Old 01-05-2011, 06:35 PM   #1
mrchomponthis
mrchomponthis's Avatar
mrchomponthis is an unknown quantity at this point
sr20det water pump studs
How do I take off the old studs from my old water pump and put them on my oem pump i bought. The new one didn't come with studs :/
CHOMPONWHAT?
mrchomponthis is offline   Reply With Quote
Old 01-05-2011, 06:50 PM   #2
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
go buy some nuts and bolts that will fit in there
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 01-05-2011, 07:01 PM   #3
mrchomponthis
I figured there was a way to get the STUDS out.
CHOMPONWHAT?
Old 01-05-2011, 07:11 PM   #4
niscur29
Location: Back IN FL, bring nice cars to the fail state!
niscur29 is an unknown quantity at this point
I attempted to get mine out using everything but a vise grip....ended up needing the VG which naturally fucked them up. I went to Lowes and got some new bolts and nuts and threaded the bolt through the backside like the OEM studs. I think they were M6 fine thread and like $1.50 for all 4 with nuts/washer/lock washer.
niscur29 is offline   Reply With Quote
Old 01-05-2011, 07:14 PM   #5
mrchomponthis
thanks man, Kinda screwed up that the oe water pumps come with studs but oem ones dont....
CHOMPONWHAT?
Old 01-05-2011, 07:21 PM   #6
niscur29
Whoops meant 6mm fine thread not M6!
Old 01-06-2011, 08:51 AM   #7
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
pulling out the studs it super simple,
take two nuts and put them on the stud tighten the nuts togather, using your wrench remove the lower nut and the stud will come out. once the stud is out take two wrenches and remove the nuts from the stud.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 01-06-2011, 06:41 PM   #8
mrchomponthis
thanks sir thats what i needed to know.
CHOMPONWHAT?
