Old 12-21-2010, 02:48 PM   #1
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
SoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud of
Feedback Score: 36 reviews
s14 S14 Part out, Black interior, full trunk trim, ect, Barn Lot....
Ok as I was picking some parts out I sold and noticed alot of good items, and some items you members have asked about and I said I didnt have, but seen today I do!
I just parted out an auto 95 240 black interior, well stripped and been selling, I will rattle off a list of parts I have, please keep in mind I have alot more items I need to take inventory of. I just moved houses and everything at the house is in totes, anyways....Stuff in Shop....
All parts are from S14 unless otherwise noted! All parts below are black, although I have most items in blue also if interested. Lots of doubles! Will be adding ....
Dash - $100(has 3 small spots/pokes. upclose pics available upon request, not visible really unless you point them out!)
Passenger Door Panel black/grey insert - $20
Passenger Window switch & surround - $30 (NOT CRACKED)
Driver window Glass - $25
A/C-Heater Control - $25
Rear Seats Grey - $30 set (bottoms stained up, could be cleaned im sure, NO RIPS BURNS!)
Rear Seats SE Patterned Style - $75 set (CLEAN!!!)
Cluster Trim - $15
Door sills - $20
A-Pillars w/speaker pods - $30
Rear 1/4 top panels - $40
Rear 1/4 bottom panels - $50
Rear trim pc w/clips! sits ontop of trunk latch - $20
Behind Rear seat trim(3pc) & molding -$15
OEM radio w/brackets dual unit tape is stuck - $20
OEM Amplifier under rear deck - $30
Complete Airbag System - $100 (this includes L & R airbags with computer and all harness!)
Front Seats Grey - $150 (No rips/burns!)
Misc Rubber Seals, door jams, trunk, ect. - $5-$10 depending which seal
Rear Windshield trim pc(screws at bottom of rear glass)- $20
Map Light(front one w/sunroof) - $15
Rear headliner light - $10
Rear seat Belts - $40
Front Seat Belts - $80
Glove Box - $25
Glove box metal Trim mount - $5
Underdash trim pc, under steering colunm - $15
Kick Panels - $20
Auto Shifters assemblies - $20
Rear View Mirror - $10 (one tiny 1/4" crack top right corner, not chipped!)
Dash vents, side, top corners, inside tubes, ect - $5 each
Visors - black dyed - $15
Sunroof motor - $20
Hood Latch Cable - $20
Rear Struts - $20 (good oems)
All 3 Underdash Boxes:
-Heater Core - $50
-AC Core - $50
-Blower Motor - $50
Metal Dash Bar - $20
Brake Master Cylinder w/Booster - $50
A/C Lines and misc peices - $5 and up
A/C Compressors - $25
Wiper Motor - $20
ABS unit - $50
Cowl Panel - $20
E-Brake Cables - $40
Passenger Rear Brake Caliper - $40
Front Brake Calipers - $30 ea.
Chassis Underdash harness - $75
Misc Chassis harnesses, yanked them all, PM request and offer!
Air Boxes, Air Intake tubes, all oem, couplers, ect...-$5 (&up depending what ya want)
MAFS - $25
Distributer - $40
Starter - $40
Fuel Rail with Injectors - $40 (no FPR)
Engine Mount Brackets -$40
Fan Shroud w/2 sides/bottom/complete - $30
Electric Fan - $30
Clutch Fans - $15
Zenki Tailights - $50
Passenger Fender Maroon - $30
Sunroof Glass - $100 (Glass only w/good seal)
Battery Tray Plastic - $5
Tanabe Subframe Bushings - $80
Ton of KA Engine parts/accessories also!
Ton of SR S13 Engine Misc...
S13 Door Sills black - $20
S13 Driver Kick Panel black - $10
As said before, I have 10 times this stuff, this was all in a spot at my shop I need to do something with asap! lol
PM me with any further requests and offers, everything above is OBO!!!
I can text pics upon request or PM them to you. I know pics make te sale add. I will try and just get some put up here soon, for now, I will take upon request, everything is in good shape unless otherwise noted!
Hatas Keep Hatin, I Keep Rollin!
Last edited by SoloSilvia; 01-18-2011 at 06:50 PM.. Reason: adding parts/selling parts...
SoloSilvia is offline   Reply With Quote
Old 12-21-2010, 03:14 PM   #2
imnotniko
imnotniko is an unknown quantity at this point
ya don't happen to have a Blower resistor would you? you can shoot me a pm thanks!
imnotniko is offline   Reply With Quote
Old 12-21-2010, 03:58 PM   #3
redline1
redline1 is an unknown quantity at this point
if ya have corner lights and turn signals let me know via pm.thanks i am only an hour from you. and price
redline1 is offline   Reply With Quote
Old 12-21-2010, 04:13 PM   #4
tims05
tims05 is an unknown quantity at this point
Is the rear deck lid cover the SE one with the large speaker grills? Seems like it wont let me pm you
tims05 is offline   Reply With Quote
Old 12-21-2010, 04:15 PM   #5
sidewaysil80
sidewaysil80's Avatar
sidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to all
do you by any chance have any of the following un-cracked? s14 radio trim, shifter trim, defroster vent for dash?
sidewaysil80 is offline   Reply With Quote
Old 12-21-2010, 04:20 PM   #6
redline1
oh sorry forgot to ask if you have the sunroof seal also
Old 12-25-2010, 05:38 AM   #7
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
Keep the PM's coming! Thanks to those whos helped me clear some space already! Got so much more to go!
Christmas Bump #1! MERRY CHRISTMAS!!!
Old 12-26-2010, 12:04 AM   #8
ss1156ss
ss1156ss is an unknown quantity at this point
Would you happen to have a driver's door panel? It doesn't have to be perfect, but as few cracks in the arm rest portion the better. I have a guy that can fix it and then cover the repaired section with suede.
ss1156ss is offline   Reply With Quote
Old 12-26-2010, 12:31 AM   #9
lucas240sx
lucas240sx is a jewel in the roughlucas240sx is a jewel in the roughlucas240sx is a jewel in the roughlucas240sx is a jewel in the roughlucas240sx is a jewel in the roughlucas240sx is a jewel in the roughlucas240sx is a jewel in the roughlucas240sx is a jewel in the rough
id like to see some pics of the front seats plz
willing to ship?
if so to 74804 okl
thx
lucas240sx is offline   Reply With Quote
Old 12-28-2010, 01:42 PM   #10
speedfiend
Trader Rating: (68)
speedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to all
Feedback Score: 68 reviews
Send a message via AIM to speedfiend
Hey man sent you a pm. Interested in some of the parts you have. Hit me back when you get a chance.
Cameron
speedfiend is offline   Reply With Quote
Old 12-28-2010, 11:34 PM   #11
pincheturbo
pincheturbo's Avatar
Trader Rating: (24)
pincheturbo is an unknown quantity at this point
Feedback Score: 24 reviews
would you by any chance have the driver side headlight plug? for lowbeam
my for sale thread:
http://zilvia.net/f/sale-items/53975...e-30-less.html
NISMO, NRG, JDM turn signals, misc engine parts
pincheturbo is offline   Reply With Quote
Old 12-29-2010, 08:58 AM   #12
fearlessKouki
fearlessKouki is an unknown quantity at this point
Willing to sell the windshield??
fearlessKouki is offline   Reply With Quote
Old 01-01-2011, 07:27 PM   #13
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
and a...
...HAPPY NEW YEARS !!!
Some Parts Added, more to come, keep the PM's rolling in!
Old 01-02-2011, 01:06 AM   #14
pink godzila
pink godzila's Avatar
Trader Rating: (226)
pink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond repute
Feedback Score: 226 reviews
S14 manual tranny harness?
pink godzila is offline   Reply With Quote
Old 01-11-2011, 09:55 AM   #15
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
Last bump for this sale!
Old 01-11-2011, 10:12 AM   #16
Hollywood30
Hollywood30 is an unknown quantity at this point
Those subframe bushings solid aluminum ones?
Hollywood30 is offline   Reply With Quote
Old 01-11-2011, 10:23 AM   #17
Daggering
Daggering's Avatar
Daggering is an unknown quantity at this point
You got the engine harness?
WTB- Type X Part's
Daggering is offline   Reply With Quote
Old 01-11-2011, 10:48 AM   #18
importdude
importdude's Avatar
importdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond repute
Send a message via AIM to importdude
do you have the drivers side fender liner?
built ka-t
importdude is offline   Reply With Quote
Old 01-11-2011, 10:51 AM   #19
burton240sx
burton240sx is an unknown quantity at this point
s14 zenki
do you have any zenki headlights?
burton240sx is offline   Reply With Quote
Old 01-11-2011, 11:11 AM   #20
miravete
miravete's Avatar
Trader Rating: (44)
miravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant future
Feedback Score: 44 reviews
Clutch pedal?
taking corners just as good as a drunken rhino..
miravete is offline   Reply With Quote
Old 01-11-2011, 11:33 AM   #21
PITCH
PITCH's Avatar
PITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to behold
do $10 on the auto shifter assembly?
PITCH is offline   Reply With Quote
Old 01-11-2011, 01:10 PM   #22
Nissan240sxDriver
Nissan240sxDriver is an unknown quantity at this point
SE Headlight/fog light switch?
Nissan240sxDriver is offline   Reply With Quote
Old 01-11-2011, 03:56 PM   #23
amolao
amolao's Avatar
amolao is an unknown quantity at this point
pics of rear seats??
http://home.sw.rr.com/longstorenissan ***UPDATED 13 AUG 05 ***
amolao is offline   Reply With Quote
Old 01-11-2011, 08:37 PM   #24
brian.
brian. has made poor choicesbrian. has made poor choicesbrian. has made poor choicesbrian. has made poor choicesbrian. has made poor choicesbrian. has made poor choices
Let me know If you'd be willing to sell a power antenna, and a windshield wiper tranmissio n (the linkage).
Please pm me.
brian. is offline   Reply With Quote
Old 01-11-2011, 08:38 PM   #25
brian.
Let me know If you'd be willing to sell a power antenna, and a windshield wiper tranmission (the linkage).
Please pm me.
Old 01-12-2011, 04:24 PM   #26
squatting pigeon
squatting pigeon's Avatar
squatting pigeon is an unknown quantity at this point
do you have a passenger door lock or manual trans. brake pedal?
squatting pigeon is offline   Reply With Quote
Old 01-16-2011, 01:35 AM   #27
240AZ
240AZ's Avatar
240AZ is an unknown quantity at this point
I need wiper motor and a/c heater control. Would you know if the heater core would fit a 98??
240AZ is offline   Reply With Quote
Old 01-16-2011, 02:14 AM   #28
Tracer11lb
Tracer11lb is an unknown quantity at this point
do you have the driverside door and window switch and the plastic that connects them to the door arm rest?? if you do how much shipped to 12208? let me know thanks
Tracer11lb is offline   Reply With Quote
Old 01-17-2011, 08:43 AM   #29
nurevem1
nurevem1 is an unknown quantity at this point
need these
Wiper Motor - $20
Washer Resivoir - $20
and was also wondering if you have the dash piece that goes around the center air vents that holds the hazards switch and rear defroster switch? please let me know asap. thanks
nurevem1 is offline   Reply With Quote
Old 01-17-2011, 02:44 PM   #30
Wbarnes13
Wbarnes13 is an unknown quantity at this point
Do you have a driver side window control switch? how much shipped to 33411?
Wbarnes13 is offline   Reply With Quote
