break idle hesitation problem PLEASE HELP!!!
to start first off im running z32 breaks up front and stock s14 rears.
i have a stock s14 bmc. I changed the rear pads today and after i bleeded them i seem to have this weird problem that i never seen before . when the car is idle and i break and keep breaking it seems to hesitate a good mount almost feels like it wants to choke the engine. btw im running an s13sr I WILL ANSWER ANY QUESTIONS thanks. |
![]() Join Date: Mar 2008
Trader Rating: (81)
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 81 reviews
sounds like you need to clean your idle control valve.
http://squarespokes.com/ |
Trader Rating: (81)
the brake master has a vacuum line that goes across to the intake manifold. make sure that plugged in and check that line for any leaks. the idle air control valve (iacv) gets dirty/clogged and causes idle to bog or die when braking or sometimes just in full stop at idle. might have just been coincedance that it happened after your brake upgrade. a little carb/choke cleaner will do the trick.
