Old 02-18-2011, 09:17 PM   #1
jvega
jvega is an unknown quantity at this point
sr20 wiring/ground/fp problem
hello everyone!
im having problems starting my s13 sr.
i bought a brand new harness, wired it up directly to the chassis clips, because i didnt have the Ka harness,
and the fuel pump will not prime.
The fuel pump primes ONLY when i *ground the wires by the battery*(black and pink), **but the fuel pump stays on**.
any ideas what it could be?
perhaps bad wiring job
or bad grounds?
any advice is greatly appreciated. thanks!
jvega is offline   Reply With Quote
Old 02-18-2011, 09:23 PM   #2
jvega
i double checked all the grounds and they all seem to be good.
i double checked my wiring job and it seems ok.
The fuel pump stays on when i ground the black/pink stripe fuel pump relay wires.. its wierd
Old 02-19-2011, 10:10 AM   #3
92dagrey
92dagrey is an unknown quantity at this point
bad relay. or the wires to/from the relay are bad.
92dagrey is offline   Reply With Quote
Old 02-20-2011, 04:23 PM   #4
cotbu
cotbu's Avatar
The ecu is supposed to ground the black and pink wire for the fuel pump relay.
It is to be connected to pin 104 on the ecu.
Old 02-21-2011, 12:24 PM   #5
jvega
do you think this problem is happening because the ECU is not grounded?
Old 02-21-2011, 01:40 PM   #6
Sileighty_85
Sileighty_85's Avatar
check this out
http://zilvia.net/f/tech-talk/327189...-problems.html
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 02-21-2011, 02:14 PM   #7
jvega
Originally Posted by Sileighty_85 View Post
Thanks for the info, im gonna give that a try..
btw i bought my engine from Jdm-online. I hope nothings wrong with it. I havent driven or started the motor yet.
JDM Nissan Silvia SR20DET S13 Blacktop *Upgraded* Motor '94-'98 - Sold - JDM Online
Old 02-21-2011, 07:11 PM   #8
jvega
*UPDATE*
I managed to get all the clips from a KA harness, and clipped everything in, rewired everything. (sr20 engine harness to chassis harness)
But it still has the same problem...(fuel pump wont prime, unless i ground the black/pink wires, but it stays on)
Bad ECU maybe?
Old 02-21-2011, 09:58 PM   #9
Ekin_s13
Ekin_s13 is an unknown quantity at this point
try this site SR20DET Swap Engine Harness Wiring Diagram Guide SR SR20
i use this site to wired my new sr harness
Ekin_s13 is offline   Reply With Quote
Old 02-21-2011, 10:06 PM   #10
jvega
*UPDATE*
Tried my ecu(E5) on my friends sr which also uses the E5 ecu, and it would not start, no fuel pump sound or nothing!
so im asuming my ECU is bad..
Anyone selling a s13 blacktop ecu??
Thank you guys for the help!
Old 04-12-2011, 01:35 AM   #11
240sx-pat
240sx-pat is an unknown quantity at this point
Send a message via AIM to 240sx-pat Send a message via MSN to 240sx-pat
So How did this go? I'm having the same issue
240sx-pat is offline   Reply With Quote
Old 04-18-2011, 09:39 AM   #12
Slow Poke
Slow Poke's Avatar
Slow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really nice
Are you sure you have a harness setup for the S13 blacktop ECU?
Slow Poke is offline   Reply With Quote
Old 04-18-2011, 10:35 AM   #13
lok
lok's Avatar
lok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond repute
Did you actually rewire the plugs by the battery tray?
You cant just wire the colors that match together you have to move them around to other pins.
lok is offline   Reply With Quote
Old 04-22-2011, 06:42 PM   #14
jvega
thanks for all the help guys, but it was the ecu.
the ecu was bad.
something about the fuel pump power was wrong in the ecu.
because my friend uses that ecu on his ae86 but he has everything wired directly.
i bought a new ecu, and now my car drives like a beast.
