Old 01-16-2011, 06:42 PM   #1
StryfeS13
It's Always Broken.
StryfeS13's Avatar
StryfeS13 is an unknown quantity at this point
KA TPS Adjustment?
I had to rebuild my throttle body because one of the seals was leaking. Anyway, I get it all back on, and I'm not too sure of how to adjust my TPS.
The tutorial says:
1. Install Throttle Sensor body in the Throttle Chamber. Do not tighten bolts. Leave bolts loose.
2. Connect Throttle Sensor harness connector.
3. Start engine and warm up sufficiently.
4. Measure output voltage of Throttle Sensor using voltmeter.
5. Adjust by rotating Throttle Sensor body so that the output voltage is 0.45 - 0.55 volts.
6. Tighten mounting bolts.
7. Disconnect Throttle Sensor harness for a few seconds and then reconnect it.
Here are my questions.
1. Does the engine need to be started and warmed up? I've read on NICO and on Zilvia, that you don't need to turn it on, you just need the key in the on position.
2. Does anyone have a picture of the exact two wires to test, for voltage? The guide doesn't describe it very well.
3. When I went to adjust, there was a green/white wire, and a red wire I believe. My voltage read as 4.55. It doesn't read as 0.45 as the guide stated. It doesn't matter what I set my volt meter to, it doesn't read 0.45. It's only 4.55 or 45.5, etc.
4. I set it at 4.55, and it has a high idle, like 1500 when it starts, and 1200 when it warms up. It used to be 900ish when cold, and 700 when warmed up.
Thanks.
Originally Posted by KoukiMonsta
once its done you can drive it off a fucking cliff for making such a fucking stupid thread.
Gotta love Zilvia.
StryfeS13 is offline   Reply With Quote
Old 01-16-2011, 09:53 PM   #2
StryfeS13
It's Always Broken.
StryfeS13's Avatar
Anyone....
Gotta love Zilvia.
Old 01-17-2011, 08:01 AM   #3
nismoman
nismoman is an unknown quantity at this point
Download the FSM it tells you what wires to probe. You should only be getting a voltage that high at wide open throttle.
nismoman is offline   Reply With Quote
Old 01-17-2011, 09:29 AM   #4
Banana_Cute
Banana_Cute's Avatar
Banana_Cute is an unknown quantity at this point
dang, i never really know how to set the TPS.. i jst play it by the ear.
leave it a lil loose and move it around while the car is on.. lol...
u seemed to be doing it right. jst gotta find the FSM for the right voltages.
Banana_Cute is offline   Reply With Quote
Old 01-17-2011, 10:39 AM   #5
airhead
airhead's Avatar
Trader Rating: (32)
airhead is making a name for him/her selfairhead is making a name for him/her selfairhead is making a name for him/her self
Feedback Score: 32 reviews
FSM will tell you exactly wat to do
make sure you set the meter to DC i believe?
i had to shake the TPS sensor so it can get to the 0.00 number so maybe you can try that
airhead is offline   Reply With Quote
Old 01-17-2011, 11:36 AM   #6
WIKID S4TEEN
WIKID S4TEEN's Avatar
WIKID S4TEEN is making a name for him/her selfWIKID S4TEEN is making a name for him/her self
yeah, make sure your DMM (Digital Multi Meter) is on VDC and within that voltage range.
You can place the leads any way, if it is wrong, it will read neg voltage.
Example: -.45
If so, swap the leads of the DMM.
Rock wha U jock and don't talk if U ain't got!!
WIKID S4TEEN is offline   Reply With Quote
Old 01-17-2011, 02:15 PM   #7
StryfeS13
It's Always Broken.
StryfeS13's Avatar
Okay...I'm not sure which setting is VDC, I'm guessing it's the V with the dot and lines?
EDIT: Okay, so I researched and figured out that the V with the dots is DC. So what do I set it on, 200m, 2, 20, 200, or 600??
Gotta love Zilvia.
Old 01-17-2011, 02:39 PM   #8
S14DB
AFC #1
S14DB's Avatar
20 vdc
Old 01-17-2011, 02:47 PM   #9
nismoman
yeah that side and what he said^^^
Old 01-17-2011, 03:02 PM   #10
StryfeS13
It's Always Broken.
StryfeS13's Avatar
Alright thanks guys. I'll go try it out, and I'll be back with results in about an hour.
Gotta love Zilvia.
Old 01-17-2011, 05:18 PM   #11
StryfeS13
It's Always Broken.
StryfeS13's Avatar
Alright so I'm pretty sure I got it guys.
I set the key to the ON position, and used a paper clip as a probe. I placed the positive on the probe, and the negative on a bolt in the engine bay.
This was my reading. 0.54, which is .4 off. (can't believe it makes that big of a difference..)
I loosened the TPS sensor bolts, and rotated it until I achieved this with the throttle plate CLOSED.
And this with the throttle plate at WOT.
Everything look good?
Gotta love Zilvia.
Old 01-09-2017, 06:11 PM   #12
Basam4
Basam4 is an unknown quantity at this point
https://youtu.be/RaKitZZVEi8 this is the link that shows what is wrong with my 240sx, if anyone has any suggestions on what I could do to fix this problem please reply back.
Basam4 is offline   Reply With Quote
