Old 02-04-2011, 03:56 AM   #1
mojocoggo
mojocoggo's Avatar
mojocoggo is an unknown quantity at this point
Send a message via ICQ to mojocoggo Send a message via AIM to mojocoggo Send a message via MSN to mojocoggo Send a message via Yahoo to mojocoggo
FS: 1987 Nissan 300zx Turbo Targa Manual, Built
Selling my 1987 Nissan 300ZX Turbo currently has 112,000 miles, manual transmission 5-speed with CLSD diff.
We're talkin forged pistons, n̶e̶w̶ ̶r̶o̶d̶s̶, ̶n̶e̶w̶ ̶c̶r̶a̶n̶k̶s̶h̶a̶f̶t̶, bigger turbo (literally), Han's labor ain't cheap! I drive this car daily and and it is absolutely reliable. I've had the car for 9 months, and I have gone over pretty much every mechanical aspect of the car and either rebuilt or replaced parts as needed. It isn't pretty, but it cleans up nice and is perfectly mechanically sound. The suspension is a fully adjustable S13 coilover setup. All electronics and lights work fine. A/C and heater have been removed, along with about 300lbs of other extra nonsense.
Current Mods:
Engine
-VG30ET top end rebuilt with new heads
-All new senors including a brand new Mass Air Flow Sensor
-Custom built brand new T3 T4 Turbo, 60 trim compressor 63 trim turbine with stage II wheels
-Custom made intake piping with custom Volvo recirculation valve installed
-Custom 2.5in downpipe with V-band flange
-New 90 Amp alternator from Nissan Maxima
-Wiring harness tucked and all emission items removed.
-Running 88/89 ECCS with resistance droppers on low imp injectors
-Brand new Walbro 255 Fuel Pump
-Brand new fuel lines and brand new fuel pressure regulator and fuel filter
-Brand new distributer, new coil, new NGK wires, new NGK plugs, new Cap and rotor
-New oxygen sensor, new PCV valve, new Auxilary Air valve, New timing belt
-All new belts, rebuilt power steering pump
-All new vacuum hoses
-New Water pump, thermostat, new Nismo rad cap, new radiator, new hoses, new coolant temp sensor and harness
-Brand new custom e fan setup
-Custom 2.5 in exhaust system with muffler
Suspension
-Every bushing replaced with polyurethane (excluding rear end)
-Front suspension is entirely custom S13 adjustable setup
-Front S13 Godspeed adjustable control arms
-Front S13 Godspeed Adjustable tension rods
-Front S13 Ichiba 5-Lug hubs
-Front S13 OEM new spindles
-S13 Godspeed coilovers with 16 way adjustable dampeners
-N/A 300zx 22mm sway bars
-Front J30 rotor and brakes
-All around 1.25 in wheel adapters
-15x7 BBS BMW wheels wrapped with 225/50/15s in the rear and 195/50/15s in front
-Brake system bleed and filled with new fluid
-Front and Rear Courtesy Nissan Strut Bars
-New S13 OEM tie rods (inner and outer)
Interior
-Entire interior gutted out and coated with truck bed liner (Rhino Liner)
-Custom generic racing seats
-Dash gutted of all climate control devices
-Custom gauges including 2x for water temp and 1x for boost
-Greddy Turbo Timer installed with Greddy harness
-New shifter boot with 240sx shifter knob
-Aftermarket drift steering wheel
-OEM gauges converted from Digital to Analog
-Anything not used has been blocked off with sheet aluminum for weight
-Made a custom opening to access fuel pump
-Custom hood pins with hood locks
Asking $4000 OBO! Please call me or text at 760-712-9943.
mojocoggo is offline   Reply With Quote
Old 02-04-2011, 05:08 PM   #2
mojocoggo
mojocoggo's Avatar
New price, $7800 with stock wheels, $10,500 with the BBS wheels. $17,500 with engine.
Old 02-04-2011, 05:28 PM   #3
emtee817
emtee817 is a glorious beacon of lightemtee817 is a glorious beacon of lightemtee817 is a glorious beacon of lightemtee817 is a glorious beacon of lightemtee817 is a glorious beacon of lightemtee817 is a glorious beacon of lightemtee817 is a glorious beacon of lightemtee817 is a glorious beacon of lightemtee817 is a glorious beacon of lightemtee817 is a glorious beacon of lightemtee817 is a glorious beacon of light
just for clarification, why does your original post say 4,000 obo and now youre asking upwards of 7,800-17,500
emtee817 is offline   Reply With Quote
Old 02-05-2011, 01:22 PM   #4
2590402
2590402 is an unknown quantity at this point
Wait what happened to the $4000 price tag, i was thinking about buying this.
2590402 is offline   Reply With Quote
Old 02-05-2011, 01:25 PM   #5
joeyz31
joeyz31 is an unknown quantity at this point
wait...bro, is this real life? where did those numbers come from?
joeyz31 is offline   Reply With Quote
Old 02-05-2011, 08:10 PM   #6
mojocoggo
mojocoggo's Avatar
Well, I sort of found my calling. I'm most likely keeping the car unless I get offered an insane amount of money for it. Sorry for the confusion. Still considering offers.
Old 02-06-2011, 06:38 PM   #7
shadowhunter66
shadowhunter66's Avatar
shadowhunter66 is making a name for him/her selfshadowhunter66 is making a name for him/her self
What the hell is with the price?
shadowhunter66 is offline   Reply With Quote
Old 02-06-2011, 06:45 PM   #8
Untam3dS13
Untam3dS13's Avatar
Untam3dS13 is an unknown quantity at this point
Dang stopped breathing for a bit after dat price tag....lol
H3LLO LADYI3ZZ
Untam3dS13 is offline   Reply With Quote
Old 02-06-2011, 10:43 PM   #9
shadowhunter66
If your keeping the car unless you get offered an insane amount, why don't you clarify how much you want.. instead of confusing all of us with your secondary prices, when you have your primary which totally conflict.
Old 02-07-2011, 12:28 AM   #10
Boost-Fiend
Boost-Fiend's Avatar
Boost-Fiend is an unknown quantity at this point
Send a message via AIM to Boost-Fiend Send a message via Yahoo to Boost-Fiend
and its t-top, not targa.
Boost-Fiend is offline   Reply With Quote
Old 02-07-2011, 10:09 AM   #11
mr.booie
mr.booie's Avatar
mr.booie is an unknown quantity at this point
realistic price please. not 17,500. i would be interested at around 5k for it as is with everything. can you give us all a single price please.
http://zilvia.net/f/image.php?type=sigpic&userid=70890&dateline=122764  6693
mr.booie is offline   Reply With Quote
Old 02-07-2011, 11:44 AM   #12
ship2236
ship2236's Avatar
Trader Rating: (18)
ship2236 is making a name for him/her selfship2236 is making a name for him/her self
Feedback Score: 18 reviews
Send a message via AIM to ship2236
Lol if ur most likely keeping it u should just ask a mod to lock the thread? Lol just an idea.
ship2236 is offline   Reply With Quote
Old 02-07-2011, 07:18 PM   #13
rb26detzenkiedition
rb26detzenkiedition is an unknown quantity at this point
didnt think red came in 3 different reds. other than the hood an door effect clean car GLWS buddy.
rb26detzenkiedition is offline   Reply With Quote
Old 02-11-2011, 08:51 PM   #14
metzger
metzger is an unknown quantity at this point
I can do $14,000 with the stock wheels and shortblock only. Final offer.
metzger is offline   Reply With Quote
Old 02-12-2011, 01:28 AM   #15
iwannaslyde
iwannaslyde's Avatar
iwannaslyde is an unknown quantity at this point
thats actually not a bad offer ^^^^
u guys have to consider the age of the car and all the work it took to restore/replace alot of these parts. the car is practially new now and i think its fair asking as much as he did except that it should of been in the OP from the start. it was a little confusing lol
iwannaslyde is offline   Reply With Quote
Old 02-12-2011, 02:30 AM   #16
rb25_s13*CHUKI
rb25_s13*CHUKI's Avatar
Stupid ass thread
Obliterate
rb25_s13*CHUKI is offline   Reply With Quote
Old 02-12-2011, 08:02 PM   #17
Chaw wee
Chaw wee's Avatar
Chaw wee is an unknown quantity at this point
Originally Posted by rb25_s13*CHUKI View Post
Stupid ass thread
I agree. Wtf..
Chaw wee is offline   Reply With Quote
Old 02-12-2011, 08:11 PM   #18
Pray And Spray
Pray And Spray is an unknown quantity at this point
i dont even think this guy is selling... i tihnk hes just fronting because the prices he's posting are tooo different.
Pray And Spray is offline   Reply With Quote
Old 02-14-2011, 02:20 AM   #19
mojocoggo
mojocoggo's Avatar
Sold for $15.5k with stock wheels. Thanks for the interest.
Old 02-14-2011, 08:25 AM   #20
rb25_s13*CHUKI
bs to the fullest
Obliterate
Old 02-14-2011, 11:37 AM   #21
metzger
bs to the fullest
I bought it.
Put up an extra $1500 and got the complete motor with it, running and ready to go.
Old 02-15-2011, 05:03 PM   #22
mojocoggo
mojocoggo's Avatar
Yep, perfect transaction! Now time to get the S30 project rollin!
Old 02-15-2011, 08:40 PM   #23
2590402
Wait this has to be a joke. There is no way you paid that much for this car. I hope for your sake you didn't.
Old 02-15-2011, 09:27 PM   #24
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
I bought it.
Pics or you lie, or you are a complete idiot.
singlecamslam is offline   Reply With Quote
Old 02-17-2011, 10:34 AM   #25
mkezzo16
mkezzo16's Avatar
mkezzo16 is an unknown quantity at this point
^^^ what he said..understand a lot of work may have went into the car to replace parts..but for that price the car should be near show quality..with proper paint/ perfect body at the verry least
mkezzo16 is offline   Reply With Quote
Old 02-17-2011, 11:24 AM   #26
ship2236
ship2236's Avatar
Trader Rating: (18)
Lol who cares just lock This thread it's full of lameness and the car is "sold"
Anyways. Hopefully this seller will get it right when he finishes n tries to sell his
S30 project on here for $20,000. Lock this up
Old 02-17-2011, 11:34 AM   #27
P-Funk alot
P-Funk alot's Avatar
P-Funk alot is an unknown quantity at this point
Send a message via Yahoo to P-Funk alot
damn this guy comes up with some great bed time stories.
P-Funk alot is offline   Reply With Quote
Old 02-17-2011, 12:28 PM   #28
bmhossain
bmhossain's Avatar
Trader Rating: (34)
bmhossain is just really nicebmhossain is just really nicebmhossain is just really nicebmhossain is just really nicebmhossain is just really nicebmhossain is just really nicebmhossain is just really nicebmhossain is just really nicebmhossain is just really nice
Feedback Score: 34 reviews
This is possibly one of the dumbest things I've ever read on here.
bmhossain is offline   Reply With Quote
