Old 12-08-2010, 04:13 PM   #1
s13pimp
s13pimp is an unknown quantity at this point
FS: NY S13 SR20DET Blacktop part-out!!!
Well, I was running MSD 72lb injectors on my sr and one of them failed, causing a lean condition in cylinder 2, which damaged the water jacket in cyl two. For all intensive purposes, the block is not salvageable. However, everything else is in great working order. Everything is for sale except for the CAS. I have everything else including:
-Stock T25 (in EXCELLENT condition) *SOLD*
-Valve cover (small dent from leaving a tool on it and closing the hood) *SOLD*
-3 coilpacks (one of the 4 is badly cracked) $25 (each)
-Coilpack harness $30
-2 knock sensors *SOLD*
-O2 sensor *SOLD*
-MAFS $35
-coolant temp sensor $10
-Wiring harness (not the greatest I've seen) *SOLD*
-Lower trans harness $50
-2 sets of stock cams $40 (each)
-Stock exhaust manifold $25
-T25 with blown seals [I think] $40
-alternator $30
-2 sets of stock fuel injectors, rails and FPR's $115 (each)
-ARP head studs (used for about 1000 miles, probably less) $75
-Transmission *SOLD*
-water pump*SOLD*
-oil pan $20
-timing chain tensioner $30
-Head (Looks excellent, but might need machining) $150
-bottom end (pistons and other components are in *GOOD* condition) (make an offer)
-Fidanza flywheel *SOLD*
-ACT 6 puck unsprung clutch (good condition) $140
-Stainless steel turbo lines (t25, t28) $60
-Passenger side door w/ mirror and door card (s13, primered black, crank windows) $65 (picked up)
-Electric driver side mirror $20
-Stance GR+ Pro springs (2 8kg front, 2 6kg rear) $50
I'm getting tired of listing things, so if you need something, just ask. I most likely have it since I have a complete swap basically. Ask for pictures if you want them. Email is the best way to get in touch. [email protected]
All prices are OBO
s13pimp is offline
Old 12-08-2010, 05:10 PM   #2
l2edken
l2edken is a jewel in the roughl2edken is a jewel in the roughl2edken is a jewel in the roughl2edken is a jewel in the roughl2edken is a jewel in the roughl2edken is a jewel in the roughl2edken is a jewel in the rough
stock downpipe available?
l2edken is offline
Old 12-08-2010, 05:30 PM   #3
s13pimp
No, but the stock turbo elbo is. You wouldn't happen to have meant that, would you?
s13pimp is offline
Old 12-09-2010, 01:44 AM   #4
90hatchie
Banned from the Marketplace
where in ny are you im lookin to pick up that turbo :-)
90hatchie is offline
Old 12-09-2010, 08:56 AM   #5
240boost
240boost is an unknown quantity at this point
flywheel picture? and where in ny.
240boost is offline
Old 12-09-2010, 10:53 AM   #6
s13pimp
For all that asked, I'm located in Syracuse, NY.
Pics of flywheel:
The friction plate is a little rusty. It could be resurfaced, or you could simply order a new friction plate for $61, and then you would have a brand new flywheel.
s13pimp is offline
Old 12-12-2010, 10:26 AM   #7
s13pimp
Bumb to the top!
s13pimp is offline
Old 12-16-2010, 03:42 PM   #8
s13pimp
Bump! All prices are OBO!
s13pimp is offline
Old 12-16-2010, 04:54 PM   #9
negrosx13
negrosx13's Avatar
negrosx13 is an unknown quantity at this point
Send a message via AIM to negrosx13
Where is your location iin ny??..I want the alternator
MORE BACON STRIPS
negrosx13 is offline
Old 12-16-2010, 05:40 PM   #10
s13pimp
I'm located in Syracuse (unfortunately).
s13pimp is offline
Old 12-17-2010, 06:15 PM   #11
s13pimp
Bump! Added ss turbo lines!
s13pimp is offline
Old 12-17-2010, 06:40 PM   #12
hkspwrsr
hkspwrsr's Avatar
hkspwrsr is an unknown quantity at this point
do you have an intake suction hose? filter to turbo
hkspwrsr is offline
Old 12-20-2010, 06:04 PM   #13
s13pimp
Sorry, It's not for sale. Good luck finding one!
s13pimp is offline
Old 12-22-2010, 04:00 PM   #14
s13pimp
Bump! Reduced prices and revised list!
s13pimp is offline
Old 12-22-2010, 04:51 PM   #15
sr20sean
sr20sean's Avatar
Trader Rating: (25)
sr20sean is an unknown quantity at this point
Feedback Score: 25 reviews
Send a message via AIM to sr20sean
got any pics of that clutch?
sr20sean is offline
Old 12-25-2010, 08:42 AM   #16
s13pimp
I sure do! I can post some pics in a little bit. Also, I'll be in New Paltz next weekend so pickup is possible if you decide you want it.
s13pimp is offline
Old 12-25-2010, 09:29 AM   #17
two40guy
two40guy is an unknown quantity at this point
you wouldnt happen to have an aluminum radiator for sale would you?
two40guy is offline
Old 12-26-2010, 03:40 PM   #18
Razi
Razi is an unknown quantity at this point
Do the manifolds have the stock heatsheild?
Razi is offline
Old 12-26-2010, 04:37 PM   #19
s13pimp
Sorry for the delay, but here is a picture of the clutch.
And sorry, but I have no radiator for sale.
I have only one manifold left, and I actually dont think it has a heat shield. I can check tomorrow though.
s13pimp is offline
Old 12-26-2010, 05:28 PM   #20
Prez
Prez's Avatar
Prez is an unknown quantity at this point
where is dent on valve cover? picture?
and would you be interested in selling just the compressor wheel off that t25... otherwise cause i know you dont wanna fuck with that snap ring.... make that t25 $30 shipped to DE 19713 and you got a deal....
and depending on location of the "dent" i might take valve cover too.
"soft so you can't even enjoy it"
Prez is offline
Old 12-26-2010, 07:03 PM   #21
Tempnix
Tempnix's Avatar
Tempnix is an unknown quantity at this point
Sent PM.
Tempnix is offline
Old 12-26-2010, 07:05 PM   #22
Prez
Prez's Avatar
Thanks For Valve Cover!
Prez is offline
Old 12-27-2010, 09:11 PM   #23
somedude
somedude is an unknown quantity at this point
how much for the mafs shipped to 84015
somedude is offline
Old 12-27-2010, 09:21 PM   #24
409-ef8
409-ef8 is an unknown quantity at this point
Ps pump and bracket shipped to 77662
409-ef8 is offline
Old 12-27-2010, 09:32 PM   #25
s13pimp
Sorry, but I sold the PS pump and bracket.
The maf will be $53 shipped to your door!
s13pimp is offline
Old 12-27-2010, 09:42 PM   #26
409-ef8
damn lol there like gold
409-ef8 is offline
Old 12-28-2010, 07:27 AM   #27
somedude
ok cool pm'd you
somedude is offline
Old 12-28-2010, 03:43 PM   #28
s13pimp
Just sent you a pm back!
s13pimp is offline
Old 12-28-2010, 05:12 PM   #29
s13pimp
Haha yeah, I know! I wish you got to me like two days sooner because I ended up selling the whole setup to my buddy at "bro pricing" (which basically means I gave it to him for free hahaha).
s13pimp is offline
Old 12-29-2010, 03:49 PM   #30
s13pimp
Bump. Updated list.
s13pimp is offline
