything today. probably is the leak from the crank shaft seal.
Ill get it fix asap...
