Old 12-21-2010, 12:37 PM   #1
roadster6909
roadster6909 is an unknown quantity at this point
Drive shaft install problem.
With my transmission bolts unscrewed, which leave it hanging around a half foot lower, this is the offset of the two, around half inch to an inch.
I can't seem to unscrew the 4 bolts from the differential/ drive shaft..
What do i have to do to get this dang drive shaft in?
I swapped the sr20 back in last night, and i came to this problem.
roadster6909 is offline   Reply With Quote
Old 12-21-2010, 12:46 PM   #2
nismoman
nismoman is an unknown quantity at this point
You gotta get those diff bolts loose. That's the right way to do it.
nismoman is offline   Reply With Quote
Old 12-21-2010, 12:55 PM   #3
roadster6909
They are both 14 mm keys. You cant fit socket keys on them so i used the wrench 14mm's and it slips. I don't want to strip the bolt, so i'm stuck thinking about what to use :l
What would you suggest? I have the clamp ons with rigid teeth on the side closer to tranny and that seems to work fine but i'm afraid if i do the same to the other side it'll strip and i'm stuck??
I'm so close to finishing though, i'm happy to have the sr back in
Please reply if you can!
Old 12-21-2010, 01:45 PM   #4
obsolete
obsolete is an unknown quantity at this point
can't tell from pics, but did you unbolt the two bolts holding up the driveshaft? Then you could slide it in on a slight angle and then bolt the two bolts back and then the tranny mount.
obsolete is offline   Reply With Quote
Old 12-21-2010, 01:49 PM   #5
WIKID S4TEEN
WIKID S4TEEN's Avatar
WIKID S4TEEN is making a name for him/her selfWIKID S4TEEN is making a name for him/her self
i used an open wrench with 1.5" dia tube as a breaker bar.
Rock wha U jock and don't talk if U ain't got!!
WIKID S4TEEN is offline   Reply With Quote
Old 12-21-2010, 01:54 PM   #6
roadster6909
Which two bolts do you speak of?
Old 12-21-2010, 02:51 PM   #7
upsdude
upsdude's Avatar
Trader Rating: (46)
upsdude is an unknown quantity at this point
Feedback Score: 46 reviews
U should have done the diff bolts first tat way you dont have the tranny all loose.
upsdude is offline   Reply With Quote
Old 12-21-2010, 05:35 PM   #8
roadster6909
After hours of adrenaline rush trying to do this, i've accomplished. This is how it looks like, is this how it should sit? I have a bag that says drive shaft bolts, 3 of them.. bolts with nuts, but idk where they go?
Do these brackets bolt on to it somewhere? Where do these brackets go?
Their was one big bracket that bolted on under the drive shaft, but i'm left with these still.
And what about this on the tranny?
I cant push the fork down any further, so i cant bolt it on >_<
I appreciate your help zilvia, i keep coming one step closer to accomplishing this swap, thanks!
Old 12-21-2010, 06:03 PM   #9
Sileighty_85
Sileighty_85's Avatar
Brackets go to top of Radiator
pull up clutch pedal and push in slave rod
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 12-21-2010, 06:07 PM   #10
roadster6909
Hmmm, I dont have my clutch installed yet, looking for guides on that.
Maybe you have some guides on how to install clutch/ master cylinder so i can do this?
Should the clutch pedal be down when installing? Sorry i've never messed with this stuff.
And does the drive train look like it's in the tranny right? Or..?
Thanks, as always.
Old 12-21-2010, 06:18 PM   #11
Sileighty_85
If you dont have a clutch pedal installed and cant push that slave in then its probably fucked and needs to be replaced.
There are guides around here i sure but if you look under the dash you will see a hole that you need to cut out pretty straight forward.
I was thinking that the cluch pedal was pushed down since you couldnt push in the slave so the fluid couldnt back flow.
drive train looks fine
後輪駆動車1番
1986 SR86 - 200ish
Old 12-21-2010, 06:33 PM   #12
roadster6909
This sr was in the car, took it out, and rebuilt it.
The clutch is from the sr and everthing is their . The clutch pedal is installed, you can push it in, pull it out etc, i just don't know how to install the lines, etc.
Master cylinder and everthing is their..just need to install lines, etc.. but idk how lol <- noob
Old 12-21-2010, 06:48 PM   #13
BlazNby
BlazNby is an unknown quantity at this point
this is straight forward for hardlines and doesnt need much explanantion, just look at pictures of engine bays on google and look at the three hardlines that are at the back top part of the firewall. only one can go to the master cylinder(these are pre-bent and can only go to one spot,so i doubt you can mess this part up). What you might need is a stainless steel hardline for your setup to delete that box looking thing that goes to your slave(pedal feels much stiffer with the setup like that). Also use line wrenches if u can if not open end works but be sure to start these threads with your hands and once u feel it tighten up then go with the tool(if you strip these lines either the threads in your master cylinder or the threads in the hardline u must scrap it and buy new ones).
BlazNby is offline   Reply With Quote
Old 12-21-2010, 06:50 PM   #14
BlazNby
found using google
Old 12-21-2010, 10:01 PM   #15
obsolete
if you never messed with the hardlines, you don't need to do anything. just push that rod in by the tranny and bolt up the two bolts.
Old 12-21-2010, 10:21 PM   #16
roadster6909
I can move the fork part closer to the two bolts, but not the opposite way.. thats the way it needs to go or else i cant bolt it on..
Old 12-22-2010, 05:27 AM   #17
obsolete
Try opening the cap to the master cylinder and then push in the rod on the slave cylinder by hand. That should give u room to line up the bolt holes
Old 12-22-2010, 12:29 PM   #18
roadster6909
Okay, so i took of the lid and was able to squueze the master cylinder together and onto the rod. However i still have these 3 bolts, that said drive shaft bolts on them.. Where do ya think they go?
Old 12-22-2010, 07:43 PM   #19
240ND
240ND is an unknown quantity at this point
Those hold the 2 peice driveshaft together. on the very right of this picture youll see right behind the part that is held up by that driveshaft bracket there's 4 holes. put the bolts in those holes.
edit: it looks like you have one in there already. just make sure the round top with the one flat side is on the right side with the flat side sitting flush with the u-joint and the nut and lockwash are on the left(using the above picture)
240ND is offline   Reply With Quote
